Receiver Recommendation For 9.1 Setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 05-20-2013, 08:02 AM - Thread Starter
hussain's Avatar
Quoted: 53 Post(s)
Liked: 25
Hi,
I have already bought 9.1 speakers for home theatre with intention to use the additional 2 speakers for either front height or front width.
These are atlantic technology 2200's with dipoles/bipoles for rears and sides and monopole for all the rest.
What receiver or receiver plus amplifier setup is recommended while keeping the budget below 1500 USD.
Hussain
hussain is offline
post #2 of 12 Old 05-21-2013, 07:38 AM - Thread Starter
hussain's Avatar
Quoted: 53 Post(s)
Liked: 25
anyone?
hussain is offline
post #3 of 12 Old 05-21-2013, 08:30 AM
smitty8451's Avatar
Quoted: 63 Post(s)
Liked: 86
The Yamaha RX-a3010 receiver which was last years model is still available through Amazon and will match your budget. It can power 9 speakers by itself and has amp outputs for Front Presence (which I suggest) and rear presence. I am running this unit with all 9 channels powered by ATI AT2000 series amps (because I allready had the amps from my previous setup), but in the wifes audio room which also has a yamaha RX-A3010 she does run 7 channels with front presence without issue.
Yamaha CX-A5000, ATI AT 2007 Amp, ATI AT 2004 Amp, Klipsch La Scala II- Main, RB 61's - Front heights, RC-62 - Center, RS-62's - Surround, RS-52's - Rear Surround, 2 Rythmik DS-1510 DIY Subwoofers each connected with Antimode Dual Core 2, Oppo BDP-95, MMF-7.1, Project Phono Box RS, XBox 360, XBox One, Oppo HA-1, TEAC PD-501HR transport, Atech Fabrication 7000 fanless HTPC and TASCAM DA-3000 SS Recorder, Kramer VS-88A Matrix Switch, Rogue Audio Pharaoh Int amp, Sony HAPZ1-ES
smitty8451 is offline
post #4 of 12 Old 05-21-2013, 07:43 PM
jdsmoothie's Avatar
Quoted: 12104 Post(s)
Liked: 5508
Denon's 4311CI (few years old) is 9.2 and the new X4000 is 7.2 but can be expanded to 9.2 by adding a 2CH amp or another AVR; either of which can be had under your budget.
jdsmoothie is offline
post #5 of 12 Old 05-21-2013, 07:53 PM
crn3371's Avatar
Quoted: 239 Post(s)
Liked: 192
See if your local Costco has the Pioneer 1522. For $599 you can't beat it.
crn3371 is offline
post #6 of 12 Old 05-22-2013, 10:36 AM - Thread Starter
hussain's Avatar
Quoted: 53 Post(s)
Liked: 25
Are there any 7.1 receivers which can be expanded to 9.1. I particularly like the idea of having a separate amplifier for front 3 speakers
hussain is offline
post #7 of 12 Old 05-22-2013, 11:57 AM
crn3371's Avatar
Quoted: 239 Post(s)
Liked: 192
Never heard of one. Just get a 9.1 avr that has pre outs, that way you can run a seperate power amp.
crn3371 is offline
post #8 of 12 Old 05-22-2013, 04:34 PM
jdsmoothie's Avatar
Liked: 5508
Read post #4 again. wink.gif There's also the Onkyo 818 as well.
post #9 of 12 Old 05-22-2013, 09:36 PM
DaveCarrera4's Avatar
Compare prices versus features (I did), then call your local Costco to find out which nearby store has the Pioneer SC 1522k in stock for $599, drive there and get it. I did. I'm very happy.
Why go out to a movie theater?
DaveCarrera4 is offline
post #10 of 12 Old 05-23-2013, 05:32 AM - Thread Starter
hussain's Avatar
Quoted: 53 Post(s)
Liked: 25
sadly i can't as i don't intend to use it in usa and this one only works on 110 volt, right?
hussain is offline
post #11 of 12 Old 05-23-2013, 07:33 AM
crn3371's Avatar
Quoted: 239 Post(s)
Liked: 192
Probably should have mentioned this up front!
crn3371 is offline
post #12 of 12 Old 05-23-2013, 05:20 PM
jdsmoothie's Avatar
Liked: 5508
