The "Official" Yamaha AVENTAGE RX-A1030, RX-A2030, RX-A3030 and CX-A5000/MX-A5000 Thread - Page 79 - AVS Forum | Home Theater Discussions And Reviews
 103Likes
post #2341 of 4066 Old 04-26-2014, 01:19 PM
mfahnestock's Avatar
Originally Posted by Bond 007 View Post
To be honest I dont understand what advantage that is to just having 2 conventional setups. I guess you could save money by not buying 2 bluray players or something. But it sounds like you know what youre doing. Good luck.
pretty much. the main setup is located with the rest of the equipment, so i use the fios box and blu-ray for outdoor as well as indoor. basically trying to avoid extra boxes if i can. with the a/v receivers having extra hdmi outputs i am trying to avoid using an hdmi matrix the way i do today.
mfahnestock is offline
post #2342 of 4066 Old 04-26-2014, 03:31 PM
Bond 007's Avatar
Quoted: 2371 Post(s)
Liked: 1907
The BDP can only play one thing at a time so youll have to watch the same thing in both rooms. Same with the fios box. Or you could watch the BDP in one room and the fios box in the other. Seems like quite a sacrifice just limit yourself on boxes. You can buy a wifi BDP for $50 nowadays and that would open up some options. Or am I wrong?
Licence to Kill
Bond 007 is offline
post #2343 of 4066 Old 04-26-2014, 04:43 PM
For the most part, it's TV in one room and a Movie in another typically or same source. I've been using an Oppo player and didn't see buying 2 of them.. I'm cheap that way. biggrin.gif
post #2344 of 4066 Old 04-27-2014, 12:13 PM
goldielox's Avatar
Originally Posted by Jim Golden View Post
I've found that the "flat" setting is the least "bright."
I blame this on adaptive DRC. You guys are right! Flat is more bright. Somehow when I ran my setup last, it initiated adaptive DRC, which was negatively impacting my overall sound. I have since turned it off and am more happy with my results.
goldielox is offline
post #2345 of 4066 Old 04-28-2014, 02:22 PM
PinMonkey10's Avatar
RX-A3030 Zone 2 setup question.  I'm running my Zone 2 to a pair of Definitive Outdoor speakers.  Any tips on making them sound better at low to moderate volumes?  They seem to be lacking bass on zone 2, I even have the bass to +10.  You have to really crank the volume up to make them sound great, but then they are way to loud for a residential situation.
Before buying this receiver I was running them with a old yahama 5.1 receiver and was using them in stereo mode and they sounded awesome, very crisp and full of bass at moderate listening levels.
Is it safe to assume most zone 2 receivers are not that great for outdoor speakers?
My main zone sounds awesome, but I'm just not to happy with Zone 2 performance.
PinMonkey10 is offline
post #2346 of 4066 Old 04-28-2014, 02:54 PM
jdsmoothie's Avatar
Quoted: 12093 Post(s)
Liked: 5503
If you still have the old 5.1 AVR, consider connecting the Zone 2 pre-outs to it and using it again.
jdsmoothie is online now
post #2347 of 4066 Old 04-30-2014, 05:39 AM
boxerfan88's Avatar
What's the experience like streaming 24b/96kHz FLAC files to the RX-A3030?
I have been struggling with 24b/96kHz FLAC file streaming. The RX-A3030 intermittently stutters, or goes silent for a few secs, or just skips to the next track. Occasionally, it will succeed in playing the entire track. No specific pattern, it can fail on any of the 17 tracks. Have tried 2 different DLNA servers -- Serviio & Kooraroo, same issue. I am starting to think it is a problem with the RX-A3030.
No problems at all with standard 16b/44.1kHz tracks using either of the above DLNA servers. I am stumped.
RX-A3030 | Usher MD2 + Klipsch RB51 | Sony BDP-S5100 | HTPC
Zone 2 | Heco Victa 702
Zone 3 | Audiolab 8000A | Rogers LS6a
boxerfan88 is online now
post #2348 of 4066 Old 04-30-2014, 06:33 AM
bwillcox's Avatar
Quoted: 352 Post(s)
Liked: 169
I don't have any problems streaming 96kHz/24bit or 192kHz/24bit FLAC files to any of my Aventage AVRs (1030, 2030, & 3030) or my CX-A5000. It sounds to me like your bandwith may not be sufficient. How is your 3030 and DLNA servers connected? Note that I use a NAS box as my DLNA server. A Netgear ReadyNAS 316, not a PC though.
