Confused on my options - Get amplifier or better receiver? - AVS Forum | Home Theater Discussions And Reviews
Old 05-19-2013, 07:30 PM - Thread Starter
Johnny Mnemonic's Avatar
Quoted: 86 Post(s)
Liked: 125
I've always had 1 receiver that powered everything. I have zero experience or knowledge on how to use supplemental amplifiers. I am aware of using "pre-outs" but have no idea how to the sound processing works across multiple receivers/amps.
I currently have a Sony STR-DH820. It is 7.1, with what I think is pre-outs and zone 2 outputs which the manual mentions is for a 2nd receiver (in a 2nd room). So I don't think the latter is what I need.
My front speakers (polk TSI500) wants 20-275 watts, my center CS20 is 20-150 watts. I feel my receiver is adequate, but not really pushing my front channels to their potential. I could likely spend 500-600 bucks this year, but don't know the technical approach (i.e. what equipment) would serve me best. Should I just save up for a new receiver ?
Thanks, and sorry for any dumb questions.
Warning: I make a lot of mistakes but occasionally I learn from them!
Johnny Mnemonic is offline
Old 05-19-2013, 07:55 PM
Mad Norseman's Avatar
Liked: 101
The Sony STR-DH820 AVR doesn't have 7.1 (or 5.1) pre-outs, so you can't use it with an external amplifier.
It has 7.1 INPUTS, and 2 subwoofer pre-outs, but no pre-outs that could drive an external amplfier.
If you want to use a receiver as your surround processor you'll need a decent one with pre-outs (a nice one would be the Yamaha RX-A820), coupled with (say) an Emotiva XPA-3 external amplifer (3 x 200watts), then use your receiver to drive the two surrounds (plenty of power for that duty), and the XPA to drive your front left & right, and center channels which are the most demanding.
Good luck!
Johnny Mnemonic likes this.
The Insane Pink Care Bear's Home Theater Set Up:
Marantz AV 8801 Processor, Emotiva XPR-5 Amplifier, Panasonic 65" ST30 Plasma, Yamaha BD-S2900 Blu-ray, Yamaha CDC-697 CD Player, Yamaha TT-500U Turntable, w/Signet TK5e, JBL ES100 Fronts, JBL LC2 Center, JBL ES30 Surrounds & 2 JBL ES250P Subwoofers
Mad Norseman is offline
Old 05-19-2013, 10:08 PM - Thread Starter
Quoted: 86 Post(s)
Liked: 125
Ok, that makes sense. I was mistaken on the outputs for sure but this cleared it up. I guess I was hoping/wishing it had more capabilities that it really did.
So the pre-outs are basically volume controlled RCA outs per channel? So the receiver still has all sound processing duties, but I assume there is also some gain control at the amplifier level.
And that XPA-3 looks perfect for my application, but my first step is definitely a bigger/ better receiver that will accommodate it.
Thanks for the info, this definitely helped!
Old 05-19-2013, 10:35 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4776
Some amps have gain control, some don't. You need to check the specs...but otherwise yes, your avr acts as a preamp only when you connect an external amp through the avr's pre-amp outputs...
lovinthehd is offline
Old 05-20-2013, 11:14 AM
SARHENTO's Avatar
If your power amp has a volume/gain control, Yamaha advises to turn it to the max and use your pre-amp to control your listening volume. Doing this will be similar to using a power amp without a volume/gain control.
SARHENTO is offline
Old 05-20-2013, 12:02 PM - Thread Starter
Quoted: 86 Post(s)
Liked: 125
I think the emotiva amp did not have gain controls(per the owner manual PDF), and the Yamaha recommended above was the pre-amp
Old 05-20-2013, 01:19 PM
lovinthehd's Avatar
Liked: 4776
But will that always be the ideal gain matching?
Old 05-20-2013, 02:41 PM
Yosh70's Avatar
Quoted: 175 Post(s)
Liked: 129
Not sure if you want "gain match" but one way to set it and forget it is with the pre/receiver off and the amp on, keep turning up the gain until you hear a hiss from the speakers.
The manual for my Parasound told me in a "THX equipped" rolleyes.gif installation, crank the gain all the way. If a non-THX receiver is used and has a "high gain", it may be necessary to reduce the level
Yosh70 is offline
Old 05-20-2013, 04:53 PM
Liked: 101
You're welcome!
This suggested set-up would be using a receiver as a surround processor/pre-amp, but using the receiver's amps to also drive your surrounds - this is a very efficient use of equipment.
The volume and switching and everything else remains controlled through the receiver.
The receiver and amp are connected with what's called a 'trigger cable' and the amp is automatically triggered on and off along with the receiver's on/off, so its all automatic.
After running the receiver's room correction software program (YPAO in the case of Yamaha for example), gain, distances, speaker levels, etc. are all automatically set and adjusted.
Old 05-29-2013, 08:11 PM
deltadube's Avatar
Liked: 36
get an xpa 5 and the umc 7.1 preamp from emo you will have great system..
cheers
deltadube is offline
Old 05-29-2013, 08:17 PM
truwarrior22's Avatar
Quoted: 333 Post(s)
Liked: 78
Check out the new Denon AVR-X4000, great useful features and Audyssey XT32! It's has preamp out too if you want to and a external amp, but I think you'll be happier with a nice subwoofer and crossover your mains around 80hz or so.
truwarrior22 is offline
