The "Official" Yamaha AVENTAGE RX-A1030, RX-A2030, RX-A3030 and CX-A5000/MX-A5000 Thread - Page 94 - AVS Forum | Home Theater Discussions And Reviews
 758Likes
post #2791 of 4114 Old 07-02-2014, 12:45 AM
JKR1963's Avatar
Quoted: 249 Post(s)
Liked: 109
Originally Posted by Craig Mecak View Post
What of the ealier models which are virtually identical except for the addition of extra streaming audio features etc. Like The RX-A3020 or the RX-V3073 models? Even these have 11.2 capability, and might also have the required horsepower to do Dolby ATMOS in some capacity. Not to mention the 4K 50p/60p 4:2:0 mentioned above.
I do know that none of the old models will be ATMOS capable because they would need new hardware. I am not even sure what the HDMI Upgrade means...or how it will help .........what will I switch that will need HDMI 2.0......the only thing I know of at this time is likely a forthcoming 4K Blu ray format at 60 HZ....(some tv or concerts likely.....maybe a new 4K cable box signal).
But there is no guarantee that any of the new 2014 HDMI 2.0 receiver's will meet the spec's needed to switch a 4K Blu ray signal. There are also no guarantee's that the current 4K "UHD" TV's coming out will be able to play the 4K Blu ray either..........I am not sure if the panels will meet the necessary spec's to do it. My main interest for 4K would be to get movies that I can buy .....disc's with the best quality...........this is my interest and likely only need and reason to discuss any newer HDMI Connections or 4K TV'S.........and the truth is very vague at this time.
If there turns out to be no 4K Blu ray ..........I'm not even sure I need anything beyond HDMI 1.4.
Having said all of this......I ordered a Yamaha RX-V1075 (same as the 1030) for $699. from Future Shop today. It will serve as a backup receiver........may sell my Denon AVR-3808 that is in the family room...
I had already bought one of these last January but took it back because the display window was all scratched up.............a first for the 6 or so Yamaha receivers that I have bought in the past.....850, 992, 2095, 3800, 1900......659 etc.
JKR1963 is offline
post #2792 of 4114 Old 07-02-2014, 02:52 AM
JohnHWman's Avatar
Hello,
This RX-A3040 amplifier looks promising for my old Z11 (in 10.2 B&W speakers config.) replacement.
Quick question : according to the specifications listed inside the user manual, the rear presence speakers amplifier power is not listed. Does it means that there is no power Amp section inside the unit for these rear speakers wiring in 9.2+2 channel system configuration ?
John
Home theater enthusiast for over 20 years !
My dedicated HT room !
JohnHWman is offline
post #2793 of 4114 Old 07-02-2014, 05:10 AM
tyreman's Avatar
Would I be correct in assuming that my RX-V1075 is basically a RX-A1030?
Specs,features seem awfully similar.
tyreman is offline
post #2794 of 4114 Old 07-02-2014, 07:15 AM
JKR1963's Avatar
Quoted: 249 Post(s)
Liked: 109
Yup........seems to be a Canadian Model and not available in the US.
JKR1963 is offline
post #2795 of 4114 Old 07-02-2014, 07:34 AM
tyreman's Avatar
Thanks I will now watch this forum and call Home for my receiver
Doesn't seem to be any other dedicated threads for the RX-V1075.
tyreman is offline
post #2796 of 4114 Old 07-02-2014, 09:19 AM
bwillcox's Avatar
Quoted: 484 Post(s)
Liked: 265
I did a bit of a test this morning with my CX-A5000 streaming some 5.1 channel flac files to it via my DLNA server. What I discovered was that it only played them using two channels. I'm not certain, but it sounded like it simply dropped all of the other channels.
To confirm that this is happening in the CX-A5000 (and not my DLNA server), I then played the same tracks using my Oppo BDP-103D via the DLNA server and it played them with all 5.1 channels.