Bob
1) JVC DLA-X750, Yamaha CX-A5100, Outlaw Audio 7900 & 7700, Oppo UDP-203, Roku Ultra, Sony HAP-Z1ES
2) Sony XBR-75Z9D, Yamaha RX-A3050, 2xOutlaw Audio 2200s, Oppo UDP-203, Roku 4, Sony HAP-Z1ES
3) Sharp LC-70UH30U, Yamaha RX-A2050, Oppo BDP-103, Roku 4
bwillcox is offline
post #2349 of 4066 Old 04-30-2014, 04:38 PM
boxerfan88's Avatar
Connection is via gigabit switch (1 hop). Almost sure the problem is with the RX-A3030. I did a "INITIALIZE ALL" and reloaded the configuration, problem went away!
post #2350 of 4066 Old 05-01-2014, 08:28 AM
bwillcox's Avatar
Quoted: 352 Post(s)
Liked: 169
I have noticed that if I set my Yamaha AVRs to the quick start mode (I don't recall the actual name, but where they keep the network up), that after a few days they no longer can access the network reliably. I suspect that there's a problem when they attempt to stay online all the time with stuff that they 'see" on my network.
Bob
bwillcox is offline
post #2351 of 4066 Old 05-01-2014, 08:31 AM
Bond 007's Avatar
Liked: 1907
Network Standby. Thats a common problem.
Licence to Kill
Bond 007 is offline
post #2352 of 4066 Old 05-02-2014, 01:54 AM
boxerfan88's Avatar
Hmm...interesting. I do keep the AVR on network on when standby (so that I can switch it on using the iPhone app). So I guess it is not a hardware fault? (my warranty ending in 6 months). I notice this problem occurs between 5-7 weeks after the last INIT ALL/reload config, once it happens the fault is permanent for DLNA streaming.
Is there a workaround such that I do not need to INIT ALL/reload config to recover?
Maybe at the next occurrence, I need to try AC Power OFF/ON, and see if it recovers. May also try pulling out the network cable & reinsert. Will update then...
Thanks all.
post #2353 of 4066 Old 05-02-2014, 06:49 AM
smitty8451's Avatar
Quoted: 63 Post(s)
Liked: 86
Thanks all.
Funny. You guys mentioned this, I have had the same issue a couple of times, I just pull power from my Cx-a5000, plug her back in and she's good to go. I'm an IT tech, and I think it maybe due to a network time out issue. Hope yamaha issues a firmware update to fix this issue in the future.
Yamaha CX-A5000, ATI AT 2007 Amp, ATI AT 2004 Amp, Klipsch La Scala II- Main, RB 61's - Front heights, RC-62 - Center, RS-62's - Surround, RS-52's - Rear Surround, 2 Rythmik DS-1510 DIY Subwoofers each connected with Antimode Dual Core 2, Oppo BDP-95, MMF-7.1, Project Phono Box RS, XBox 360, XBox One, Oppo HA-1, TEAC PD-501HR transport, Atech Fabrication 7000 fanless HTPC and TASCAM DA-3000 SS Recorder, Kramer VS-88A Matrix Switch, Rogue Audio Pharaoh Int amp, Sony HAPZ1-ES
smitty8451 is offline
post #2354 of 4066 Old 05-02-2014, 09:11 AM
bwillcox's Avatar
Quoted: 352 Post(s)
Liked: 169
Yeah, my A5000 does it to. Since I don't use a fondleslab to control/turn on my equipment, all disabling Network Standby does to me is make the power on startup a bit slower.
