The "Official" Yamaha AVENTAGE RX-A1030, RX-A2030, RX-A3030 and CX-A5000/MX-A5000 Thread - Page 134 - AVS Forum | Home Theater Discussions And Reviews
 91Likes
Old 10-10-2016, 09:35 AM
Gurba's Avatar
Quoted: 385 Post(s)
Liked: 186
Originally Posted by Bond 007 View Post
Then dont replace your 2 amps with 1.
I'd rather have one amp With 11 channels but if it can't really handle it it's no use.
Gurba is offline
Old 10-10-2016, 10:00 AM
Bond 007's Avatar
Quoted: 2091 Post(s)
Liked: 1749
I wouldnt buy a different receiver for just that reason.
Bond 007 is offline
Old 10-10-2016, 10:05 AM
Gurba's Avatar
Quoted: 385 Post(s)
Liked: 186
I don't need a receiver. I've got the CX-A5100. I just want to replace the two poweramps I've got with one with 11 channels. But I guess that's not going to happen.
Gurba is offline
Old 10-16-2016, 06:41 AM
dertitan2's Avatar
I just connected and epson 2040 to my 3030, image when watching cables flashes on and off then goes blank
If I connect the pj directly to the cable box with same hdmi cables image is perfect
I poured through my 3030 user manual but I cannot find any thing to fix, did the same with pj manual
Any suggestions
dertitan2 is offline
Old 10-16-2016, 08:08 AM
bguzman's Avatar
Quoted: 46 Post(s)
Liked: 514
Any suggestions
What is your Video Mode and Resolution setting?
HT, Mitsubishi HC6500, 106" screen, Samsung 32" LCD, Oppo BDP-83, Pioneer Elite BDP-62, Toshiba A35, Panasonic LX-1000U, Pioneer Elite CLD-95, DirecTV H21-100, PS3, Pioneer Elite SC-85, Def Tech; SM 450, CLR 2002, BP2X, Klipsch KSB 1.1(X4), Pro Sub 100, Polk PSW125
Old School, Sony PS-5500->Denon 103r->AU-320 SUT, Sansui SR-4050c->Shure M91ED, Alternative Acoustics preamp, Kyocera R-861, Polk Monitor 10A
bguzman is offline
Old 10-16-2016, 08:42 AM
dertitan2's Avatar
Video mode processing, resolution auto, I tried switching the resolution to through, but that didn't change anything
Old 10-16-2016, 10:52 AM
bguzman's Avatar
Quoted: 46 Post(s)
Liked: 514
I had some trouble with Auto on my system as well. First try the resolution at 720p, then, 1080i, then 1080p. Let me know the results.
bguzman is offline
Old 10-17-2016, 05:21 AM
dertitan2's Avatar
I did a reset, working perfectly now
Old 10-17-2016, 06:44 AM
bguzman's Avatar
Quoted: 46 Post(s)
Liked: 514
Excellent, carry on then.
bguzman is offline
Old 10-17-2016, 07:25 AM
dertitan2's Avatar
Quick question, on the 3030, when I am playing music such as Pandora, and I have it in 9 channel stereo mode, what wattage is the avr pushing to each speaker, I ask only because I came across a 5 channel and 2 channel rote amp and was thinking about out boarding
Old 10-27-2016, 02:52 PM
Davidroidx's Avatar
Quoted: 44 Post(s)
Liked: 9
I have 2 mxa5000's, 1 is sitting brand new in box because I dont need it. So much so I might sell it. For home theater it works great, although all sound is not happening at one time. My subs are seperately amplified. I also have a seperate amp for music 2 channels.
Davidroidx is online now
Old 10-27-2016, 05:03 PM
red_5ive's Avatar
Quoted: 13 Post(s)
Anyone getting "Access Error" and "You are not connected to the network" error with Pandora? The issue started a couple of days ago on my RX-A1030 and has not recovered. I am also having the same problem with my RX-A3020, which appears to have started at the same time. Net Radio is working just fine and I am listening to Net Radio now as I type this so I know I have a WAN connection.
