The "Official" Yamaha AVENTAGE RX-A1030, RX-A2030, RX-A3030 and CX-A5000/MX-A5000 Thread - Page 61 - AVS Forum | Home Theater Discussions And Reviews
 104Likes
post #1801 of 4090 Old 03-04-2014, 04:20 PM
wase4711's Avatar
Quoted: 165 Post(s)
Liked: 139
how does the 2030 compare to a marantz 6008?
thanks!
wase4711 is offline
post #1802 of 4090 Old 03-04-2014, 04:21 PM
Bond 007's Avatar
Quoted: 2552 Post(s)
Liked: 2014
The angle correction and upgraded DSP modes both sound like worthy considerations. Get the best one you can easily afford.
Licence to Kill
Bond 007 is offline
post #1803 of 4090 Old 03-04-2014, 06:09 PM
wse
wse's Avatar
Quoted: 2189 Post(s)
Liked: 797
Will the 1039 work with MMG MAGNEPAN 4 Ohm, 86db sensitivity speakers?
wse is offline
post #1804 of 4090 Old 03-04-2014, 06:19 PM
David Susilo's Avatar
Quoted: 619 Post(s)
Liked: 586
No it won't. The Magnepan impedance go below 2 ohms at certain frequencies, the receiver will go into protection mode.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #1805 of 4090 Old 03-04-2014, 06:20 PM
Chad Varnadore's Avatar
Liked: 52
Originally Posted by omiee View Post
Thank you for that, so in your opinion do you think it's worth the extra to get the 3030 over the 2030 or I wont even notice the difference? (this will be my first ht setup pairing with monitor audio silver 10's and an svs pb2000 if it makes a difference)
I'm guessing not, unless your speaker array requires angle correction. If it doesn't need angle correction (see next paragraph), I'd actually go so far as to wager you won't hear a difference, but it's just a guess. I went with the 3030 anyway, to play it safe, as I'm not only upgrading AVRs, I'm also trying to drop an external amp that I think is likely overkill for our HT. But I'm not familiar with your speakers other than the SVS - great subs! - and don't know enough about your room to offer any supposition as to your power needs - not that an extra 10 wpc will give you much more headroom. I tend to agree with the "get the best you can afford so you're not second guessing your decision later" line of thinking. Keeping in mind that you can get a 3030 for a lot less than SRP at many dealers; just don't try to buy one from a big box store like Best Buy or amazon for less than SRP.
From what I was told, the angle correction is primarily, if not solely, for compensating for non-ideal speaker placement. Like for example, you position your left surround ideally, but because of a door or window on the other wall, the right speaker has to be positioned higher, or forward or back more. If you're able to place the speakers symetrically, in the approximate ideal locations - which ideal placement depends on the speaker type and seating area - then the angle correction may not be as useful according to Yamaha tech support.
The Cinema DSP HD3 is supposed to expand the sound field vertically, but it may require front presence speakers. I'm not usually a fan of DSPs, but Yamaha is supposed to have some of the best, so I'm looking forward to hearing what they've come up with. I think their most celebrated dsps are included in both models.
It's actually the ESS dacs that separate these two models that I'm most looking forward to hearing, after the glowing review at Secrets. Everything I've heard about dacs tell me, there shouldn't be an audible difference though, at least not because of the bit depth, so we'll see.
Chad Varnadore <><
ex-armchair quarterback
Our HT
Chad Varnadore is offline
post #1806 of 4090 Old 03-04-2014, 06:22 PM
SoundChex's Avatar
Quoted: 365 Post(s)
Liked: 308
New Product Bulletins for some Yamaha 2014 low|mid-priced AVRs seen on the net:
[Home Office system schematic]
"My AV systems were created by man. They evolved. They rebelled. There are many speakers. And they have . . . A PLAN."
SoundChex is online now
post #1807 of 4090 Old 03-04-2014, 06:52 PM
MAGHUNTER's Avatar
Quoted: 28 Post(s)
Good to see built in wifi and included Bluetooth on the 777. I would assume all of the A lines will have both included?
MAGHUNTER is offline
post #1808 of 4090 Old 03-04-2014, 07:19 PM
kriktsemaj99's Avatar
Quoted: 648 Post(s)
Liked: 368
Originally Posted by SoundChex View Post
New Product Bulletins for some Yamaha 2014 low|mid-priced AVRs seen on the net...
"YPAO Volume" is new, and seems to be Yamaha's answer to Audyssey Dynamic EQ. Also HDMI 2.0 and built in WiFi, so probably more improvements this year than last year.
kriktsemaj99 is offline
post #1809 of 4090 Old 03-04-2014, 07:32 PM
Bond 007's Avatar
Liked: 2014
Sounds like more and more significant than last year. Sure "YPAO Volume" isnt the answer to "Dynamic Volume"?
