The "Official" Yamaha AVENTAGE RX-A1030, RX-A2030, RX-A3030 and CX-A5000/MX-A5000 Thread - Page 123 - AVS | Home Theater Discussions And Reviews
post #3661 of 3680 Old 04-29-2015, 08:50 AM
rdgrimes's Avatar
Quoted: 777 Post(s)
Liked: 384
Originally Posted by Montucky View Post
Just to follow up on my own question, it would appear that the 1030 doesn't allow for different crossover points for individual speakers. Is this Yamaha wide, or just on the lower models?
The higher models allow crossover setting for each pair, there's no particular reason to allow individual speaker settings except for the center.
rdgrimes is offline
post #3662 of 3680 Old 04-30-2015, 08:38 AM
Quoted: 40 Post(s)
Liked: 38
Well that's a bummer. I'd kind of like to lower the crossover points on the rears/surrounds since they can easily handle it, but perhaps that will make things sound a bit off? Don't get me wrong, it still sounds great. I'd just like a bit more bass coming from those speakers if possible.
What Yamahas DO allow individual crossover settings?
Montucky is offline
post #3663 of 3680 Old 04-30-2015, 05:41 PM
azz7686's Avatar
Quoted: 36 Post(s)
I have the 3030 and I listen to my music in server thats actually my WD my cloud have listened to it this way for quite a while but tonight I seem to be getting a lot of crackling going on, and its music I always listen to so I know it wasn't there before? Just wondered if anyone else has had this issue or any possible fix or dilemma I might be facing here! Thanks
2-RTi-10's 1-CSi5 2-TSi400 6-r150's 1-Velodyne DPS-12
Yamaha RX-A3030 and Emotiva XPA-200
Samsung UN65F7100
azz7686 is offline
post #3664 of 3680 Old 04-30-2015, 06:00 PM
azz7686's Avatar
Quoted: 36 Post(s)
Hey I remember some one asked if the lollipop update on a phone would still control receiver and I just updated my S4 and it still works great
Samsung UN65F7100
azz7686 is offline
post #3665 of 3680 Old 04-30-2015, 06:15 PM
smitty8451's Avatar
Quoted: 43 Post(s)
Liked: 70
I have a CX-A5000 that I stream too from a home server and once I had this happen. I just physically unplugged the power cord from the back of the unit for a minute or two then plugged it back in, no further issue. I think (I'm an IT Tech by profession) the TCP/IP Protocal gets corrupted and ip packets start getting dropped/scrambled creating packet loss. I have read about this happening on all major brands. These units are not like a network switch that has error correction, but they do a very respectable job. Remember internet connectivity is relatively new to AV BUT WILL ONLY GET BETTER WITH TIME. Things I do to all my network connected gear is one, give them a static IP address (turn off DHCP) and two, exclude those addresses from the dhcp pool on your router. I have 10 Av devices on my network (excluding wireless devices) and besides the onetime issue have not experienced any issues in the last 7 years. Also keep in mind there are a lot of other factors that can attribute to this particular issue and you might want to check these;
Faulty cat5/6 cable and/or RJ45 ends
Cat5/6 running close to power cords/power strips ect
Cat5/6 running to close to power transformers, powered sub plate amps are a likely culprit
Failing hub or router
Multiple high bandwidth devices going to a low bandwidth hub
The list goes on but if continues to be an issue I would start by checking your home network cabling.
Yamaha CX-A5000, ATI AT 2007 Amp (7X200W), ATI AT 2004 Amp (4X200W)Klipsch RF 63's - Main, RB 61's - Front heights, RC-62 - Center, RS-62's - Surround, RS-52's - Rear Surround, 2 Rythmik DS-1510 DIY Subwoofers (With PEQ600XLR3 Amp) each connected with Antimode 8033S-II, Oppo BDP-95, MMF-7.1, Project Phono Box RS, XBox 360, XBox One, Oppo HA-1, TEAC PD-501HR transport
smitty8451 is offline
post #3666 of 3680 Old 05-01-2015, 04:24 PM
boxerfan88's Avatar
Known problem without a permanent fix. It's more apparent when streaming hi-res flac files. Usually starts 4-6 weeks after a reboot. On my unit, Yamaha changed the main server board and the problem still exist. This problem does not happen when one does not use network standby. Clearly it is a software/firmware issue with the network stack.
