Emotiva XPA 1 Da Power - AVS Forum | Home Theater Discussions And Reviews
Old 05-23-2013, 02:42 PM - Thread Starter
deltadube's Avatar
Liked: 36
wow recieved my xpa 1s mono block amps yesterday
hooked em up on my paradigm studio 100 v5s
wow what an AWESOME sound
i went from the lowly power of a denon 3313 ci 125 wpc in stereo
to an xpa 3 200 wpc that produced a massive improvement in the sound quality of my speakers
yesterday i hooked up the xpa 1s mono block 500 wpc 8 ohm 1000 wpc 4 ohm
the sound is absolutely amazing another 10 steps up from the xpa 3
the sound is so much more fuller richer cleaner clearer smoother and better..
absolutely amazing improvemnet in the sound quality..
money very well spent.. if you like great sound quality..
Da Power is awesome
cheers
biggrin.gifbiggrin.gifbiggrin.gifbiggrin.gifbiggrin.gifbiggrin.gifbiggrin.gifbiggrin.gifbiggrin.gifbiggrin.gifbiggrin.gifbiggrin.gifbiggrin.gifbiggrin.gif
deltadube is offline
Old 05-23-2013, 10:49 PM
gostillerz's Avatar
Take that damn sticker off of the Denon!! What's the matter with you? mad.gif
It's these cans! He hates these cans!
gostillerz is offline
Old 05-24-2013, 06:43 AM
PeterK's Avatar
Quoted: 41 Post(s)
Liked: 54
What a HUGE mistake in purchasing the XPA-1s!!!!
Only 500 watts rating.
Better return them quick and get the King
XPR-1 at 1000 watts.
Obviously they will sound many times better than the puny XPA-1s.
Would think knowing it is all about Da Power that he would not have made this mistake.
PeterK is offline
Old 05-24-2013, 12:51 PM - Thread Starter
deltadube's Avatar
Liked: 36
oh yes the xpr 1 would be another step up in sound quality... Your right but i think i would upgrade my speakers before i add that kind of power...
i noticed you dont have a system listed in your profile
what kinda Power you running ? maybe you can post some pics too...
Man my speakers are absolutely amazing with the xpa 1s money extremely well spent... if your want amazing sound quality...
Old 05-24-2013, 12:53 PM - Thread Starter
deltadube's Avatar
Liked: 36
Originally Posted by GIEGAR View Post
Hey!!! He's a loyal follower of the Denon guru: biggrin.gif
Originally Posted by batpig View Post
The "12 inches on all sides" recommendation probably falls into the category of a CYA Clause, i.e., "some lawyer said we had to write this just so if anyone complains about overheating we can say, did you read the manual?! It says 12 inches on all sides so we're not liable!"
In the real world you can definitely get away with a lot less than that. All of my receivers have lived in my wooden A/V console, with less than 1 inch on either side, although plenty of room above and big slot in the back for ventilation. With the door closed it can get somewhat warm but never hot, but it should be noted that I don't really drive my setup that hard. If I did, I'd probably just install an exhaust fan in the back to suck out hot air.
sure would like to know how you get a foot on the bottom thats a side!
cheers
Emotiva Xpa 3 Amplifier
