Best Preamp or Receiver with Preouts under $1000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-10-2013, 08:04 PM - Thread Starter
tsloms's Avatar
Quoted: 54 Post(s)
Liked: 59
I've just now begun on building my pair of DIY speakers as can be seen at this link.
http://www.avsforum.com/t/1459575/tmm-ae-td-10xs-with-xr1464-horn-and-bms-4594-cd
I'll be posting updates to that post this week yet. I'm currently running an Onkyo 616 receiver which does a pretty good job as a budget receiver with my mini Ewave DIY speakers. These new speakers will be going into my living room when completed and running in only stereo for the time being. I will probably add a pair of surrounds but no center channel. These speakers will be powered by a Crown XTI2002 amp in 4 ohm stereo for 800 watts per channel. This will allow me to EQ the speakers with the amp as well.
I'm looking for a preamp that can meet the following requirements.
1) Of course output to the XTI2002. (preferably balanced outputs)
2) Allow for streaming Pandora and Spotify. (Preferably via WIFI. Otherwise I will need to run another Ethernet from my basement.)
3) Support at least 4 HDMI inputs and ARC.
4)Cost less than $1000 unless there is a marked improvement.
5) Support 7.1 at a minimum. This one should be easy. I have no plans to go to 9.1 or 9.2.
6) Have excellent audio quality with music in stereo.
I've been looking at used and refurb units even . The models that I've been looking at are the Onkyo 818, Marantz 7005 or 7701, Denon 3313 or 4411, and the Onkyo 5508. I'm open to suggestions.
Please help me with this choice. So far the highest end receiver I've purchased is my old Onkyo 805 which has a great amp section but can't stream Pandora and is missing ARC.
tsloms is online now
post #2 of 8 Old 06-11-2013, 04:45 AM
Nethawk's Avatar
Liked: 118
The Denon 3313CI would be my choice. Preamp outputs for full 7.1 and on board Spotify & Pandora. I just bought the 2313CI for my 2 channel set up (I needed better bass integration), and love it, but its preamp outputs are only for zone 2, so you'll need the 3313.
Nethawk is offline
post #3 of 8 Old 06-11-2013, 06:28 AM - Thread Starter
tsloms's Avatar
Quoted: 54 Post(s)
Liked: 59
Does the advantage of the 818 having XT32 over the 3313 with XT offer that much?
post #4 of 8 Old 06-11-2013, 08:55 PM - Thread Starter
tsloms's Avatar
Quoted: 54 Post(s)
Liked: 59
Any other thoughts?
post #5 of 8 Old 06-11-2013, 09:24 PM - Thread Starter
tsloms's Avatar
Quoted: 54 Post(s)
Liked: 59
I've read that the Sherwood 972 can be a bit flaky at times but would that compare to these modern receivers as a preamp?
post #6 of 8 Old 06-12-2013, 05:53 PM
Quoted: 911 Post(s)
Liked: 489
You're not gonna find balanced outputs on an AVR under a grand. If you're willing to go with an cheap (and more user-friendly) external solution for streaming (AppleTV, etc.) and sound quality is the primary goal, look at the Anthem MRX 300. In your budget, and room correction software superior to anything else near its price (except for the aforementioned Sherwood, which is also excellent but not a current-production piece).
Get it from a "custom installation" dealer (no online sales) and you'll even be spared the "High End audio salesman" full-court press to buy idiot wires, etc.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #7 of 8 Old 06-13-2013, 05:22 AM - Thread Starter
tsloms's Avatar
Quoted: 54 Post(s)
Liked: 59
I'm going to do some running tonight. I have a local Anthem dealer that I'll stop by and check out the MRX receivers. My TV does stream Pandora as well but it's convenient having it in the receiver. From the reading that I've done on them the MRX series is highly regarded as having excellent sound quality. Does is also have HDMI audio return channel to be controlled by the TV for powering on and off as well as volume control?
post #8 of 8 Old 06-13-2013, 05:11 PM
Quoted: 911 Post(s)
Liked: 489
It claims to have the return channel, but my TV doesn't so I've never personally used it. It also has CEC, but CEC wastes a lot of energy on the MRX and all AVRs. It's a bit of kludge, really. I have it turned off and use a Harmony remote.
The MRX is a commodity part just like all the others, except for the fantastic room correction system.
Serious Audio Blog
DS-21 is offline
Crown Audio Xti 2002 475w Stereo Power Amplifier 20hz To 20khz Frequency Response 1 4vrms Input Sens , Onkyo Tx Nr818 , Marantz Av7005 Pre Processor , Marantz Av7701 Audio Video Preamp Processor , Denon Avr 3313ci Receiver