Bob
bwillcox is offline
post #2355 of 4066 Old 05-02-2014, 09:34 AM
smitty8451's Avatar
Quoted: 63 Post(s)
Liked: 86
BWilcox
Did your unit do this when you first got it or has it had the problem after the last firmware update in Jan? The reason I ask is I don't recall mine haveing issues until recently, but then again I don't stream from my NAS everytime I use it. I want to get ahold of Yamaha support and give them some other owner inputs. Other owners of the CX-A5000 who provide there experiences with this problem would help me give them some solid facts.
post #2356 of 4066 Old 05-02-2014, 11:39 AM
kokishin's Avatar
Quoted: 799 Post(s)
Liked: 486
Possibly a DHCP renew lease issue?
Try setting a static IP address in the AVR.
My signature:
Link: avsforum Members Atmos & Auro Configuration Spreadsheet
I'm just a caveman. Your modern world frightens and confuses me.
kokishin is online now
post #2357 of 4066 Old 05-02-2014, 12:59 PM
bwillcox's Avatar
Quoted: 352 Post(s)
Liked: 169
BWilcox
It did it right from the start, as did my A1030, A2030, & A3030. So it seems to be common problem in there firmware.
Bob
bwillcox is offline
post #2358 of 4066 Old 05-02-2014, 01:09 PM
bwillcox's Avatar
Quoted: 352 Post(s)
Liked: 169
Not sure what DHCP would have to do with this (the failure occurs while the device is off...in standby). Also, all of my AVRs do have static IP addresses.
Bob
bwillcox is offline
post #2359 of 4066 Old 05-02-2014, 01:23 PM
smitty8451's Avatar
Quoted: 63 Post(s)
Liked: 86
I'm with BWilcox on this one, my unit has a static IP as well and allways has. I even went further and created a DHCP reservation in my switch (wich has Level 3 routing) for that particular IP so i am pretty sure the IP is not getting used by another device on my network. My theory is the Yamaha's have a very short "keep alive" broadcast signal when in standbye mode so connectivity becomes inconsistant over a period of time. Further evidence is that when I power cycle my unit it will work flawlessly which leads me to believe that power cycling reboots the network functionality and hence all is good again. I am pretty sure this is something that can easily be rectified by a firmware update, so now off to go bug Yamaha support for a bit.
P.S. Still love this unit and would recommend it to anybody.
post #2360 of 4066 Old 05-02-2014, 02:39 PM
kokishin's Avatar
Quoted: 799 Post(s)
Liked: 486
My theory was by having a static IP address, as opposed to a DHCP address or a reserved DHCP address (which is not the same as a static IP address), the AVR would not have to renegotiate the DHCP address with the router should the DHCP lease expire while the AVR is in standby mode. There was a comment that power cycling the AVR corrected the issue (at least for a while), which made me think that the AVR was getting assigned a DHCP address during boot up. Someone commented that after a week, the problem returned which might be the time frame when the DHCP address was renewed. Anyway, just trying to help.
My signature:
post #2361 of 4066 Old 05-02-2014, 07:23 PM
Rando235's Avatar
My 3030 has the stuttering problem streaming 96/24 or 192/24 .flacs from my QNAP NAS, but these days I have the Oppo BDP-103D do that. It doesn't have a problem with it and has a prettier UI. Might be interesting to see if the problem also occurs on the 3030 with the same files on a USB stick but have never tried it.
Rando235 is offline
post #2362 of 4066 Old 05-03-2014, 12:48 AM
pchain's Avatar
Quick question: I'm am deciding between the a1030 and the a2030. I am running a 5.1 system and probably won't go beyond it any time soon.
I am running
Polk RTi12 fronts
Polk CSi5 center
Polk PSW505 sub
Polk FXi3 surrounds.
I don't run audio or video to a separate room.
I have a medium size room with 12 foot ceilings.
The primary question is whether the a1030 has enough power to feed the whole 5.1 system or would the extra power with the a2030 be better? I have heard that more power will give better dynamic detail at lower/mid volume and more "headroom.". (not even sure what that means).
pchain is offline
post #2363 of 4066 Old 05-03-2014, 08:45 AM
kriktsemaj99's Avatar
Quoted: 636 Post(s)
Liked: 357
There's not much difference in power between the 1030 and 2030, but a lot of other differences. e.g. only the 2030 will give you individual crossovers and EQ the subwoofer.
kriktsemaj99 is offline
post #2364 of 4066 Old 05-03-2014, 09:31 AM
pchain's Avatar
would my speakers sound any better using the a2030 over the a1030?
pchain is offline
post #2365 of 4066 Old 05-03-2014, 09:52 AM
PretzelFisch's Avatar
Quoted: 396 Post(s)
Liked: 262
That depends on how much better the calibration and sub eq on the 2030 is over the 1030, otherwise they are pretty much the same unit. I have a 2030 and 820 I don't seem much difference sq wise. Now Aventage vs the HTR 7065 I think there is a difference.
