Official Pioneer VSX-1123-K Owners thread - Page 20 - AVS Forum | Home Theater Discussions And Reviews
 54Likes
post #571 of 1059 Old 06-12-2014, 01:59 PM
TrafficGuy's Avatar
Originally Posted by Exist_To_Resist View Post
I don't see why you needed to get a converter, the receiver is capable of handling composite RCA inputs and converting them to HDMI output.
DVD, SAT/CBL, and DVR/BDR inputs can take Component signals, you just have to switch the option in the receivers menu.
Page 23 and 37 of the Operational manual for the receiver.
This is exactly what I have done for the kids' older Wii console. No converters needed...looks & sounds fine.
TrafficGuy is offline
post #572 of 1059 Old 06-18-2014, 04:44 AM
sforza's Avatar
Hey all, I also picked one up from amazon for $349.
I can't get hdmi from xbox1 or Verizon fios box to output through receiver to LG tv.
The receiver's volume/menu overlay does show though.
Any advice?
sforza is offline
post #573 of 1059 Old 06-18-2014, 05:42 AM
Exist_To_Resist's Avatar
Quoted: 339 Post(s)
Liked: 178
Any advice?
What inputs on the receiver are you using?
Some inputs can get their signal from analog sources. You might have to check to make sure that for a specified input the HDMI as source is selected in the receivers menu.
Exist_To_Resist is offline
post #574 of 1059 Old 06-18-2014, 05:52 AM
Bond 007's Avatar
Quoted: 2662 Post(s)
Liked: 2113
XBox is not HDMI.
Check the cable box audio settings.
Bond 007 is online now
post #575 of 1059 Old 06-18-2014, 08:07 AM
Quoted: 339 Post(s)
Liked: 178
Originally Posted by Bond 007 View Post
XBox is not HDMI.
Huh?... he said he's not getting anything.
I suspect he has both of those devices on either SAT/CBL, DVR/BDR, or DVD inputs as these inputs can have varying sources.
And these correspond to HDMI 1, 2, and 3 inputs. So I would check the settings on those or just move your Xbox One and VBox to different HDMI inputs.
OLED is a game changer.
post #576 of 1059 Old 06-19-2014, 04:11 AM
netjack's Avatar
Hi Guys - I too have a couple of q's as I'm contemplating upgrading from an Onkyo 809 (mostly because I heard about the dreaded HDMI board issue and I'm out of warranty). FWIW I have an Aperion Audio 7.1 speaker setup.
1) I use a handful of HDMI inputs and constantly find myself swapping audio modes (between 2 speakers, stereo, and the slew of 7.1 simulated configurations). What I find annoying w/ the 809 is that I have to toggle through all the modes (there are like 20) vs assigning buttons (logitech harmony) to specific modes. I haven't been able to find this in the 1123 manual so does that not exist for this either?
2) Will I notice any upgrade in sound fidelity from the 809?
TIA
netjack is offline
post #577 of 1059 Old 06-19-2014, 05:00 AM
sforza's Avatar
I moved the xbox1 to one of your suggested ports and it worked. For whatever reason I couldn't get cable to pass through xbox1 successfully.
I opted to run an optical cord from xbox1 to reliever. I have cable going into xbox1, and xbox1 hdmi out to tv.
I am only able to get sound when in stereo ext , thoughts on why?
sforza is offline
post #578 of 1059 Old 06-23-2014, 01:05 AM
mlgreen's Avatar
Does this receiver display Ipod art and bypass the Ipod's built in DAC?
mlgreen is offline
post #579 of 1059 Old 06-24-2014, 12:39 PM
sforza's Avatar
Question
Originally Posted by Murilo View Post
I love the new price but im concerned with all these issues.
I do have one question since i currently own a denon.