Have others experienced this? Is it a limitation of the flac DLNA support in the prepro, or have I just failed to set some configuration setting to allow it to play all of the channels in the stream?
bwillcox is online now
post #2797 of 4114 Old 07-02-2014, 11:28 AM
mjmcmahon67's Avatar
Quoted: 167 Post(s)
Liked: 61
Originally Posted by mjmcmahon67 View Post
Hey all -
still getting my RX-A3030 setup but I've tripped across something that doesn't make a lot of sense so I'm hoping others may be able to provide guidance. We're watching America's Got Talent on DirecTV tonight and typically we'll get LFE output. The Information page does show that the Subs are supposed to be getting output but we're only getting sporadic output. The subs (Velodyne 10 and Martin Logan 700W) are going in and out of standby. Thoughts?
Crossover is set to 80 for the Center and surrounds. I have my B&W 683S2's set to Large with 'Extra Bass' enabled - I believe that this should send output to both the 683's and the subs. PEQ is set for YPAO: Natural. I expect that I'll bump the output for the sub freq's, but not being familiar with setting a Parametric EQ, I've been hesitant to go too far with those settings.
Thx,
Mike
Any input folks? Can't figure out why I'm getting so little bass response.
mjmcmahon67 is offline
post #2798 of 4114 Old 07-02-2014, 12:53 PM
andymusicvideo's Avatar
Hi,
I am a frustrated Denon receiver owner who is thinking of buying the Yamaha 1030 in the next few weeks. The reason I am writing on this thread, is to find out if anyone has had any HDMI board problems with the Yama 1030 receiver or that line?
The reason I am getting rid of the Denon receiver, is because I had to get the HDMI board replaced TWICE within three years of use. I even contacted Denon support and they (DENON) unofficially told me - avoid using the HDMI connections and use the other inputs/outputs instead. Can you believe that? They know their HDMI boards are garbage and will shortly fail.
anyway, I do not know if Yamaha uses the same HDMI boards and if that is a problem with the Yama 1030? One of the authorized Denon service center techs I talked to vie telephone said "all HDMI connections stink" - all of them - does not matter what brand you get.
thanks
andymusicvideo is offline
post #2799 of 4114 Old 07-02-2014, 01:04 PM
JKR1963's Avatar
Quoted: 249 Post(s)
Liked: 109
Originally Posted by andymusicvideo View Post
Hi,
thanks
But it does make a difference........Onkyo puts their HDMI Boards in an OVEN !!
Which Denon did you have?? It seems like Yamaha has a lower failure rate then other brands, but my Denon AVR-3808 has not had any issues in 7 yr's.
JKR1963 is offline
post #2800 of 4114 Old 07-02-2014, 01:06 PM
Is it good that ONKYO puts them in an oven?
Your 7 year old Denon has HDMI? were you using HDMI's the entire 7 years?
post #2801 of 4114 Old 07-02-2014, 01:11 PM
kriktsemaj99's Avatar
Quoted: 660 Post(s)
Liked: 382
When the signal from the receiver to the sub stays below a certain level for a period of time, the sub is going to turn itself off if it's in auto mode. The Yamaha sub output has a lower voltage than some receivers, so when playing at a fairly low volume the sub may just decide to turn itself off. Two possible fixes:
1. Set the sub to stay on, rather than using auto-on (not all subs have this setting).
2. Turn up the sub level trim in the receiver (to somewhere closer to the +10dB max than it is now) and turn down your sub's gain knob to offset the level increase. Now the signal from the receiver will be higher at any given volume setting, and the sub may stay on.
kriktsemaj99 is offline
post #2802 of 4114 Old 07-02-2014, 01:11 PM
Im so frustrated with Denon, that I would not even consider Marantz, which is supposed to be better version of the same brand. Denon customer support was great - they repaired the boards twice for free, I was only out the cash to ship it twice to an authorized repair center. But - I should not have to deal with all that crap.
I need a clean change to a different company - Yamaha was my conclusion after some internet research. But I am not sure about Yama HDMI board reliability. Thats why I am asking about it.
post #2803 of 4114 Old 07-02-2014, 01:15 PM
Quoted: 167 Post(s)
Liked: 61
1. Set the sub to stay on, rather then using auto-on (not all subs have this setting).
2. Turn up the sub level trim in the receiver (somewhere closer to the +10dB max than it is now) and turn down your sub's gain knob to offset the level increase. Now the signal from the receiver will be higher at any given volume setting, and the sub may stay on.
