3D Receiver to go with new Panasonic ST60 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-10-2013, 06:55 AM - Thread Starter
tlinnert's Avatar
I just purchased a Panastonic 60ST60 and would like to be able to fully utilize its 3D capabilities. I am still using an Onkyo 606 which is not 3D capable. I would like to keep my budget under $300. I have 4 Polk Monitor 60's and a CS2 center channel. I also have a PA-120 Sub. I have been considering the Denon 1713. Does anyone have any positive or negative opinions of this receiver? Are there any other receivers someone would suggest in this price range? Thanks in advance.
tlinnert is offline
post #2 of 3 Old 06-10-2013, 08:34 AM
myoda's Avatar
Liked: 57
The Denon 1713 is slightly above your price point. If you don't mind a factory refurb, try these:
$219.99
http://www.accessories4less.com/make-a-store/item/ONKTXNR515/Onkyo-TX-NR515-7.2-Channel-Network-A/V-Receiver/1.html
$269.99 (with free shipping)
http://www.accessories4less.com/make-a-store/item/ONKTXNR616/Onkyo-TX-NR616-7.2-Ch-THX-Certified-Network-A/V-Receiver/1.html
$279.99
http://www.accessories4less.com/make-a-store/item/DENAVR1912/DENON-AVR-1912-7.1ch-Network-A/V-Home-Theater-Receiver-w/Airplay/1.html
$299.99
http://www.accessories4less.com/make-a-store/item/DENAVR1913/DENON-AVR-1913-7.1ch-Home-Theater-Receiver-w/AirPlay-3D-ready/1.html
myoda is offline
post #3 of 3 Old 06-10-2013, 09:08 AM - Thread Starter
tlinnert's Avatar
Thanks for all of the great suggestions. I am a bit skeptical of the Onkyo's due to the HDMI issues I have had with my current receiver. I believe for me it would come down to the Denon 1713 and 1913. The 1713 is actually cheaper on the same website you posted those links. $269.99 i believe.
tlinnert is offline
