The "Official" Yamaha AVENTAGE RX-A1030, RX-A2030, RX-A3030 and CX-A5000/MX-A5000 Thread - Page 95 - AVS Forum | Home Theater Discussions And Reviews
 758Likes
post #2821 of 4115 Old 07-02-2014, 09:54 PM
smitty8451's Avatar
Quoted: 64 Post(s)
Liked: 87
Merrymaid520
I have the Cx-A5000 that replaced my RX-A3010 and couldn't be happier, funny you should ask but I am thinking of getting the P-5 for dedicated 2 ch playback with my turntable and other 2 channel analog gear so turnabouts fair play how do you like the p-5?
Yamaha CX-A5000, ATI AT 2007 Amp, ATI AT 2004 Amp, Klipsch La Scala II- Main, RB 61's - Front heights, RC-62 - Center, RS-62's - Surround, RS-52's - Rear Surround, 2 Rythmik DS-1510 DIY Subwoofers each connected with Antimode Dual Core 2, Oppo BDP-95, MMF-7.1, Project Phono Box RS, XBox 360, XBox One, Oppo HA-1, TEAC PD-501HR transport, Atech Fabrication 7000 fanless HTPC and TASCAM DA-3000 SS Recorder, Kramer VS-88A Matrix Switch, Rogue Audio Pharaoh Int amp, Sony HAPZ1-ES
smitty8451 is offline
post #2822 of 4115 Old 07-03-2014, 02:33 AM
JohnHWman's Avatar
Quoted: 13 Post(s)
Originally Posted by JohnHWman View Post
Quick question : according to the specifications listed inside the user manual, the rear presence speakers amplifier power is not listed. Does it means that there is no power Amp section inside the unit for these rear speakers wiring in 9.2+2 channel system configuration ?
I've got my answer after carefully read the user manual in page 27 : in 9.2+Rear Presence speakers (my use), you need an external stereo amplifier connected to R.Presence PRE-OUT jacks. I'm considering the TPA3116-D2 D-Class 2x50W solution
John
Home theater enthusiast for over 20 years !
My dedicated HT room !
JohnHWman is online now
post #2823 of 4115 Old 07-03-2014, 05:50 AM
Quoted: 525 Post(s)
Liked: 495
Originally Posted by kriktsemaj99 View Post
This link has IR codes for the RX-A3030, and the A5000 is the same. After you download the ZIP file, look in the document for extended codes. You'll probably have to convert the codes to Pronto Hex, as described in this post at remotecentral.
Wow, thanks again kriktsemaj99. I had no idea that these resources were available. I'll give it a try.
Balthazar2k4 is offline
post #2824 of 4115 Old 07-03-2014, 05:58 AM
Otium's Avatar
Originally Posted by FilmMixer View Post
Even though I am not an owner, I love these AVR's and since I started the x020 thread I thought I could get this one going too...
I will update as info becomes available...
EDIT: I now own a A3030.
I also own an A3030. Love the ability to control it with my iPhone since the receiver is outside of the HT.
Otium is offline
post #2825 of 4115 Old 07-03-2014, 06:05 AM
kriktsemaj99's Avatar
Quoted: 665 Post(s)
Liked: 383
I just noticed that at the top of the list of Yamaha codes (on the awe-europe website) there's a link to a converter web page where you can enter a Yamaha NEC IR code and get the equivalent Pronto Hex. That may be easier than using the converter from the remotecentral post.
kriktsemaj99 is online now
post #2826 of 4115 Old 07-03-2014, 06:07 AM
Quoted: 525 Post(s)
Liked: 495
I saw that too. My current problem is figuring out how to add the code to my Harmony Touch. The new software does not seem to have a way to manually enter a code. Trying to find a workaround for that now.
post #2827 of 4115 Old 07-03-2014, 07:36 AM
bwillcox's Avatar
Quoted: 484 Post(s)
Liked: 270
I've used tge awe-europe website converter to convert all of the Yamaha NEC IR codes to Pronto Hex codes. The only gotchas that I recall is that you have to leave out the dashes (-) and use lower case on the Hex alphas.
bwillcox is online now
post #2828 of 4115 Old 07-03-2014, 07:39 AM
bwillcox's Avatar
Quoted: 484 Post(s)
Liked: 270
Well, I'm working on avoiding use of any of my Harmony Touches anymore (I despise the gesture stuff), but when I have used them I have learned the codes I needed from one of my Prontos.
post #2829 of 4115 Old 07-03-2014, 07:51 AM
merrymaid520's Avatar
Quoted: 60 Post(s)
Liked: 31
Originally Posted by smitty8451 View Post
Merrymaid520
Good to hear! Any improvement will be appreciated!