With the denon when i listen to a 2 channel track you can automatically set surround processing option specifically for 2channel, i use multichannel stereo for music, and then surround processing you can have a completely different surround processing and i use dolby plxII for my blurays. So on my htpc i use it for music and bluray when a 5.1 movie is playing it will automatically add plxII, and if im listening to a flac cd in stereo it will automatically switch to multi channel stereo. Can the pioneer do this? Just want to make sure before i jump ship the pio's can do what my denon does.
I should mention what my denon does is remember what processing i last used for a particular type of auto stream.
For instance my htpc input on the denon displays "auto surround mode" and then shows what i had last selected analog to (plxII), Digital 2ch (Multi channel stereo), digital 5.1 (plxII), and Multi ch (plxII). Although my denon avr 991 often forgets the settings the surround sound processing was last set at, kind of why im looking to get rid of it as well. so it would be nice to know if the pioneers dont have this problem of defaulting to something different.
Was this ever answered?
sforza is offline
post #580 of 1059 Old 06-24-2014, 08:52 PM
ColdCase's Avatar
The receiver is a text display only. Dunno about the DAC. How would one bypass the DAC... its only for the headphone jack right? So by using USB or network connection the DAC doesn't come into play? Its all digital... but I dunno.
PDP-6010FD, VSX1123K, HW-150PVR, Snell E111 Mains, Polk Center, VTF3Mk4 Sub, DIY surrounds, HD XA2, DMR HS2, DV F27, HR21-200, TH-50PH9UK, VSP-1100, PSW200... some other stuff.
ColdCase is offline
post #581 of 1059 Old 06-25-2014, 01:39 AM
Shadyron's Avatar
Looking to purchase an audio receiver that I will run speaker wire outdoors to speakers near my pool. With that in mind it is a must for me to have the capability of controlling the volume from a smartphone since the receiver will be no where near my pool. It looks like this Pioneer vsx 1123 has that capability.
Now could I stream sirrusxm radio app from my smartphone through the receiver? I know the Onkyo 626 model allows it, but I've owned Pioneer receivers all my life and would like to stick with them.
Shadyron is offline
post #582 of 1059 Old 06-25-2014, 05:22 AM
sforza's Avatar
I have receiver set to auto surround.
I have audio coming via hdmi from xb1 set to bitstream.
Auto surround does not play any audio when i switch to channel (like nick jr) with 2ch stereo. Also some commercials do not play sound.
Any ideas?
sforza is offline
post #583 of 1059 Old 06-25-2014, 11:33 AM
ColdCase's Avatar
I can do both from my iPhone 5s (airplay). One can control just about anything remotely, but I am using last year's control app. Dunno about other smartphones.
ColdCase is offline
post #584 of 1059 Old 06-25-2014, 11:57 AM
Quoted: 339 Post(s)
Liked: 178
The Pioneer doesn't do what the Denon does, as you can see that function is sketchy at best. The Pioneeer remembers the audio processing for each individual input. The audio processing can be set with one press of 3 easily accessible buttons on the remote, it takes 2 seconds.
post #585 of 1059 Old 06-25-2014, 12:14 PM
Quoted: 339 Post(s)
Liked: 178
Any ideas?
I have an HTPC connected which switches audio streams all the time, stereo, DTS, DD, DTS Master... etc.
The receiver has no problems processing these/
The Xbox One does not have a true bitstream option, it is still doing all the audio processing.
Sounds to me like a limitation of the Xbox.
I would connect the TV to a separate HDMI input on the receiver for testing.
post #586 of 1059 Old 06-25-2014, 04:20 PM
sforza's Avatar
tell it to the wife!
sforza is offline
post #587 of 1059 Old 06-26-2014, 06:08 AM
Bond 007's Avatar
Liked: 2113
Whats the best (cheapest) place to get an MCACC microphone for this receiver?
post #588 of 1059 Old 06-26-2014, 09:12 AM
Quoted: 339 Post(s)
Liked: 178
I'm sure you can teach her how to use three buttons on a remote, if not then she doesn't deserve to be basted in glorious harmonics.