Thanks kriktsemaj99 - I don't know that it's as much of a case of the subs having insufficient level trim as no signal being sent to the subs? I got signal during a commercial, but then it seemed to disappear again once the program started. Settings changes on the receiver didn't seem to make a difference.
One other thing I found a bit odd was that the SPL at the receiver's reference level was only showing about 65db using my SPL meter at the listening location. Any suggestions on that?
post #2804 of 4114 Old 07-02-2014, 01:19 PM
Quoted: 167 Post(s)
Liked: 61
Andy -
I came from a HDMI-failed Onkyo and had tried a Denon but wasn't happy with it. I chose the Yamaha RX-A3030 for those very same reasons.
Hope this helps,
Mike
post #2805 of 4114 Old 07-02-2014, 01:52 PM
JKR1963's Avatar
Quoted: 249 Post(s)
Liked: 109
I know I would not want to be in an oven........oven not good !!
Denon HDMI 7 years yes .......... I bought it at A&B Sound about May 2007 and it is still in use in my small family room system.
JKR1963 is offline
post #2806 of 4114 Old 07-02-2014, 02:11 PM
WetCoaster's Avatar
FWIW I have the same issue on my 1030, the signal cuts off every 2-3 seconds. I have tried USB etc and it still fails!
WetCoaster is online now
post #2807 of 4114 Old 07-02-2014, 02:15 PM
bwillcox's Avatar
Quoted: 484 Post(s)
Liked: 265
This doesn't sound quite like what I am hearing. My signal never cuts off, it's just that the CX-A5000 only plays the front two channels of a 5.1 surround mix. All the other channels are missing.
post #2808 of 4114 Old 07-02-2014, 02:24 PM
smitty8451's Avatar
Quoted: 64 Post(s)
Liked: 87
Bwillcox
On page 75 of the users manual it states
"- the unit supports playback of WAV (PCM format only), MP3, WMA, MPEG-4, AAC and FLAC files (1- or 2-channel audio only)"
Its in the bullet notes right at the beginning of "Playing back music stored on media servers (PC/NAS)"
I tried doing the same thing with the same results
Hope this helps
Yamaha CX-A5000, ATI AT 2007 Amp, ATI AT 2004 Amp, Klipsch La Scala II- Main, RB 61's - Front heights, RC-62 - Center, RS-62's - Surround, RS-52's - Rear Surround, 2 Rythmik DS-1510 DIY Subwoofers each connected with Antimode Dual Core 2, Oppo BDP-95, MMF-7.1, Project Phono Box RS, XBox 360, XBox One, Oppo HA-1, TEAC PD-501HR transport, Atech Fabrication 7000 fanless HTPC and TASCAM DA-3000 SS Recorder, Kramer VS-88A Matrix Switch, Rogue Audio Pharaoh Int amp, Sony HAPZ1-ES
smitty8451 is offline
post #2809 of 4114 Old 07-02-2014, 02:28 PM
thanks for input
post #2810 of 4114 Old 07-02-2014, 02:33 PM
bwillcox's Avatar
Quoted: 484 Post(s)
Liked: 265
Originally Posted by smitty8451 View Post
Bwillcox
Hope this helps
Thanks for pointing that out. I suspected as much. Guess I should read the manual someday.
Since it won't play all of the channels, I wish it would simply to refuse to play the track as my Sony HAP-Z1ES does. A 5.1 channel mix played with only the front two channels is pretty anemic sounding.
post #2811 of 4114 Old 07-02-2014, 02:57 PM
Quoted: 660 Post(s)
Liked: 382
When the source is cable TV, then the source could be the problem. You get all sorts of garbage sometimes, including supposed 5.1 sound but only a signal in the the front L/R, to terrible lipsync, to exaggerated bass or no bass. It can vary from channel to channel and program to program. If the receiver is working properly with CDs and Blu-rays, then it's a good sign the problem is the source.