The P5 paired with my A21 is a great combo! I came from the parasound 2100 prior. I love the Halo gear For 2ch, a while back I had done my own A/B comparisons with my previous Yamaha receivers against the dedicated parasound pre and the differences are easily noticeable. The soundstage and imaging with a dedicated 2ch setup is much better. I think you will be pleasantly surprised
Let me know if you go that route and your thoughts!
Brandon
merrymaid520 is offline
post #2830 of 4115 Old 07-03-2014, 08:02 AM
mjmcmahon67's Avatar
Quoted: 167 Post(s)
Liked: 61
Balthazar -
I can't speak to the Touch as I have a 900, but adding multiple PRONTO codes to my 900 required an e-mail to Logitech Datasupport: datasupport@logitech.com
mjmcmahon67 is offline
post #2831 of 4115 Old 07-03-2014, 08:08 AM
jong1's Avatar
Quoted: 250 Post(s)
Liked: 199
Originally Posted by andymusicvideo View Post
Your 7 year old Denon has HDMI? were you using HDMI's the entire 7 years?
Originally Posted by JKR1963 View Post
Denon HDMI 7 years yes .......... I bought it at A&B Sound about May 2007 and it is still in use in my small family room system.
Got my, still going strong, Denon 4306 in August 2006 along with a Sony46x2000. My Virgin V+ was connected through the Denon to the TV by HDMI from day 1. My HTPC at the time used a DVI -> HDMI converter, which then went to the Denon and on to the TV.
Planing on a Yamaha next time though! I already have an RX-S500D in another room. Still not sure that all this HDMI 2.0/4K stuff is mature enough though. Thought I was going to upgrade TV and AVR for this about now, but I'm thinking it is better to hold off another year
jong1 is offline
post #2832 of 4115 Old 07-03-2014, 09:47 AM
Quoted: 525 Post(s)
Liked: 495
I already wasn't a big fan of the remote, but this really takes the cake. I seriously can't believe that Logitech has removed that function from the consumers hands.
post #2833 of 4115 Old 07-03-2014, 09:47 AM
Quoted: 525 Post(s)
Liked: 495
Originally Posted by mjmcmahon67 View Post
Balthazar -
Saw that somewhere else too. Can't believe I have to e-mail someone to have it added. Ridiculous!
post #2834 of 4115 Old 07-03-2014, 10:36 AM
Quoted: 665 Post(s)
Liked: 383
In the good old days (V1800/3800, Z11 etc.) you could directly enter any hex code into the Yamaha remote, and then it would emit the IR signal needed to teach another remote.
post #2835 of 4115 Old 07-03-2014, 10:48 AM
bwillcox's Avatar
Quoted: 484 Post(s)
Liked: 270
Huh, I never knew that. However, I've simply given up on my Harmony Touches. Just couldn't get used to the gesture based touch screen and they aren't nearly as flexible as my three Pronto TSU9400s. I still use my Harmony Ones on a couple of my systems. At least they don't have the gesture nonsense (the Touches would often do the wrong thing for me, might be an age thing...kids probably have it figured out).
post #2836 of 4115 Old 07-03-2014, 07:28 PM
turnne1's Avatar
Quoted: 1991 Post(s)
Liked: 489
Originally Posted by merrymaid520 View Post
Question regarding the CX-A5000. anyone know if the trigger outputs on the unit are 3.5mm or 2.5mm? Some of my equipment has both.
3.5mm
Warren
Rm 1 Samsung 65KS9800 Marantz 8802A prepro Sherbourn 5/1500A amp B&W CM10s..CM2 center...CM5's.rears
Rm 2 Vizio P50 Denon X4300 Celestion 305 speaker system
Rm 3 Samsung 55KS8000 Yamaha A1060 Kef 2005.2 speaker system
Rm 4 Vizio P50 Pioneer SC95 Mirage Omni sat speaker system
turnne1 is offline
post #2837 of 4115 Old 07-03-2014, 08:22 PM
Quoted: 60 Post(s)
Liked: 31
Originally Posted by turnne1 View Post
3.5mm
Warren
Thank you!
post #2838 of 4115 Old 07-03-2014, 09:01 PM
Skylinestar's Avatar
Quoted: 1214 Post(s)
Liked: 227
How is the YPAO when compared to Audyssey?
Skylinestar is offline
post #2839 of 4115 Old 07-04-2014, 01:24 AM
Webmonkey's Avatar
Quoted: 60 Post(s)
Liked: 32
I am curious is the Yamaha will downsample to 48KHz like the Marantz AV8801....
Webmonkey is offline
post #2840 of 4115 Old 07-04-2014, 05:55 AM
Quoted: 665 Post(s)
Liked: 383
I wish someone with the required equipment would make measurements, but I haven't seen any for the new models. Several years ago someone did post measurements for the RX-V1800. See this post and the next few from OttoElectronic.
