Budget Receiver Recommendation - AVS Forum | Home Theater Discussions And Reviews
Old 05-25-2013, 03:15 PM - Thread Starter
deadtrick's Avatar
Hello all!
First time poster here.
I'm currently looking for a relatively inexpensive A/V receiver for my small apartment. I'm looking to connect a PS3 (HDMI), Cable Box (HDMI), Technics turntable (RCA), and iPod (RCA) to the receiver. I was also looking at using my existing pair of active speakers (KRK Rokit 5s) as the output. After doing some research, I found that I can do this by connecting the pre-outs of the receiver to the back of my speakers.
Two questions:
1. Will the receiver automatically decode digital audio and convert to send out through the analog pre-outs for my speakers? Or will I have to use passive speakers in a more traditional setup?
2. Recommendations of a receiver that can accomplish this? Or any workarounds?
Apologizes for my lack of receiver knowledge. Thanks everyone!
deadtrick is offline
Old 05-25-2013, 03:41 PM
vzphoneman's Avatar
Quoted: 82 Post(s)
Liked: 78
First what price range are you thinking? If you are using the KRK's you might get away with a "preamp" as apposed to a receiver. I think you will more then likely need a phono preamp for the turntable.
The lazy man finds the easiest way ... Ben Franklin
Rouge Audio Cronus Magnum II integrated amp, Goldenear Technology's Triton 2+ speakers, Schiit Bifrost Multibit Dac, Technics SL-1200MK2 turntable with Audio Technica 440ml cartridge, Teac X-1000R reel to reel, custom computer as main music source
vzphoneman is offline
Old 05-25-2013, 04:30 PM - Thread Starter
deadtrick's Avatar
I understand that the turntable requires a phono preamp. Would it not be possible to just plug the turntable into one of the analog RCA inputs on a receiver?
I'm looking for a receiver because of the HDMI connections (PS3, Cable Box). They both have analog outs as well, but would require more cable purchases (other than the current HDMI cables I already have hooked up to my TV).
My price range is around 250 max, I know it's pretty low for a receiver but that's why I'm looking into other options as well.
Old 05-25-2013, 04:36 PM
crn3371's Avatar
Quoted: 240 Post(s)
Liked: 192
You'll need a phono preamp for sure. The hard part is going to find a budget avr with pre outs for your speakers. Might need to go used.
crn3371 is offline
Old 05-25-2013, 04:47 PM - Thread Starter
deadtrick's Avatar
I see, well I guess I'll have to buy a separate phono preamp and connect that to the receiver then.
I don't have a problem going used, but I just found this on amazon: http://www.amazon.com/Pioneer-VSX-522-K-5-Channel-Receiver-iPhone/dp/B007L8Q75G
Would something like this work?
Old 05-25-2013, 04:55 PM
crn3371's Avatar
Quoted: 240 Post(s)
Liked: 192
That will work, but only as long you just want to run 2.1
crn3371 is offline
Old 05-25-2013, 04:59 PM - Thread Starter
deadtrick's Avatar
No problem with running 2.1, seeing as I don't have enough room for a full 5.1 setup anyway.
Going back to my first question, the receiver will automatically convert the digital audio from the HDMI inputs and send them to the analog pre-outs, correct?
Old 05-25-2013, 05:14 PM
crn3371's Avatar
Quoted: 240 Post(s)
Liked: 192
I take back what I said about it working. Upon further reading the pre outs are only for presence speakers. Keep looking.
crn3371 is offline
Old 05-25-2013, 07:14 PM
afrogt's Avatar
Quoted: 1056 Post(s)
Liked: 757
something like this Marantz 1403 would work. It has a set of preouts for the front speakers.
http://www.accessories4less.com/make-a-store/item/MARNR1403/MARANTZ-NR1403-Slim-5.1-Channel-3D-Pass-Through-Home-Theater-Receiver/1.html
Yes
Afro GT
afrogt is online now
Old 05-25-2013, 07:23 PM - Thread Starter
deadtrick's Avatar
Ah thanks for the heads up, crn3371.
That Marantz looks nice, a bit out of budget, but I will look for one used. Looking for more recommendations. Thanks!
Old 05-25-2013, 07:26 PM
afrogt's Avatar
Liked: 757
What's your budget?
HDMI A/V receivers with preouts for cheap are hard to find.
Afro GT
Old 05-25-2013, 07:49 PM
vzphoneman's Avatar
Quoted: 82 Post(s)
Liked: 78
I also would recommend the Marantz NR1403 from the same site. It's Marantz factory refurbished for $299. I doubt you'll do much better, price and quality wise, unless you switch to a stereo receiver but finding one of those with the HDMI's you need will be tough.
Old 01-09-2014, 06:17 PM - Thread Starter
deadtrick's Avatar
Hi all!
Sorry to resurrect an old thread, but I just bought the marantz nr1403 and I'm having a bit of a problem. I've connected my speakers directly to the pre-outs located in the back of the receiver, but I'm not receiving any sound at all, only a faint buzz. Looked in the manual and it simply says to connect the pre-outs to a separate amplifier, then to the speakers (hence my powered monitors). What gives?
Old 01-09-2014, 06:30 PM - Thread Starter
deadtrick's Avatar
Ok actually I solved the "no sound" problem, but anyone have an idea about the buzzing noise? Is this possibly because I'm using regular RCA cables (Red/white) and not a balanced 1/4 (TS)cable? Thanks!
Old 04-20-2015, 03:54 PM
Liked: 0
How did you resolve the no sound problem? Did you buy a separate amplifier? I get no sound either from connecting my Rokit 5s to the preouts on the Marantz 1403.
johnnyutah81 is offline
Old 04-20-2015, 04:59 PM - Thread Starter
deadtrick's Avatar
Hi,
I've since changed over to passive speakers, but if I remember correctly it was simply an issue of having the volume level on the back of the Rokit's turned up, and the Marantz volume also turned up. If everything's connected correctly it should work fine, just have to mess around with the gain on both amps.
