The "Official" Yamaha AVENTAGE RX-A1030, RX-A2030, RX-A3030 and CX-A5000/MX-A5000 Thread - Page 48 - AVS Forum | Home Theater Discussions And Reviews
 758Likes
post #1411 of 4114 Old 02-10-2014, 11:10 PM
boxerfan88's Avatar
Hi folks, on the 3030 while playing FLAC files (16/44) how large a sonic difference do you find between "STRAIGHT" mode vs. "Pure Direct" mode?
RX-A3030 | Usher MD2 + Klipsch RB51 | Sony BDP-S5100 | HTPC
Zone 2 | Heco Victa 702
Zone 3 | Audiolab 8000A | Rogers LS6a
boxerfan88 is online now
post #1412 of 4114 Old 02-11-2014, 03:21 AM
dryasanne's Avatar
Quoted: 57 Post(s)
Liked: 25
Just get myself a 2030
The difference from my marantz 5006 is immensevily wast, why didnt I buy this earlier ??
There are some newebi q I dont fix.
- how do I play Pandora and Rhapsody
- how do I turn it on with Roomie remote
- how do I adjust tuner input so I can get my 2 subwoofers.
dryasanne is offline
post #1413 of 4114 Old 02-11-2014, 04:53 AM
WR1325's Avatar
Originally Posted by dm465531 View Post
I just came from theMarantz AV7005 and I must say the ease of use and all of the features the CXA-5000 provides make for a very enjoyable experience. For movies this pre sounds amazing like wise with music. I watched a little bit of Rush and the separationseparation between the channels was great. YPAO is equally amazing and easy to use. It was also much quicker than audessey. I am very happy with this purchase and would recommend any one sitting on the fence to get one.
Thanks, its good to know others really like the Yamaha, personally for some reason could never buy the Marantz
or Pioneer much as i like most Pioneer kit,
and definitely not the Denon either as they are usually so boring sounding
yeap still on the fence
but bought the Beast last night online, the "Yamaha P7000s Pro amp" (2x1000 into 4ohms or 1x2000w)
for a sub upgrade, could nt resist, should be here by the end of the wk,
if i don't get evicted for noise pollution i let folks know how it sounds
the CX-A5000 will have to wait just a little bit longer
enjoy the CX-A
WR1325 is offline
post #1414 of 4114 Old 02-11-2014, 06:42 AM
joeyvaz's Avatar
Quoted: 73 Post(s)
Liked: 30
I just set this receiver up for a friend last night. Sounds Good connected to his old school Infinity bookshelf speakers. I have a couple of questions to some issues I encountered. He is running a 5.1 setup in his main room, 2 bookshelf speakers in zone 2, and a Bose Acoustimas setup in zone 3. All wiring is correct. I used the setup on page 31 of the manual.
Issues:
#1. In zone 3, it seems as though no bass is going to the Bose setup. It sounds as if all bass is crossed over and out from that zone. ZERO bass going to the "sub" and just sound to the cubes. Wiring is 2 ch to the "sub" and then up to the cubes. He swore the sub worked before. So I wired into the main L/R to test. And sure enough, the sub "works" as well as it can. These are just being used for mood music in a sitting room.
***Put the receiver in Party Mode and get the same results in this zone-No Bass***
#2. His turntable is connected to the phono input on the receiver-and grounded. We get no sound coming out of it. Connected to his old Yamaha receiver, it works fine. I read in the manual on page 43 where it says something about the type of cartridge the turntable uses may determine if a boosting transformer is necessary. Any thoughts on whether this might be his issue? Never had to use a boosting transformer before.
joeyvaz is offline
post #1415 of 4114 Old 02-11-2014, 08:23 AM
kriktsemaj99's Avatar
Quoted: 659 Post(s)
Liked: 382
I suspect there would be no inherent difference at all, because Pure Direct is not really Pure Direct for FLAC files (the DSP is still involved because it has to decode the input stream to PCM).
Any difference you hear will be because Straight mode applies EQ and Pure Direct doesn't (plus there's no bass management in Pure Direct, so it's not a direct comparison with Straight unless you have all speakers set as Large). When the input signal has to be decoded, Pure Direct really just becomes a quick way to turn off EQ and bass management (which I suppose still might be useful to some people).
