Do you people use a separate circuit outlet for your integrated 500W or higher amplifier? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-12-2013, 04:06 AM - Thread Starter
happy hopping's Avatar
Quoted: 58 Post(s)
I had an old Sony 500W ES integrated receiver. In the old days, it was connected to the same outlet as my UPS, in which my UPS connects to HD TV, DVD player etc. And each time the sony integrated amp. is turned on, the Smart APC UPS has a momentary voltage gain (or drop), its fan turns on for a minute, and all these is due to the transient response of 500W
My current new receiver is a Yamaha RX-v573, which is 700W. Should I connect the yamaha cable to a separate wall outlet like my sony, or can I connect the yamaha along w/ my HD TV, blu ray player etc. on the same wall outlet?
in short, what do you guys normally do?
happy hopping is offline
post #2 of 8 Old 06-12-2013, 09:16 AM
crn3371's Avatar
Quoted: 239 Post(s)
Liked: 192
I connect mine on the same outlet. I'm sure most people do the same, but probably out of necessity as there's usually only one outlet available at their tv location.
crn3371 is offline
post #3 of 8 Old 06-12-2013, 09:21 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Skip the UPS.
arnyk is offline
post #4 of 8 Old 06-12-2013, 09:22 AM
javi404's Avatar
Sounds like the capacitors charging in the amp cause a momentary drop in line voltage. The ups is doing it's job and switching to battery for that split second. I have everything plugged into my ups except amp for my diy subwoofer. All eventually to same outlet since it's the only one on that wall I can use.
javi404 is offline
post #5 of 8 Old 06-12-2013, 10:38 AM
Splicer010's Avatar
Liked: 39
No. not necessary.
Splicer010 is offline
post #6 of 8 Old 06-12-2013, 11:46 PM
Legairre's Avatar
Quoted: 470 Post(s)
Liked: 270
I use a Rotel RMB-1095(5x200 wpc) and two Rotel RB-1050 (2x80 wpc each) and an Anthem MRX300 as a pre/pro. The RMB-1095 is on a dedicated circuit and the two RB-1050s are on another dedicated circuit with the Anthem MRX300.
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Legairre is offline
post #7 of 8 Old 06-13-2013, 02:50 PM - Thread Starter
Quoted: 58 Post(s)
I look at the Yamaha, the cord is just a basic cord, so I am going to connect it to just a simple extension cord, as it doesn't seem to draw a lot of power based on the gauge of that cable. Lamp cord gauge.
Now my old Sony, that cable diameter is big, I wonder why. As my sony is 500W, the yamaha is 700W
post #8 of 8 Old 06-13-2013, 05:04 PM
javi404's Avatar
Do a search on the arguments about measuring amp power. Most specs are for only a few channels driven simultaneously and also for peak bursts of power not continuous with all channels driven 100%.
javi404 is offline
