The "Official" Yamaha AVENTAGE RX-A1030, RX-A2030, RX-A3030 and CX-A5000/MX-A5000 Thread - Page 131 - AVS Forum | Home Theater Discussions And Reviews
 85Likes
post #3901 of 3907 Old 02-02-2016, 06:16 AM
smitty8451's Avatar
Quoted: 54 Post(s)
Liked: 80
Originally Posted by nsiret View Post
I have a CX-A5000. I have an input for an Apple TV that is use for both Movies and Music. I would like to use a different scene for each - one with the front speakers set to Small (Movies- Scene 1) and a second with the front speakers set to Large (Music - Scene 2). I know I can do this by having each of the two scenes use different speaker setting patterns (1 and 2). I would only be using the Scenes for the Apple TV. I use a Pronto remote so I want to automate this.
1. Can I start the Apple TV in my standard mode I have set for that input and then select either Scene 1 or Scene 2 depending on if I watch a Movie or listen to Music?
2. The next time I start the Apple TV, will the last scene used automatically be loaded?
3. If the only thing I configure for Scene 1 or Scene 2 is the different speaker patterns, will all other settings remain the same?
Thanks for the help.
Nick
Having owned a CX-A5000 since they first came out and setting it up for an oppo BDP-95 connected via my HDMI 1 input here are my finding in light of your questions;
1. Yes
2. Yes
3. Yes
The only thing that I found changed was in question #2 and that if I unplugged the power to my unit (going on a long vacation ect) then sometimes when plugged back in it would revert to scene 1 when it was left on scene 2 prior to being unplugged.
Yamaha CX-A5000, ATI AT 2007 Amp (7X200W), ATI AT 2004 Amp (4X200W)Klipsch La Scala II- Main, RB 61's - Front heights, RC-62 - Center, RS-62's - Surround, RS-52's - Rear Surround, 2 Rythmik DS-1510 DIY Subwoofers (With PEQ600XLR3 Amp) each connected with Antimode Dual Core 2, Oppo BDP-95, MMF-7.1, Project Phono Box RS, XBox 360, XBox One, Oppo HA-1, TEAC PD-501HR transport, Atech Fabrication 7000 fanless HTPC and TASCAM DA-3000 Solid State Recorder/ADDA upconverter
smitty8451 is offline
post #3902 of 3907 Old 02-02-2016, 06:30 AM
Redoryx's Avatar
It has been a long time since I've been here.
I have a V-2030 7.1 with Dual subs. X-over set at 80, speakers set to small.
The issue I am having is, and am not sure if this has happened to anyone else, is that the volume seems to be lower than it should be.
Its hard to explain, I listen at -29db. Run YPAO sounds fantastic, loud and crisp. after about 1 month, I notice that it just is not as loud as before. Re run YPAO, and it is back to normal.
I do not have a DB meter to verify, just my ears.
GAMERTAG: ORYX
Redoryx is offline
post #3903 of 3907 Old 02-02-2016, 07:09 AM
nsiret's Avatar
1. Yes
2. Yes
3. Yes
Thanks for the responses.
Nick
nsiret is online now
post #3904 of 3907 Unread Yesterday, 01:28 PM
nsiret's Avatar
Nick
One other question on this.
If I enable a Scene for an input, is there a way to cancel that Scene and go back to the standard settings for that input?
Thanks again for the help.
Nick
post #3905 of 3907 Unread Yesterday, 04:01 PM
Philnick's Avatar
Quoted: 195 Post(s)
Liked: 79
Nick
The easiest is to set up two scenes for that input - one set to the default settings. If you can tie one of them to one of the row of Scene buttons in the middle of your remote (like "DVD/BR") and put the other one as one of the other eight you use the remote to scroll between, you can always go back to the one you use most often by hitting its dedicated button.
That's what I do.
Philnick is offline
post #3906 of 3907 Unread Yesterday, 06:05 PM
nsiret's Avatar
That's what I do.
Thank you. That will work!
post #3907 of 3907 Unread Today, 10:27 AM
rustolemite's Avatar
Quoted: 84 Post(s)
Liked: 36
Well just ordered my CX-A5100 from AVScience this morning it will be replacing my current CX-A500, excited to see what improvements they have made and to use the updated YPAO software.
Rustolemite
Mitsubishi WD-92840
Yamaha CX-A5000 + Emotiva XPA-5
GoldenEar Triton Five + SuperCenter XXL + Axiom QS8's
HSU VTF-3 MK4 Subwoofer
LG BP550+ Sony BDP-CX960 + HTPC +Xbox One
http://www.invelos.com/dvdcollection.aspx/Rustolamite
rustolemite is online now
Yamaha Aventage Rxa 1030 Receiver , Yamaha Rxa2030bl Aventage Home Theater Receiver , Yamaha Rxa3030bl Aventage Home Theater Receiver