Also, if I try the "Remove Account", "Add Account", or "Switch User" in the 1030 Pandora input options, it immediately gives the "Access Error" message.
I've done the following to no avail:
  1. Changed from a Static IP to DHCP (been using static the whole time, but tried DHCP for the heck of it, and currently back on static as it didn't help).
  2. Tried a different static IP and one that I know isn't in use, although on same subnet.
  3. Set a MAC address reservation for the 1030 (I actually had this setup previously, but changed it to different IP and back).
  4. Tried different DNS server (google). This actually seemed to improve Net Radio connectivity, but still no Pandora.
  5. Set QoS Priority to ""Highest" for the 1030.
  6. Connected to a completely different router.
  7. Logged on to my Pandora account and verified it's actually working (via web browser).
I'm still on a very old FW version 1.03, but I haven't had any issues in 2+ years since the last time I updated so I haven't bothered updating. But before I go updating the FW I just wanted to check first if anyone is having issues or knows of any. Thanks.
Defeat of Deduct must go over Defense before Detail does.
red_5ive is offline
Old 10-27-2016, 05:33 PM
boxerfan88's Avatar
Quoted: 13 Post(s)
Maybe Pandora refresh/changed their authentication key.
RX-A3030 | Usher MD2 + Klipsch RB51 | Sony BDP-S5100 | HTPC
Zone 2 | Heco Victa 702
Zone 3 | Audiolab 8000A | Rogers LS6a
boxerfan88 is offline
Old 10-27-2016, 07:13 PM
red_5ive's Avatar
Quoted: 13 Post(s)
It doesn't look like it's the 1030 or the 3020. I forgot my Oppo BD player has Pandora. I haven't used it in years and decided to test it out. I had to re-enter my account information, and it logged on successfully and I saw my stations, but then it too threw a network error. Although the Oppo continues to play, once I click "Ok" to the error message it exits back to the Home screen. So at this point it looks like it's something on my network (although I can login to Pandora fine with a web browser) or with my service provider (which sucks now ever since Frontier took over Verizon FiOS in my area)... or maybe something else...
Edit: I pulled the LAN cable from the 1030, and the status changes from "access error" to "not connected", and then when I plug cable back in and the unit will flash "successfully connected to network" at the bottom, then Pandora will change back to "access error". So definitely looks like Pandora is trying to do something then dies somewhere, as otherwise it didn't look like it was even trying to establish a connection before. More troubleshooting later. *sigh*
red_5ive is offline
Old 11-02-2016, 03:18 PM
red_5ive's Avatar
Quoted: 13 Post(s)
^^ Just following up on my Pandora troubles. I still couldn't find a cause that wasn't pointing to the 1030 and 3020, so I went ahead and updated the FW on the 1030 and sure enough that fixed it. 3020 is next.
red_5ive is offline
Old 11-06-2016, 12:01 PM
Bond 007's Avatar
Liked: 1749
Can I play music stored on my Android tablet through the 2030?
Bond 007 is offline
Old 11-08-2016, 04:18 PM
azz7686's Avatar
Quoted: 165 Post(s)
Liked: 55
Yes, Just use the app and it will automatically find it.
Spoiler!
azz7686 is offline
Old 11-09-2016, 05:25 AM
Bond 007's Avatar
Liked: 1749
Doenst work for me.
Bond 007 is offline
Old 11-09-2016, 04:21 PM
azz7686's Avatar
Quoted: 165 Post(s)
Liked: 55
What does it do? Its the music icon with 3 lines in it, Could be where the music is stored if its android cause mine only shows 3 so I would have to move my music to where those 3 are so it might depend on the phone and how the app works with it.
Spoiler!
azz7686 is offline
Yamaha Aventage Rxa 1030 Receiver , Yamaha Rxa2030bl Aventage Home Theater Receiver , Yamaha Rxa3030bl Aventage Home Theater Receiver