Workaround: reboot the AVR via mains power off/on when the problem arises.
RX-A3030 | Usher MD2 + Klipsch RB51 | Sony BDP-S5100 | HTPC
Zone 2 | Heco Victa 702
Zone 3 | Audiolab 8000A | Rogers LS6a
boxerfan88 is offline
post #3667 of 3680 Old 05-01-2015, 05:24 PM
azz7686's Avatar
Quoted: 36 Post(s)
Thumbs up
Well I will do the power down and up thing thought maybe this was not the issue but obviously not cause the old dreaded Onk used to do that but then turned into something worse so I worry when I have to start powering down units after this experience. All my networked devices have their own ip and I usually don't have any issues but the packets getting dropped/scrambled makes sense, I work as a security service tech and deal with nor's and ip cameras that just drop everything and a usual power cycle fixes this issue so I do appreciate the advice and will let you know.
Samsung UN65F7100
azz7686 is offline
post #3668 of 3680 Old 05-04-2015, 03:19 AM
fish5225's Avatar
Quoted: 43 Post(s)
Any word if Yamaha is ever going to add wifi to its only preamp? Cx 5050? I have a 2040 but wanted to upgrade to a pre/pro but I need wifi for streaming as I can't run wire to my stereo location. Right now marantz appears to be the only pre/pro with wifi but their interface/app for streaming is not good on their avr's although I have not tried the 8802. Hears to hoping that Yamaha comes out with a new unit.
fish5225 is offline
post #3669 of 3680 Old 05-04-2015, 06:13 AM
PretzelFisch's Avatar
Quoted: 143 Post(s)
Liked: 178
Yamaha sells a wifi to ethernet bridge or you can buy one off the shelf, with more then one ethernet port. this way you don't have that radio in your preamp and you can position the device where you can get the best wifi signal.
PretzelFisch is online now
post #3670 of 3680 Old 05-04-2015, 09:57 AM
fish5225's Avatar
Quoted: 43 Post(s)
I assume the bridge works with the Yamaha App? It of course would be nice to get the updated 2.2 compliant chipset if they introduce a new model. I obviously will wait for Yamaha to announce, I am just very happy with the sound of the 2040 so was hoping to step it up another notch but would prefer to wait for a new unit if available. Just looking for info thanks.
fish5225 is offline
post #3671 of 3680 Old 05-04-2015, 12:51 PM
Quoted: 143 Post(s)
Liked: 178
the bridge just lets you go from wifi to wired ethernet so configured right there will be no trouble.
post #3672 of 3680 Old 05-04-2015, 03:25 PM
Woochifer's Avatar
I concur with the above rec about adding a dedicated wi-fi bridge. Typically, Ethernet connections present far fewer issues than wi-fi, and those standalone bridges will have better range and more reliable connections than the wi-fi built into a home theater device. Plus, if your devices use a combination of 802.11 G, N, and/or AC wireless, a Wireless-AC wi-fi bridge can connect multiple devices in your entertainment system and bring everything up to the faster wi-fi spec. A few years ago, the wireless performance on my DVR and PS3 were horrible -- lot of dropouts, error messages, and general connectivity issues. Since I added a Linksys entertainment bridge (Wireless N, with 4 ports), the connection speed and reliability to the music server and internet router have been flawless.
