denon 3311ci no standby mode - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-13-2013, 02:36 PM - Thread Starter
cooldude1606's Avatar
I recently picked up a new denon a 3311ci. it was a used product i got from work, but it doesn't seem to want to go into standby mode. it does a hard shutoff every time like it flips an internal air gap switch like the older denons used to have. any suggestions or feedback would be much appreciated
thanks
cooldude1606 is offline
post #2 of 3 Old 05-13-2013, 04:18 PM
jdsmoothie's Avatar
Quoted: 12104 Post(s)
Liked: 5508
What isn't happening to make you believe it's not in standby mode? The power ring will only turn "red" in Standby when either HDMI Control or Network Standby is set to ON, otherwise it will remain off even though the unit is still in Standby mode.
jdsmoothie is offline
post #3 of 3 Old 05-14-2013, 08:38 AM - Thread Starter
well what you suggested worked, thank you! not sure why I hadn't figured it out yet and decided to throw the question on here