Licence to Kill
Bond 007 is offline
post #1810 of 4090 Old 03-04-2014, 08:17 PM
wse
wse's Avatar
Liked: 797
Originally Posted by David Susilo View PostNo it won't. The Magnepan impedance go below 2 ohms at certain frequencies, the receiver will go into protection mode.
Will any AVR work with the Magnepan? Pioneer with their D3 amps?
wse is offline
post #1811 of 4090 Old 03-04-2014, 08:21 PM
wse
wse's Avatar
Liked: 797
Cool prices please are they also updating the Avantage
wse is offline
post #1812 of 4090 Old 03-04-2014, 10:49 PM
sdv5's Avatar
This is incorrect. Magnepan MMG presents a stable resistive load of 4 Ohms to the amplifier. It will work perfectly well with Yamaha receivers, and you can get get decent volume especially if you cross over to the sub at 80 Hz. Speaking from first hand experience. Leave the Yamaha at 8 Ohm setting and ignore the manual to make adjustments for 6 Ohm speakers. Never had the receiver (RX-A830) go into protection mode even when driving a 5.1 all Maggie set-up with MG1.6 for front speakers. Yes, it will play louder if you connect an external power amp and use Yamaha as a pre-pro only.
sdv5 is offline
post #1813 of 4090 Old 03-04-2014, 10:54 PM
sdv5's Avatar
The majority of AVRs will work just fine with Magnepan speakers especially if you have a subwoofer and you set the cross over frequency to 80 Hz. Yamaha Aventage, Pioneer Elite, Anthem, etc., have all been used with Magnepan speakers even though only Pioneer Elite is specifically listed as supporting 4 Ohm speakers. Again, if you have a sub in your HT set-up, you will reduce the burden on your AVR and Magnepan speakers considerably.
sdv5 is offline
post #1814 of 4090 Old 03-05-2014, 05:57 AM
Quoted: 648 Post(s)
Liked: 368
Despite the name, it seems to do what Dynamic EQ does ("automatically adjusts the high and low frequency levels so that you hear natural sound at any volume"). They don't say it boosts surround levels at lower volumes, but that Audyssey Dynamic EQ feature is somewhat controversial anyway.
post #1815 of 4090 Old 03-05-2014, 06:06 AM
Bond 007's Avatar
Liked: 2014
What would be the difference between YPAO Volume and Adaptive Dynamic Range Control?
Licence to Kill
Bond 007 is offline
post #1816 of 4090 Old 03-05-2014, 06:31 AM
jamweiser's Avatar
Have a general question/seeking to hear opinion's of yamaha owner's... Looking to upgrade from my onkyo tx-sr606, and the two yamaha's i'm looking at are the 1030 or 2030. The 9 channels aren't needed, but the sub eq is what attracts me to the 2030. If i go with the 1030, i'll add an Anti-mode 8033...
What would be the advantages of the 2030 vs the 1030 with the Anti-mode 8033?
The other receiver i've looked at, at a local shop is the Anthem mrx 510.
My speakers are Polk M60 series II, Polk CS2, some old JBL book shelf speakers for surround, and a PSA XV15.
The reliability of yamaha is what has stirred interest in these receivers...
PSN= Jamweiser
jamweiser is offline
post #1817 of 4090 Old 03-05-2014, 07:07 AM
wse
wse's Avatar
Liked: 797
Great I looked at their web site they are the only one to show 8/6/4/2 ohm data
wse is offline
post #1818 of 4090 Old 03-05-2014, 07:16 AM
wse
wse's Avatar
Liked: 797
Interesting!
wse is offline
post #1819 of 4090 Old 03-05-2014, 07:29 AM
smitty8451's Avatar
Quoted: 64 Post(s)
Liked: 87
Although I don't run a Yamaha AVR as my primary unit, I do have the CX-A5000 prepro and I do run 2 Antimode units (1 per channel to 2 Rythmik DIY 15" sealed subs). I used the antimode units not because YPAO could not EQ my subs but because I have a horrible room acustic wise and the WAF is not going to let me do any sound treatments. So as a compromise the wife went with me trying out the antimode units and it made a huge difference in elimiating some nasty peaks. I would go with the 2030 and try it and if your room needs further eq'ing then add the antimode unit(s). the antimode 8033 units are specifically designed for subs and only subs so they will only help not hinder what YPAO does as far as eq'ing your subs. Just remember to run the antimode calibration first, then run YPAO, and last but not least use an SPL meter to get everything leveled out. It made a night and day difference in my setup but YMMV.