Woochifer is offline
post #3673 of 3680 Old 05-04-2015, 04:31 PM
Woochifer's Avatar
My 14 year old Yamaha RX-V800 recently started shorting out the analog audio and video connections, so I decided it was time to finally retire that old workhorse. I'd been getting by with coaxial digital audio connections, and using an Oppo HM-31 HDMI auto switch for the digital video sources. And I still have some legacy devices connected to the system (a turntable, Sony ES SACD player with no HDMI outputs, and a S-VHS VCR) that I wanted to keep.
Since I'm not building a system from the ground up and not in the market to upgrade individual components, I wanted a receiver that I could drop into my entertainment unit, plug everything back in, and move on with my life. Shopping around for AV receivers (it's been a "few" years), I was shocked at how few of them include phono inputs, multichannel analog audio inputs, pre outs, and analog video switching. I looked around, and it turned out that once again, it was Yamaha that best met my needs. And the closeout pricing on Amazon wasn't bad either.
Just added a RX-A1030 a week ago. Decided to opt for the discontinued model because I did not need the RX-A1040's built-in wi-fi (already use a wi-fi bridge) and Bluetooth (use iOS devices for AirPlay). And the RX-A1030 still supported S-video, while the newer models dropped that spec. I won't be upgrading to 4k anytime soon, so the RX-A1040's support for 4k/60 Hz 4:4:4 pass-through doesn't mean anything to me either (especially since the RX-A1040 isn't HDCP 2.2 compliant).
First impressions -- very impressed! The RX-A1030 is in the same lineage with my old RX-V800 -- basically, the entry level for Yamaha's middle tier receivers, where they beef up the power supplies and greatly improve the internal build quality. Both receivers weigh the same (33 lbs) and have almost identical exterior dimensions, with the RX-A1030 about a half inch taller.
I ran the YPAO auto calibration, and did my own verification with a SPL meter. The YPAO was fairly accurate, and tried to set all my speakers to large. But, I bypassed that and opted to go with a 60 Hz crossover. I also saw what the YPAO did with the speaker EQ. Wound up switching the PEQ settings off. I just prefer the straight unprocessed sound.
On the subwoofer EQ, I use a 12-year old Behringer Feedback Destroyer. Dusting off the old subwoofer filter settings and measuring the test tone output manually, I found that I didn't need much adjustment. Mostly tweaking around the crossover point, because I changed it from the fixed 90 Hz crossover point on my old receiver.
On the whole, I found the sound quality on the RX-A1030 a bit more refined. But, there are also a lot more ways of adjusting and processing the sound. I'm still trying different settings and seeing which ones I like for different sources.
A BIG minus for Amazon though. They double-boxed the receiver for shipment. But, they packed the receiver box upside down! No visible damage, but I'm contacting Amazon to see what they have to say about my concerns about how this might affect the receiver's long-term durability. Normally, I would give the right of last refusal to a local B&M store. But, the RX-A1030 has been discontinued long enough for stores to no longer have any left in inventory.
Relative to current models, yes the RX-A1030 is behind the curve. But, I have more than a decade's worth of advances to trudge through in the meantime. So far, I'm enjoying it. This is only my 3rd receiver in 28 years -- all of them Yamahas. We'll see if I end up getting 14 years of everyday use out of this one as well...
The only hiccup I've found with the RX-A1030 so far is that runs noticeably hotter than the RX-V800 did. Looking at the interior layout, it seems that the RX-A1030 has less free space and the digital processor boards are right at the top of the cabinet (away from the heat sinks, but still in closer proximity to the amplifer section than before). Also, the older Yamaha receivers placed the digital processor boards inside of shielded compartments, with copper grounding attachments. That's the kind of tradeoff that had to be made to maintain the same weight.
post #3674 of 3680 Old Yesterday, 10:17 AM
Quoted: 40 Post(s)
Liked: 38
So now that the CX/MX-A5000's have been out for a while now and some of you have loads of extended hands on experience with them by now, what are your thoughts on them these days? Still impressed? Waiting eagerly for the next models? Wish you had gone with a comparable Marantz/Denon/etc? Would love to hear your updated thoughts on these models.
