$2,000 AV Receiver Money Can Buy - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 05-13-2013, 08:49 AM - Thread Starter
iwanrs's Avatar
Quoted: 48 Post(s)
I am looking to upgrade my existing HT with new AV Receiver.
My current AV Receiver is Sony STR-DA5400ES.
Speakers set up is 7.1 (with two Subwoofer)
Previously I owned Pioneer, Denon and Onkyo (in that particular order)
My budget is $2,000.
Every suggestion is much appreciated.
iwanrs is offline
post #2 of 13 Old 05-13-2013, 09:06 AM
redshift1's Avatar
Denon 4520ci falls in that price range and is fairly well regarded. You might want to post your components as that would be the key.
redshift1 is offline
post #3 of 13 Old 05-13-2013, 01:22 PM
Selden Ball's Avatar
Quoted: 3356 Post(s)
Liked: 1637
The new Denon X4000 (which just started shipping) might be appropriate. The major difference between it and the 4520 is that it can provide a maximum of only 9.2 audio channels instead of 11.2. (An external stereo amp is needed in either case.) Both have Audyssey XT32.
Selden
Selden Ball is offline
post #4 of 13 Old 05-13-2013, 03:19 PM
thirdeye11's Avatar
Would a combination of Emotiva gear such as the UMC-200 for signal processing at $599, a UPA-500 (80x5 amp for center, and surrounds) at $399, and an XPA-2 (300x2) at $799 be a good option?
I'm merely storyboarding here, and have no experience with Emotiva, only what I've read which is generally positive. I am currently in the same boat as the OP, but I have a 5.1 setup and am interested in the UMC-200 and an XPA-5 to replace my Denon AVR-5800.
thirdeye11 is offline
post #5 of 13 Old 05-13-2013, 06:10 PM
Hell Commute's Avatar
I vote step outside what you have owned. How about something qualtiy? wink.gif
Arcam, Cambridge, Rotel, NAD etc. You have a real budget. Get some real sound performance.
Real watts per channel sounds amazing.
Hell Commute is offline
post #6 of 13 Old 05-13-2013, 06:44 PM
oztech's Avatar
Liked: 101
My vote SC-67 from Pioneer.
oztech is offline
post #7 of 13 Old 05-13-2013, 06:45 PM
yaomizzle's Avatar
Liked: 27
I concur
Sent from my iPad using Tapatalk HD
yaomizzle is offline
post #8 of 13 Old 05-13-2013, 06:48 PM - Thread Starter
iwanrs's Avatar
Quoted: 48 Post(s)
I am kind of "Lazy" guy, I prefer all in one box.
I have Denon Pre and Power AMP before.
Unless there is a simple connections, I will give it a try (again).
Please provide me with the particular models.
iwanrs is offline
post #9 of 13 Old 05-13-2013, 06:50 PM - Thread Starter
iwanrs's Avatar
Quoted: 48 Post(s)
Yes, PIONEER is in my watch.
iwanrs is offline
post #10 of 13 Old 05-14-2013, 05:59 AM
JazzGuyy's Avatar
Quoted: 323 Post(s)
Liked: 331
You can get an SC-68 for $2000.
JazzGuyy is online now
post #11 of 13 Old 05-14-2013, 06:50 AM
grasshoppers's Avatar
Quoted: 850 Post(s)
Liked: 541
Off of the beaten path: Anthem MRX series of AVR's.
They don't have all the bells and whistles of main stream
AVR's , but they do have "anthem room correction" (ARC)
Which is outstanding.
Anthem MRX-300-Outlaw Audio M2200
Rythmik F12 subs
Paradigm Signature S6,C1,S1
Harman Kardon DMC1000 (music)
Assassin HTPC (movies)
grasshoppers is online now
post #12 of 13 Old 05-14-2013, 06:58 AM
thirdeye11's Avatar
Doing Pioneer's own comparison on their website didn't lead me to believe that the SC-68 offered any real advantages over the SC-67.
post #13 of 13 Old 05-14-2013, 10:08 AM
allargon's Avatar
Quoted: 68 Post(s)
Liked: 49
NAD? You think Onkyo has reliability issues.
The Anthem (slightly over/top end of budget) and Cambridge Audio recommendations make me drool. biggrin.gif
I know someone mentioned Emotiva. (It measures better than a $10k Bryston)
http://www.hometheater.com/content/emotiva-umc-200-preampprocessor-ht-labs-measures
You can consider the Outlaw pre-pro, too.
I would seriously consider the Emotiva combo.
allargon is offline
