Onkyo "Home Media" playback - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 05-11-2013, 05:59 PM - Thread Starter
krassyg's Avatar
Quoted: 12 Post(s)
Has anybody succeeded in getting their Onkyo receivers to play back from a network share using the "Home Media" option? I tried both my media server and a Synology DS412+ NAS, no go. I see the devices, but all I get is "No Item" when I select them. Sonos has no problem with the shares, both my computers see each other and the NAS. The sole purpose for this is so I can stream .DSF files from my server, thus giving me a SACD music server. Everything is gigabit cat6 with static address.
krassyg is offline
post #2 of 13 Old 05-11-2013, 09:35 PM
macuniverse's Avatar
Quoted: 26 Post(s)
+1
I would like to know the answer as well. I have a QNAP NAS with SMB, AFP & NSF enabled but I always get "No Item" message. My all other devices have no issues seeing the files on QNAP.
macuniverse is offline
post #3 of 13 Old 05-12-2013, 03:49 PM - Thread Starter
krassyg's Avatar
Quoted: 12 Post(s)
DLNA on the other hand works fine; unfortunately .DSF files don't work with it. So far the only way I can play them is from a USB thumb drive.
krassyg is offline
post #4 of 13 Old 05-12-2013, 04:05 PM
smooie's Avatar
Yes but for some reason I can only see my DS212 NAS from the Onkyo when another pc on the network which can access the NAS is powered on.
smooie is offline
post #5 of 13 Old 05-12-2013, 06:55 PM - Thread Starter
krassyg's Avatar
Quoted: 12 Post(s)
Did you have to do anything special for the router or the NAS? My computers are always on anyway.
krassyg is offline
post #6 of 13 Old 05-12-2013, 08:28 PM
smooie's Avatar
The only thing I changed on the NAS was turning off hibernation and enabling the media server service. Router is pretty much untouched.
smooie is offline
post #7 of 13 Old 05-12-2013, 08:29 PM
GoatLocker's Avatar
Quoted: 22 Post(s)
Liked: 24
This question was asked on the Onkyo Support forum and the "official" answer was "HOME MEDIA is for the use of MAC consumers also utilizing a SAMBA server". No idea if this is correct, or why there is no documentation of this feature.
Panasonic TC-P65VT60
Onkyo TX-NR818
Energy RC-70 | RC-LCR | RC-10
Klipsch R-112SW x 2
FS: Energy Veritas V-SW10 Subwoofer
FS: Mirage Omni S12 Subwoofer
GoatLocker is offline
post #8 of 13 Old 05-13-2013, 10:45 AM - Thread Starter
krassyg's Avatar
Quoted: 12 Post(s)
Are you using "DLNA" or "Home Media" from the network menu of the Onkyo?
krassyg is offline
post #9 of 13 Old 05-13-2013, 06:09 PM
smooie's Avatar
Hi. DLNA works fine. Nothing shows up in Home Media menu until I turn on my gaming box or HTPC which both have network access to the Synology. Then that other computer and the Diskstation will appear under Home Media menu after exiting then restarting the Onkyo net application. All my FLAC files show up and playback fine.
smooie is offline
post #10 of 13 Old 05-14-2013, 02:24 PM - Thread Starter
krassyg's Avatar
Quoted: 12 Post(s)
Tried it, no go. Will post in the Onkyo forum as well. I probably have to sacrifice a goat or wait for the planets to align just the right way.
krassyg is offline
post #11 of 13 Old 05-18-2013, 03:10 AM
Quoted: 26 Post(s)
Thanks for that. Please keep us posted.
As others stated Twonky DLNA server on the QNAP NAS works reasonably well (some HD Flac files don't play). It is disappointing that a product costing so much would not detail a menu feature/usage in its user manual.
post #12 of 13 Old 08-22-2013, 03:26 PM
odedia's Avatar
Liked: 25
Hi. Anyone happened to get this working? I have a nas4free box (freenas in the past) and all was working fine until suddenly it stopped working with the "no item" message. Not sure if this is directly related to the firmware upgrade I did recently.
odedia is offline
post #13 of 13 Old 10-07-2013, 07:40 PM
doomuser's Avatar
Hi everybody!
I have Synology DS213 and TX-NR3010, according to all information which I had there was no chance to get this work. But turned out it may work. When I started I saw same as you "no item" message. Then I enabled Guest account on my DiskStation And granted "read only" access to my music directory and voila Onkyo sees all folders and plays directly *.flac, *.dsf but not *.dff. If you don't have NAS simply share folder in Windows environment and it should work.
doomuser is offline
Synology Ds412 High Performance Easy To Manage 4 Bay All In 1 Nas Server For Smb Users , Onkyo Tx Nr3010 9 2 Channel Thx Certified Network A V Receiver Black
