Denon AVR-3313CI - zones 2 and 3 no sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 05-28-2013, 09:14 PM - Thread Starter
fitzmann's Avatar
I am clearly setting up wrong..... I have 5.1 in my main media room. I want to have outside speakers as a zone 2 and 2 living room speakers as a zone 3.
The main zone I have playing the 5.1 just fine. Did the set up and worked just fine.
I cannot figure out how to get the speakers in Zones 2 or Zones 3 to play.
I tried setting up Main to be 9.1 and now everything plays what is on Main zone.
I'd like to be able to play Main as surround TV, and zones 2 and 3 as a separate feed for example music from a DVD player.
Any advice on where I am going wrong and how to accomplish what bI am trying to do?
fitzmann is offline
post #2 of 9 Old 05-29-2013, 03:59 AM
jdsmoothie's Avatar
Quoted: 12082 Post(s)
Liked: 5502
jdsmoothie is online now
post #3 of 9 Old 08-17-2014, 08:13 PM
Liked: 0
Denon AVR 3313ci zone 2 or 3 no sound.
I did not find any help on your link.
I kind of had it once a while ago but it stopped working for no apparent reason. I independently tested my external speakers and they work fine. I am using my android or iPod for the source via AUX 1. Speakers are attached to surround back outputs. I have had the Main zone set to both 7/1 and 5/1 to no avail. i feel like of tried every conceivable option.
My previous AVR was half the price and worked great, but lacked the HDMI input/outputs but kinda wished I still had it.
Also the remote does not lite up and is extremely difficult to see the small buttons in normal lighting conditions.
scerami is offline
post #4 of 9 Old 08-17-2014, 08:40 PM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
Wow you come back here almost 15 months later. I'll try to help. That is a 7 channel amp so no way to assign all three zones internally.
Start with page 92 of the manual where set up speaker starts. Plug the audyssey mic into the front port and you will see an amp assign option.
Go there. Now look at page 93 and see the internal amp channel assign option buttons. You only get to pick 7 not 9 channels. That is it.
Now rerun audyssey software as shown on page 94.
kikkenit2 is offline
post #5 of 9 Old 08-18-2014, 05:08 AM
jdsmoothie's Avatar
Liked: 5502
There's no reason to run Audyssey again. Simply ensure that the AMP ASSIGN setting is on "5.1/Zone 2", set Zone 2 to ON using the remote control or front panel button, select the front AUX source input and you should be good to go. Try selecting the TUNER as a source to test. Also, does the USB source work when selected for the main zone?
post #6 of 9 Old 08-18-2014, 09:05 AM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
That makes sense. Can amp assign be accessed without plugging the mic in? I didn't see it in any regular menu in the manual.
post #7 of 9 Old 08-18-2014, 09:51 AM
jdsmoothie's Avatar
Liked: 5502
Yes, it can. That's how you make any desired configuration changes via the GUI menu.
post #8 of 9 Old 08-18-2014, 10:33 AM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
Ok so I can't find a picture of the setup>speaker>manual setup>amp assign gui but that is how to get there.
Options shown on page 130. No 9.1 option.
post #9 of 9 Old 08-18-2014, 12:30 PM
jdsmoothie's Avatar
Liked: 5502
Correct. This model is only capable of 7.1. The successor X4000 is the first at this level to be expandable to 9.1.
Denon Avr 3313ci Receiver