Yamaha CX-A5000, ATI AT 2007 Amp, ATI AT 2004 Amp, Klipsch La Scala II- Main, RB 61's - Front heights, RC-62 - Center, RS-62's - Surround, RS-52's - Rear Surround, 2 Rythmik DS-1510 DIY Subwoofers each connected with Antimode Dual Core 2, Oppo BDP-95, MMF-7.1, Project Phono Box RS, XBox 360, XBox One, Oppo HA-1, TEAC PD-501HR transport, Atech Fabrication 7000 fanless HTPC and TASCAM DA-3000 SS Recorder, Kramer VS-88A Matrix Switch, Rogue Audio Pharaoh Int amp, Sony HAPZ1-ES
smitty8451 is offline
post #1820 of 4090 Old 03-05-2014, 07:56 AM
Quoted: 648 Post(s)
Liked: 368
YPAO Volume doesn't appear to do any dynamic range reduction. It sounds more like the old "loudness button" you used to see (except that it dynamically increases its effect as the volume is turned down, it's not just on or off).
Adaptive DRC really is compressing the dynamic range as you turn down the volume. Yamaha still doesn't have anything directly equivalent to Dolby Volume or Audyssey Dynamic Volume, but Adaptive DRC should produce a similar effect because reducing dynamic range naturally reduces the difference between loud and quiet program material (e.g. between a TV show and obnoxiously loud commercials).
post #1821 of 4090 Old 03-05-2014, 08:56 AM
HDTVAV's Avatar
Quoted: 760 Post(s)
Liked: 343
Awesome, awesome, awesome!
Finally, an HDMI 2.0 AVR!!!
I may not have to wait as long as I thought!
Any idea as to when the new Aventage flagship AVRs will be coming out...?
Samsung 78 HU9000 or LG 79/84 UB9800 or Sony XBR-75X940C (2015)
Panasonic 65VT60
Panasonic 65VT25
Pioneer Elite SC-37
Pioneer Elite BDP-09FD
HDTVAV is offline
post #1822 of 4090 Old 03-05-2014, 09:14 AM
wse
wse's Avatar
Liked: 797
Originally Posted by HDTVAV View Post
Awesome, awesome, awesome! Finally, an HDMI 2.0 AVR!!!
I may not have to wait as long as I thought! Any idea as to when the new Aventage flagship AVRs will be coming out...? smile.gif
wse is offline
post #1823 of 4090 Old 03-05-2014, 09:27 AM
Oppo Beta Group
RichB's Avatar
Quoted: 1000 Post(s)
Liked: 660
The V77VT says this:
The latest HDMI version support for 4K 50/60p input
but does not say HDMI 2.0.
- Rich
Oppo UPD-205 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 | ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is offline
post #1824 of 4090 Old 03-05-2014, 10:10 AM
Quoted: 648 Post(s)
Liked: 368
4Kp60 implies HDMI 2.0, unless they are being deliberately misleading.
post #1825 of 4090 Old 03-05-2014, 10:36 AM
Liked: 52
From what I've read, the antimode will likely do a better job with low frequencies than YPAO. But I believe the difference between the 2030 and 1030 is still substantial in other areas. One reviewer likened the 1030 more toward the lower end 830 than the 2030. I don't remember how that was qualified, exactly, but I know the 2030 is a dual dac design like the 3030, where the 1030 uses a single dac. I pretty much stopped comparing them after that point.
Chad Varnadore <><
Our HT
post #1826 of 4090 Old 03-05-2014, 12:35 PM
Oppo Beta Group
RichB's Avatar
Liked: 660
or careful, if they have not been fully tested to meet the spec.
- Rich
RichB is offline
post #1827 of 4090 Old 03-05-2014, 12:39 PM
HDTVAV's Avatar
Quoted: 760 Post(s)
Liked: 343
- Rich
My understanding is that they haven't even finalized the specs for HDMI 2.0 yet...
:confused:
Panasonic 65VT60
Panasonic 65VT25
Pioneer Elite SC-37
HDTVAV is offline
post #1828 of 4090 Old 03-05-2014, 01:02 PM
wse
wse's Avatar
Liked: 797
Doo you have data showing that MMG go bellow 2 Ohms
wse is offline
post #1829 of 4090 Old 03-05-2014, 02:28 PM
dsinger's Avatar
Quoted: 316 Post(s)
Liked: 320
- Rich
IMO, 2014 for both AVRs and 4k TVs is a year for the buyer to beware and do their homework. Apparently there is more than one version of the HDMI 2.0 spec that was released in 9/13. The release info said a 18.3 gbit thru put . However, if you check the detail spec for Sony's top of the line 4k TV (950B) you will find that after 3820x2160p60 input it says 10.2 gbit 4:2:0 8 bit color. I call this HDMI 2.0 "Lite".
dsinger is offline
post #1830 of 4090 Old 03-05-2014, 02:48 PM
Oppo Beta Group
RichB's Avatar
Liked: 660
- Rich
RichB is offline
Yamaha Aventage Rxa 1030 Receiver , Yamaha Rxa2030bl Aventage Home Theater Receiver , Yamaha Rxa3030bl Aventage Home Theater Receiver
