Very confused....need processor advice. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 06-10-2013, 09:40 PM - Thread Starter
mazspeed's Avatar
Ok, this is what I have been looking for. First off, i need to explain my set up.
I currently have an arcam avr300 with a computer (htpc) setup with HD/blu ray movies and flac audio files in the system. Im also running a pioneer elite blu ray player that i dont use, but would still would keep in the setup. Im running everything for now into a older but still very good mit rear projection tv.
What i am looking for is tout my new arcam p7 with a new processor setup so I can enjoy 2 channel and home theater in one component. I was told i should get a rotel 1570b for my flac files because it has the usb/computer digital hookup and a integra or anthem mrx500-700 for my ht, but I want to run everything through the amp and not use the amps from either a receiver/processor or the rotel. I have a programmer to set everything up on one remote, then use the mouse on the computer once i engage the computer.
My question is, do I need both the rotel and processor for HT use or is there a processor that I can buy that will do all of these things? I was told that a lot of processors don't have the usb digital setup for my computer flac files.
Any advice would be great. Thanks in advance.
Mike
mazspeed is offline
post #2 of 18 Old 06-11-2013, 04:21 AM
Nethawk's Avatar
Liked: 118
Why must it be USB? How is your HTPC sound currently connected to your AVR? Most have digital outputs at the least. I don't think you need any more gear at all, but maybe I'm missing something.
Nethawk is offline
post #3 of 18 Old 06-11-2013, 04:21 AM
Quoted: 1393 Post(s)
Liked: 587
mazspeed
Try asking your question in the Marantz 8801 thread.
I think there are some that use it as you describe but I'm not sure as I don't use mine that way.
JimP is offline
post #4 of 18 Old 06-11-2013, 10:28 PM - Thread Starter
mazspeed's Avatar
Hey guys thanks. I like the Marantz but was set on other options if possible. I have had a Marantz as well, and was hoping to upgrade the sound a bit.
The system sounds ok, not fantastic like it should. I know that the square port usb connection is the one i need to play back vinyl rips on my computer the way it should sound. I was told this is the best port to use. This is what i would have to use for 2 channel, and than for HT i would switch back to the processor/amp setup. If that all makes sense.
mazspeed is offline
post #5 of 18 Old 06-12-2013, 01:41 AM
audiofan1's Avatar
Quoted: 1650 Post(s)
Liked: 1666
Marantz 8801 , go over to the thread and get some setup answers and it has SQ in spades wink.gif
audiofan1 is offline
post #6 of 18 Old 06-13-2013, 12:05 AM - Thread Starter
mazspeed's Avatar
Hey audiofan. Thanks, will take a look, but not looking for a marantz. Fine equipment, but looking for a processor that specializes in music.
mazspeed is offline
post #7 of 18 Old 06-13-2013, 12:11 AM - Thread Starter
mazspeed's Avatar
Would this work for what i am looking for instead of the rotel to run the flac files from my computer to my amp? http://www.startech.com/Cards-Adapters/Sound/USB-Audio/USB-7-Channel-Audio-Adapter-with-SPDIF~ICUSBAUDIO7D
Can the anthem 500-700 play the flac files through this from my computer to this devise hookup? I am terrible at explaining this stuff. Hopefully someonemuch smarter than myself can figure out what i am saying.
mazspeed is offline
post #8 of 18 Old 06-13-2013, 12:45 AM - Thread Starter
mazspeed's Avatar
mazspeed is offline
post #9 of 18 Old 06-13-2013, 02:06 AM - Thread Starter
mazspeed's Avatar
Something like this would work with digital outs right? http://shop.emotiva.com/products/xda2
Anything like that out there?
mazspeed is offline
post #10 of 18 Old 06-13-2013, 02:32 AM - Thread Starter
mazspeed's Avatar
Sorry for all the posts, but a friend said this might work. http://www.colamco.com/store/stat/product/1262963.html?source=froogle&gclid=CJvN2NvK4LcCFW1yQgodJHoAKA
Thoughts? Thanks again.
Mike
mazspeed is offline
post #11 of 18 Old 06-15-2013, 03:01 AM - Thread Starter
mazspeed's Avatar
Anyone?
mazspeed is offline
post #12 of 18 Old 06-15-2013, 12:42 PM
Brian B's Avatar
Quoted: 233 Post(s)
Liked: 101
Mike
No. Buy a media player like a Sonos Connect and hook it up digital to whatever preamp you get. If you are looking to hook the computer up directly to the preamp then hook it up with an optical connection and use software that preserves the sound quality depending on the operating system.
B.
Brian B is offline
post #13 of 18 Old 06-16-2013, 04:14 AM - Thread Starter
mazspeed's Avatar
Hey Brian, thanks for the response. Isn't the optical connection not as good as the square usb setup? I was told that. Should be using that connection for the flac files to play in 2 channel from my computer files? Again i have no clue, but your input will help.
Mike
mazspeed is offline
post #14 of 18 Old 06-16-2013, 10:44 PM
Brian B's Avatar
Quoted: 233 Post(s)
Liked: 101
Mike
No, most believe the optical is better, but should be at least as good.
B.
Brian B is offline
post #15 of 18 Old 06-17-2013, 01:27 AM - Thread Starter
mazspeed's Avatar
So could use the anthem mrx 500-700 for this cofiguration with running flac files in the best way possible? I do this now with my arcam avr 300 and the flac files dont sound as good as it should. I am running them on jriver media software. Do you need any other ibfo on my setup?
mazspeed is offline
post #16 of 18 Old 06-17-2013, 02:42 PM
Check out the Oppo BDP-105. It's an incredible device with world class DACs. It also does processing, two channel analog, and you can plug your computer right into it and take advantage of the asynchronus USB DAC. Very high quality at a very reasonable price.
stratoholic is offline
post #17 of 18 Old 06-17-2013, 08:25 PM - Thread Starter
mazspeed's Avatar
I was just going to ask about the oppo 105. I saw one today at a magnolia store. It was awesome. But the only issue is and i can over look it. I could use this instead of a processor and plug it strait to the amp and computer, but it doesnt have a way to use a custom remote to do the switching. I have a mx780 remote and the way i have it done now is that the arcam avr300 does all the 1 touch remote switching for me. I was told the oppo cant do this, and that it would be a step by step and 2 remote style system. Is this accurate. I was told the oppo is a world class video and sound processor dacs. I did listen to a cd on a oppo95 with an arcam avr600 with b&w speakers and it sounded incredible. Im not sure its going to do much with my mit 65 inch rear projection tv with dvi and 1080i viewing. Can i still get a receiver/processor and run audio and video passthough to get the eas of switching? Sounds like a big purchase for just the switching aspect, but i was willing to do that if need be. What do you guys think? Thanks again for everyones input, it all helps so much.
mazspeed is offline
post #18 of 18 Old 06-18-2013, 08:14 AM
I use a Logitech Harmony 700 universal remote with my Oppo and the rest of the components in my system and have had no switching issues.