post #589 of 1059 Old 06-26-2014, 09:13 AM
Quoted: 339 Post(s)
Liked: 178
This has been discussed at length in the MCACC sub forum, and there isn't. You would need to pick one up directly form Pioneer.
post #590 of 1059 Old 06-26-2014, 10:18 AM
Bond 007's Avatar
Liked: 2113
Well, that sure makes it simple enough. Thanks.
post #591 of 1059 Old 06-27-2014, 09:01 AM
Liked: 0
Tell me if you know you will have a firmware update for this receiver? Will it support HDMI2.0 (4k 60fps) or not? Maybe she has not tested estv it?
Алек Норман Оним is offline
post #592 of 1059 Old 06-27-2014, 11:28 AM
Daryl L's Avatar
Quoted: 522 Post(s)
Liked: 345
A few weeks ago I decided to go ahead and get the VSX–1123 instead of waiting on the VSX–1124 while Amazon had the 1123 and a nice price. I finally got around to hooking it up last night and going through the features I noticed in Tuner mode the station frequencies did not show in the OSD. Am I correct that it does not show the radio station on the OSD? I kind of assumed it would because my old pioneer VSX–1018AH did show the frequency on the OSD. I'm kind of bummed about that because I can't read the front panel display from across the room.
Daryl L is offline
post #593 of 1059 Old 06-28-2014, 06:57 AM
netjack's Avatar
uhhh..what am i doing wrong? I can't get the surround back left and right to output sound? they're hooked up properly because I can do the DB and distance testing in setup.
XL & XR icons on the receiver aren't lighting up to show surround back L&R (unlike my onkyo 809), how do you know the receiver is outputting to them? Essentially how does this simulate 7.1 from a 5.1 source?
netjack is offline
post #594 of 1059 Old 06-28-2014, 10:14 AM
netjack's Avatar
Ok it looks like I can get the surround back L&R working but still only lights up 5 speaker icons on the display. What is the XL and XR icons for?
netjack is offline
post #595 of 1059 Old 06-28-2014, 12:20 PM
Daryl L's Avatar
Quoted: 522 Post(s)
Liked: 345
As for only five speaker icons lit up, that just means the incoming signal has five channels (a 5.1 source). The icons represent how many channels is receiving, not how many it's playing back.
XL and XR can represent left and right back surround encoded signal (7.1 source), or left the right height encoded signal or left or right wide encoded signal. Or left and right stereo speakers in another room when running a 5.1 set up in the main room I would assume.
Daryl L is offline
post #596 of 1059 Old 06-28-2014, 02:52 PM
netjack's Avatar
Ok to ensure that it's simulating 7.1 out of a 5.1 ch, I should select the standard surround sound?
netjack is offline
post #597 of 1059 Old 06-28-2014, 04:19 PM
Daryl L's Avatar
Quoted: 522 Post(s)
Liked: 345
Smile
Yes, and just toggle through to the surround mode you want to use.
Daryl L is offline
post #598 of 1059 Old 06-30-2014, 09:32 AM
kklarson's Avatar
I don't know if they're cheaper, but there are several available on ebay.
kklarson is offline
post #599 of 1059 Old 06-30-2014, 12:08 PM
Bond 007's Avatar
Liked: 2113
Just for the record. Pioneer wants $30 for the mic and $15 for shipping.
post #600 of 1059 Old 06-30-2014, 04:25 PM
Liked: 0
First time poster...
I know it has been asked before, but has anyone had any success getting line level audio out of the Pre Out connectors on the back panel of the VSX1123, so that it can feed into an external amplifier? I know that the cabling and external amplifier are functioning as they should.
I've tried feeding multiple sources in to the VSX1123, but at best, can only get a miniscule amount of signal out of the Pre Out connectors, certainly no where near line level.
Thanks in advance,
davidt
dazzlinglights is offline
Pioneer Channel Av Receiver Vsx 1123 K , pioneer vsx-1123-k