Was the source the internal test tones? What are all your level trims set to? With the internal test tones if you measure 65dB at 0 on the master volume, it could just mean you have inefficient speakers or your level trims are in negative territory.
post #2812 of 4114 Old 07-02-2014, 03:37 PM
Quoted: 167 Post(s)
Liked: 61
I'll check some other sources and see how it sounds
yes, the source was the internal test tones - level trims were all around zero - certainly not different enough to warrant a 10dB drop. The speakers are all B&W 600 series (683S2 Fronts, HTM61S2 Center, 685S1 Surrounds) and have not been that low with other receivers in the past. This was post YPAO setup, I may reset it and retest.
post #2813 of 4114 Old 07-02-2014, 05:06 PM
Quoted: 480 Post(s)
Liked: 402
So I got my CX-A5000 and I am feeling like an idiot. I am trying to figure out how to set the unit to turn on video processing on my Apple TV input and turn it off on my Blu-ray input. I am obviously assuming this can be done and if it can't then I am going to be a very disappointed individual. Anyone care to chime in?
Balthazar2k4 is offline
post #2814 of 4114 Old 07-02-2014, 05:53 PM
Quoted: 660 Post(s)
Liked: 382
If you use Scenes to switch between inputs (which is what Yamaha seems to assume we will do) you can associate a different video mode with each Scene. See page 99 of the manual for all the items that can (optionally) be stored per Scene.
post #2815 of 4114 Old 07-02-2014, 05:58 PM
Quoted: 480 Post(s)
Liked: 402
Can you access Scenes 5 and up directly or should I just modify Scene 2 to fit my needs for the Apple TV and leave Scene 1 for my Oppo?
post #2816 of 4114 Old 07-02-2014, 06:04 PM
Quoted: 660 Post(s)
Liked: 382
The stock remote only has dedicated buttons for the first 4 scenes, and you have to use the scene menu for scenes 5-12. But there are discrete codes for all 12 scenes, so with a programmable remote you can do it.
post #2817 of 4114 Old 07-02-2014, 06:05 PM
TuenMuner's Avatar
1075 doesn't have the 5th leg. But other than that, basically the same unit.
BD-A1010/CD-S1000/PF60
HTR-6290/A-S1000/XBR55X900E
NS-555/SOAVO-900C/NS-125F
TuenMuner is offline
post #2818 of 4114 Old 07-02-2014, 06:15 PM
Quoted: 480 Post(s)
Liked: 402
Well, for now I cheated and got it to work by assigning to Scenes 1 and 2. Extremely un-intuitive that you need to go into the load menu and then details to select what loads when the Scene is selected. As for the direct codes for the additional Scenes, where can I get the codes? I am using a Logitech Harmony Touch and would love to get direct access to the Scenes and whatever else may be available.
Thanks for the help kriktsemaj99. I was starting to pull my hair out.
post #2819 of 4114 Old 07-02-2014, 07:14 PM
merrymaid520's Avatar
Quoted: 60 Post(s)
Liked: 31
Well I ordered the CX-A5000 to replace my rx-a3000. It was a tough decision between it and the upcoming 3040. Dolby atmos sounds intriguing but I have zero options for ceiling speakers etc, so.....
I'm hoping the separate pre/pro and amp are an improvement over my 3000. I ended up snagging a 7ch outlaw amp at 75 w/ch to power my center, surrounds, and zone speakers while my parasound A21 powers the front 2. I only care about movie performance being I use a parasound P5 for 2ch material.
Setup:
Ascend acoustics Towers with RAAL as L & R
Ascend acoustics Horizon with RAAL as center
Ascend acoustics Sierra-2 with RAAL as rear surrounds
Dual 15" Rythmik subs eq'd with REW and Behringer fbd
Parasound A21, P5, and zdac
Music server running Jriver
I'm hoping the setup satisfies my movie playback for the foreseeable future!
Anyone else have feedback going from a yamaha receiver the the CX-A5000?
Brandon
merrymaid520 is offline
post #2820 of 4114 Old 07-02-2014, 09:10 PM
Quoted: 660 Post(s)
Liked: 382
This link has IR codes for the RX-A3030, and the A5000 is the same. After you download the ZIP file, look in the document for extended codes. You'll probably have to convert the codes to Pronto Hex, as described in this post at remotecentral.
Balthazar2k4 likes this.
Yamaha Aventage Rxa 1030 Receiver , Yamaha Rxa2030bl Aventage Home Theater Receiver , Yamaha Rxa3030bl Aventage Home Theater Receiver