I was going to wait for the fall line-up (DTS:X!!!...hopefully), but have seen some good deals on refurbs so now I'm checking back into these guys.
Montucky is offline
post #3675 of 3680 Old Yesterday, 08:30 PM
smitty8451's Avatar
Quoted: 43 Post(s)
Liked: 70
Still lovin mine and I got it 2 days after release in the USA. No problems to date and a rock solid unit.
post #3676 of 3680 Old Today, 06:11 AM
bwillcox's Avatar
Quoted: 32 Post(s)
Liked: 26
Total agreement. I've had mine since it was first available and haven't regretted it at all. I've had zero problems with it and love its sound.
bwillcox is online now
post #3677 of 3680 Old Today, 08:47 AM
Quoted: 40 Post(s)
Liked: 38
Wonderful! Great to hear that you guys are still happy with them.
Montucky is offline
post #3678 of 3680 Unread Today, 06:21 PM
M Lo's Avatar
Same here, too. This is an impeccable unit. No reasons to complain so far.
My HT Gear:
Sony VPL-VW95ES / Panamorph A480SYS / EluneVision 2.40:1 143" CinemaScope Screen / Yamaha CX-A5000 / Oppo BDP-95 / Pioneer DV-47Ai / Crown XLS 1000 x 4 / Crown XLS 1500 x 1 / Crown XLS 2000 x 1 / Axiom M80Ti x 3 / Axiom QS8 x 2 / Yamaha NS-E105 x 2 / Yamaha NS-E60 x 2 / OSD Audio AP650 White 6.5-inch 150-Watt Speaker x 2 / SVS PB12-Plus / Mirrage BPS-400 / Buttkicker x 2 / Aura Transducer x 2
M Lo is online now
post #3679 of 3680 Unread Today, 06:56 PM
glugus2000's Avatar
Bought a used one and it was a nice upgrade from the rxv3800 it replaced. Much clearer sound. Couple issues, and most people would never see this, but sometimes when switching from any input to the tuner, no audio. Power off and back on will restore it. Not significant enough for me to worry about. And, It's coaxial input are not quite as sensitive as the rxv3800. Have a computer about 25 feet from the av rack and the cx-a5000 would never detect signal. Had been using the same setup forever with the rxv3800. Replaced the coax with optical cable and it works great. Even with those 2 minor issues, I'm still very happy with it.
Sent from my SM-P900 using Tapatalk
glugus2000 is online now
post #3680 of 3680 Unread Today, 07:07 PM
Motley01's Avatar
Quoted: 13 Post(s)
I just recently purchased an RX-A740. Holy smoke batman! This thing is absolutely beautiful. Its my first AV receiver in over 8 years! Had a crappy Onkyo receiver. I have all new speakers too. Klipsch Ref II. Towers, center 5.25", and 4 bookshelfs 5.25". I still need a sub. I'm gonna go with the BIC Acoustnet PL-200 12" sub.
Love the streaming all my music from my PC. I've collected a lot of music over the years, and its nice to be able to listen to it now on my receiver, instead of the PC.
One weird thing though that happened. Sometimes I would here this echo, like one of the cinema DSPs were on or something. Even though I had "Straight" configured for the audio input on my Comcast X1 DVR. Well, I have the HDMI passthrough configured. I figured it out though. It was my TV speakers echo'ing with the surround speakers. So when I turn my TV on, and have the receiver off. I had to mute the TV speakers before I use the receiver. Dough! User error on my part. Hell I didn't know. LOL
Overall love the quality of the build on this. Was able to updated to firmware version 1.50 using the USB. Very easy.
Motley01 is online now
Yamaha Aventage Rxa 1030 Receiver , Yamaha Rxa2030bl Aventage Home Theater Receiver , Yamaha Rxa3030bl Aventage Home Theater Receiver