PretzelFisch is offline
post #2366 of 4066 Old 05-03-2014, 09:58 AM
Mad Norseman's Avatar
Liked: 101
I am running
Polk RTi12 fronts
Polk CSi5 center
Polk PSW505 sub
You'll notice no difference in the power output between those two, but the 2030 has some other better features (DAC, etc.) that make it worthwhile.
Get the 2030 and pair it with a powerful external 5-channel amplifier (like the Emotiva XPA-5 at 200w x 5), and don't worry about having too little power again! tongue.gif
The Insane Pink Care Bear's Home Theater Set Up:
Marantz AV 8801 Processor, Emotiva XPR-5 Amplifier, Panasonic 65" ST30 Plasma, Yamaha BD-S2900 Blu-ray, Yamaha CDC-697 CD Player, Yamaha TT-500U Turntable, w/Signet TK5e, JBL ES100 Fronts, JBL LC2 Center, JBL ES30 Surrounds & 2 JBL ES250P Subwoofers
Mad Norseman is offline
post #2367 of 4066 Old 05-03-2014, 09:58 AM
pchain's Avatar
Thank you for your replies! I'm primarily looking to get the most out of my RTi12s, and it looks like instead I'd spending $400 more on the a2030 over the a1030 I should probably get the a1030 and a good used amp. It would be very cool to equal my sub.... Hmmmm....
pchain is offline
post #2368 of 4066 Old 05-03-2014, 11:05 AM
psychobrew's Avatar
Liked: 30
I would listen to the amp in those Aventage receivers before buying an external amp. You are paying a lot of money for the amp in the receiver and unless you really need more power an external amp may not bring anything to the table.
Samsung PN50C7000
Yamaha RX-V775WA
BIC Venturi DV64 Towers
BIC Venturi DV62 CLRs Center
Still building but sounds amazing so far
psychobrew is offline
post #2369 of 4066 Old 05-03-2014, 11:08 AM
phannon's Avatar
Quoted: 14 Post(s)
Liked: 24
Hey Guys,
I am in the process of installing my new A1030 (replaces an older RX 861) and have a question about one of the settings. In the HDMI set up section, there is a selection under AUDIO OUTPUT: AMP - "enables / disables the audio output from the speakers and headphones connected to the unit" ..choices OFF or ON (default). I am using the unit as a preamp and sending the signal to various separate amplifiers and this sounded, to me, like a setting to turn off the internal amps, but setting the option to OFF mutes all the sound from the preamp outs. Also, no speaker diagram shows up in the display when OFF. What is the purpose of this option, does it just have something to do with HDMI only?...there is no clear explanation (!!??) in the manual, unless I missed something.
With the setting set to ON, the sound works...I am off now to start the level balancing....
I took a day or so to go through all the settings and set ups (renaming, figuring out inputs, etc.) so basically all that is remaining is to set the levels.....though I am sure there will be a few unexpected items show up!
By the way, I am not impressed with this new concept of not supplying real paper manuals. The download PDF's are fine, but I still find it easier to have a manual (book) in front of me rather than going to a computer......the curse of being an old (newly retired though, one advantage!) guy.
Cheers,
P.E.H.
phannon is offline
post #2370 of 4066 Old 05-03-2014, 12:16 PM
Quoted: 636 Post(s)
Liked: 357
Audio output should be Amp=On for the 1030 to reproduce the sound (whether you're using speaker outs or preamp outs). You can set Amp=Off when audio output is On for one of the HDMI outputs (so sound will be reproduced by the connected HDMI device, such as a TV).
Yamaha Aventage Rxa 1030 Receiver , Yamaha Rxa2030bl Aventage Home Theater Receiver , Yamaha Rxa3030bl Aventage Home Theater Receiver