With PCM or DSD input, Pure Direct can send the signal directly to the DACs bypassing all processing, and that might be a more interesting comparison, but the main advantage of Pure Direct is probably to send a good quality analog input direct to the output section (bypassing DACs as well as processing).
kriktsemaj99 is offline
post #1416 of 4114 Old 02-11-2014, 11:12 AM
Ross Ridge's Avatar
Liked: 81
FLACs and anything else file played over the network or from USB is decoded by the ARM CPU that handles networking. If it were the DSP doing the decoding you wouldn't be able to hear network sources in zone 2. I'm not sure if the DSP get physically bypassed in Pure Direct mode when a network/USB source is used.
Ross Ridge is offline
post #1417 of 4114 Old 02-11-2014, 01:37 PM
Quoted: 659 Post(s)
Liked: 382
Good point, but I think it's probably true that Pure Direct does nothing special unless the source is analog (or maybe DSD). But it does serve as a quick way to see what your speakers sound like without EQ and/or bass management.
Edit: looking at the service manual for the A3000 (the latest I have), digital audio from the network processor (e.g. decoded FLAC) is converted to analog on the network board (DAC is a PCM1781). Then in Pure Direct mode it looks like it stays analog and bypasses the main DACs.
post #1418 of 4114 Old 02-11-2014, 03:59 PM
asharris7's Avatar
I just got the network adapter and updated firmware, all went smooth. One thing is though, that Pandora keeps getting disconnected (did that before firmware update too) Any thoughts? I'm using the App on my HTC one
asharris7 is offline
post #1419 of 4114 Old 02-11-2014, 04:53 PM
Bond 007's Avatar
Quoted: 2627 Post(s)
Liked: 2090
Does it say "access error"?
Licence to Kill
Bond 007 is offline
post #1420 of 4114 Old 02-11-2014, 04:57 PM
asharris7's Avatar
Yes, anything I can do?
post #1421 of 4114 Old 02-11-2014, 08:20 PM
Bond 007's Avatar
Liked: 2090
That used to happen to me a lot and still does from time to time. I didnt do anything special to fix it but its a fairly common problem.
Some people try resetting their router. Others try setting up a static ip address for the receiver.
Are you hardwired?
Licence to Kill
Bond 007 is offline
post #1422 of 4114 Old 02-11-2014, 09:34 PM
asharris7's Avatar
wireless adaptor
post #1423 of 4114 Old 02-11-2014, 09:38 PM
Bond 007's Avatar
Liked: 2090
wireless adaptor
If theres any way you can hardwire it that would be very beneficial.
Licence to Kill
Bond 007 is offline
post #1424 of 4114 Old 02-11-2014, 10:19 PM
marky301067's Avatar
Quoted: 61 Post(s)
Liked: 55
Excellent review of the CX-5000 & MX- A5000 in StereoPhile March issue.
Webmonkey likes this.
Dali: Epicon / Paradigm: Sub 1 / Plinius: Tautoro / SB301 / Toko / Anthem: MRX1120 / Oppo: 205 / JVC Dila: 950 / Apple: IpadProd 12.9 V2
marky301067 is offline
post #1425 of 4114 Old 02-11-2014, 10:50 PM
asharris7's Avatar
I would have to run it across the floor so that's a no go
post #1426 of 4114 Old 02-12-2014, 01:17 AM
Webmonkey's Avatar
Quoted: 60 Post(s)
Liked: 32
I am waiting for the online version, as I do not want to pay ~25$for a single magazine
Webmonkey is offline
post #1427 of 4114 Old 02-12-2014, 06:00 AM
DaveNY's Avatar
So I finally hooked up my A2030 yesterday evening. Right off the bat the speakers were louder with the new AVR than my old RX-V867, most likely because the A2030 has more juice than the 867.
One thing that surprised me was the video hookups, from everything I can see the maximum video inputs you can use is 7 regardless of whether they are hdmi, component, composite, etc. I am using 4 of the hdmi inputs and one of the component inputs, however I had to connect one of my devices to hdmi input '5' instead of '4' since the component inputs are only 1 through 4. It's hard to explain, basically there is no option to display component 1 input or hdmi 1 input if both inputs are in use, it is only 'av input 1' so you can't have an hdmi device and a component device connected to the same respective input number.
