Denon 3080CI HDMI port 1 issue - AVS Forum | Home Theater Discussions And Reviews
Old 06-09-2013, 09:07 PM - Thread Starter
PMA
PMA's Avatar
Quoted: 99 Post(s)
Liked: 30
I'm hoping someone can help me diagnose and possible fix this issue:
I have a blu ray player attached to port 1 and for some reason, I can see the boot up screen but then the screen goes black (I think to change resolutions) and then I get the Denon screen as if nothing was attached. The port has worked properly in the past but intermittently. I wasn't using it at all but then attached the BD player which worked for a short time and then this issue.
Anyone know what may be going on so I can fix? I've already reset the AVR to see if rebooting from scratch might fix. Did not work.
Paul
PMA is offline
Old 06-10-2013, 04:10 AM
jdsmoothie's Avatar
Quoted: 12249 Post(s)
Liked: 5579
Try replacing the HDMI cable as well as the other inputs.
jdsmoothie is online now
Old 06-10-2013, 10:14 AM - Thread Starter
PMA
PMA's Avatar
Quoted: 99 Post(s)
Liked: 30
Thanks, I've tried other HDMI cables and also hardware sources to that input. Still no go. What's most curious is why it works for a few seconds but then for some reason the port goes dark with the Denon screen showing on the TV as if nothing is plugged in.
PMA is offline
Old 06-10-2013, 03:34 PM
jdsmoothie's Avatar
Liked: 5579
The BDP issue may be resolved by setting the "Deep Color Output" setting on the BDP to OFF, however, if the issue still remains even when connecting to the other HDMI inputs and is also occurring with all your HDMI sources, then give a few more microprocessor resets a try, otherwise, the HDMI board has likely gone bad. If your typo really refers to the 3808CI, then this board is likely no longer available although going the repair route if the board is available is likely to run at least $300-$400 so consider putting the money into a newer model.
Old 06-11-2013, 10:20 AM - Thread Starter
PMA
PMA's Avatar
Quoted: 99 Post(s)
Liked: 30
Thanks for the advice. Yesterday, I did another hardware swap and the port suddenly worked with an Apple TV attached. Not sure why but the BDP also works OK in a separate port. You are correct that my heading is a typo and the unit is a 3808CI. If the port becomes intermittent or fully fails again, I will consider a AVR replacement but will try resetting the microprocesser a few more times.
PMA is offline