The V1800 could apply EQ at 96kHz, but downsampled to 48kHz if certain DSP processing modes were also selected. It was a two DSP design, similar to the current high-end models. Sadly, the two DSPs in the new models don't have much more processing power than the ancient V1800, and now with 11.2 channels to process instead of only 7.1 it's possible they can't manage 96kHz. But we need measurements to be sure, because Yamaha doesn't put these things in the specs.
post #2841 of 4115 Old 07-04-2014, 06:05 AM
bwillcox's Avatar
Quoted: 484 Post(s)
Liked: 270
Unless the DSP chips are the same ones, I wouldn't jump to any conclusions as to whether the V1800 and the new models have the same limitations. The chips in the new models could be faster and only require 2. My RX-Z11s have 4 DSP chips and as I recall didn't downsample to 48kHz to apply DSP processing, but they are the same vintage as the V1800.
post #2842 of 4115 Old 07-04-2014, 06:28 AM
Quoted: 665 Post(s)
Liked: 383
I'm not jumping to conclusions, but the DSPs are basically the same (same TI C67x+ core, maybe at a slightly higher clock frequency). The Z11 had 4 DSPs so it could handle more channels without having to make other compromises.
It would be nice if all the sampling rate limitations were included in the manual, but I'm sure that will never happen.
post #2843 of 4115 Old 07-04-2014, 07:55 AM
bwillcox's Avatar
Quoted: 484 Post(s)
Liked: 270
Still, unless they post the limitations somewhere, we will probably never know for sure.
post #2844 of 4115 Old 07-04-2014, 08:40 AM
Quoted: 59 Post(s)
Liked: 6
Just purchased the 3030. I am running 9.1 with the AVR and zone 2 and 3 with my 5 channel B&K AV 5000 series II amp. Should I use the B&K to run the front 2 or 3 as it is probably more robust (125w @8ohm...conservatively)? And if I do, will the 3030 power the other 2 zones with its on board amps? Also that little triangular little YPAO accessory that comes with the mike is a different size screw mount compared to the mike. Is it defective or amI missing something. I just used the mike on my tripod to calibrate until I find out.
audio.hobby is offline
post #2845 of 4115 Old 07-05-2014, 03:31 AM
Quoted: 59 Post(s)
Liked: 6
Also noted that the sound levels are off in zone 2 and 3. Is that where the party mode comes into play?
post #2846 of 4115 Old 07-05-2014, 10:02 AM
Quoted: 665 Post(s)
Liked: 383
Not quite sure what you mean, but you can control the volume of each zone independently.
post #2847 of 4115 Old 07-05-2014, 12:35 PM
Quoted: 59 Post(s)
Liked: 6
Sorry it was my error on that one.
post #2848 of 4115 Old 07-05-2014, 02:44 PM
Quoted: 59 Post(s)
Liked: 6
any suggestions?
post #2849 of 4115 Old 07-07-2014, 06:59 AM
Quoted: 59 Post(s)
Liked: 6
Anybody with any suggestions about using the B&K or is the 3030 just as powerful? Calling Yamaha about the mic today.
post #2850 of 4115 Old 07-07-2014, 08:59 AM
Keasley's Avatar
Hi All,
I've just (yesterday) set up an A1030 in a 2.0 setup with a pair of Monitor Audio Silver 8 tower speakers. I haven't yet run YPAO as I understand it's good to 'burn in' the speakers first. My room is fairly small and oddly shaped so a whole surround setup not practical. No place even for a sub or center channel. So I went with a pair of towers that can reproduce decent bass frequencies.
Anyway, music is the main focus of this gear -- and I'm very happy with the sound via audio sources -- but I have also routed my tv and blu ray through the Yamaha and finding that most of the out-of-the-box settings and presets sound very 'wrong' with my rig. Movie presets like 'Sci Fi' and 'Drama' are largely missing dialog but with music and fx highly accentuated -- also a lot of washed out reverb like you'd get if you were talking softly in a cement mixer...) I'm guessing this is because Cinema DSP 3d (or whatever it's called) thinks I have more speakers setup than I do. The '7 channel audio' preset bypasses cinema dsp 3d and sounds pretty good with tv and movies so I've been using that in the interim but hoping for advice regarding a good long-term solution.
So....once I run YPAO and tell it I have only 2 speakers will it reconfigure all the presets for a 2.0 setup and make them all available or do I have to stick with a more limited palette? Also, should I just disable Cinema DSP altogether or will it become an asset once YPAO is run?
This is my first A/V receiver and I'm having fun experimenting and figuring it out, but if you guys could point me in the right direction as well it would be great.
thanks.
Keasley is offline
Yamaha Aventage Rxa 1030 Receiver , Yamaha Rxa2030bl Aventage Home Theater Receiver , Yamaha Rxa3030bl Aventage Home Theater Receiver