Took me a few minutes to figure it out but once I did everything worked fine.
DaveNY is offline
post #1428 of 4114 Old 02-12-2014, 10:28 AM
llang269's Avatar
Quoted: 55 Post(s)
Liked: 43
Hey Marky what did the review say? I tried to ask Kal earlier but that didn't go to well. I understand he has to sell magazines!
llang269 is online now
post #1429 of 4114 Old 02-12-2014, 01:06 PM
Kal Rubinson's Avatar
Quoted: 773 Post(s)
Liked: 542
Thank you.
??? Cover price is much less than $25.
I generally say more than I should but Stereophile has to sell magazines.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #1430 of 4114 Old 02-12-2014, 01:47 PM
llang269's Avatar
Quoted: 55 Post(s)
Liked: 43
Exactly and I have no problem with that. I guess my next question would be how does it compare to the krell foundation? In your opinion!
post #1431 of 4114 Old 02-12-2014, 01:50 PM
nsiret's Avatar
Quoted: 16 Post(s)
Just received my CX-A5000 today. Anyone have the IR codes in either text or Excel format to assist with programming my TSU-9400?
Nick
nsiret is offline
post #1432 of 4114 Old 02-12-2014, 03:31 PM
bwillcox's Avatar
Quoted: 484 Post(s)
Liked: 265
PM me with your email address and I can send you the codes that I got from Yamaha and then converted from their NEC (I believe they are) to the HEX codes used by Pronto remotes to use with my TSU-9600.
Bob
1) JVC DLA-X750, Yamaha CX-A5100, Outlaw Audio 7900 & 7700, Oppo UDP-203, Roku 4, Sony HAP-Z1ES
2) Sony XBR-75Z9D, Yamaha RX-A3070, 2xOutlaw Audio 2200s, Oppo UDP-203, Roku Ultra, Sony HAP-Z1ES
3) Sharp LC-70UH30U, Yamaha RX-A2050, Oppo BDP-103, Roku 4
bwillcox is online now
post #1433 of 4114 Old 02-12-2014, 04:56 PM
Quoted: 773 Post(s)
Liked: 542
My disclosure policy is unchanged.
Kal Rubinson
post #1434 of 4114 Old 02-12-2014, 04:57 PM
llang269's Avatar
Quoted: 55 Post(s)
Liked: 43
Uh ok!!
post #1435 of 4114 Old 02-12-2014, 05:28 PM
llang269's Avatar
Quoted: 55 Post(s)
Liked: 43
I think I'll just go to the bookstore flip to what I want to know and leave it at that!
post #1436 of 4114 Old 02-12-2014, 05:33 PM
David Susilo's Avatar
Quoted: 629 Post(s)
Liked: 590
Guys, please respect his stance. Just buy the magazine. If you are to cheap to buy a magazine to read what you need, then you should not be buying a pre-pro at all. mad.gif
Mad Norseman likes this.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is online now
post #1437 of 4114 Old 02-12-2014, 05:39 PM
llang269's Avatar
Quoted: 55 Post(s)
Liked: 43
I respect his stance and will do exactly what I just said. And thank you for telling me what to do with my cash!
post #1438 of 4114 Old 02-12-2014, 06:59 PM
kikkenit2's Avatar
Quoted: 823 Post(s)
Liked: 305
It's only $2,500. Just buy it already. Now some amps worth using it with. Big bucks!
http://www.amazon.com/Yamaha-CX-A5000BL-AVENTAGE-11-2-Channel-Pre-Amplifier/dp/B00DJ4BMG0
kikkenit2 is offline
post #1439 of 4114 Old 02-12-2014, 07:15 PM
llang269's Avatar
Quoted: 55 Post(s)
Liked: 43
Ok just a brief history. I had an integra dhc 80.3 and just sold it. So now I'm trying to decide between the cx-a5000, the Marantz 8801 and the krell foundation. I'll be pairing whatever I get with parasound halo amps! So money isn't the issue!!!
post #1440 of 4114 Old 02-12-2014, 07:19 PM
Bond 007's Avatar
Liked: 2090
Licence to Kill
Bond 007 is offline
Yamaha Aventage Rxa 1030 Receiver , Yamaha Rxa2030bl Aventage Home Theater Receiver , Yamaha Rxa3030bl Aventage Home Theater Receiver
