AudioClassics LTD needs your help identifying this! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-13-2013, 07:33 AM - Thread Starter
AudioClassics's Avatar
Hi all,
We had an item a customer brought in and we believe it to be a Phono stage or Pre-amp of some sort but are a bit baffled. Can someone help giving us information for identification!? We'd really appreciate it.
AudioClassics is offline
post #2 of 8 Old 06-13-2013, 09:36 AM
vzphoneman's Avatar
Quoted: 104 Post(s)
Liked: 103
Welcome ... I'm a big fan of your store. What are the connections on the back and are the transformers and switch part of the power circuit?
The lazy man finds the easiest way ... Ben Franklin
Rouge Audio Cronus Magnum II integrated amp, Goldenear Technology's Triton 2+ speakers, Schiit Bifrost Multibit Dac, Technics SL-1200MK2 turntable with Audio Technica 440ml cartridge, Teac X-1000R reel to reel, custom computer as main music source
vzphoneman is offline
post #3 of 8 Old 06-13-2013, 09:51 AM - Thread Starter
Thank you for the kind comment! We always appreciate it.
The unit has gold RCA inputs. That's all we can see.
And yes - they are together. It seems like a separate transformer for each channel.
post #4 of 8 Old 06-14-2013, 12:41 PM
vcrpro3's Avatar
Quoted: 107 Post(s)
Liked: 25
If you can find out what tubes it uses, that may give an indication of its use.....
vcrpro3 is offline
post #5 of 8 Old 06-15-2013, 04:09 PM
vzphoneman's Avatar
Quoted: 104 Post(s)
Liked: 103
I'm with you, my best guess would be a "variable" (?) phono preamp. It's hard for me to judge it's size but It seems overly large and robust. Is there any chance it could have sat under a turntable as a sort of stand. If not it looks like it was made to have something sit on it. Maybe a power amp that it was feeding. Looking at the cap's and having "gold" RCA's it doesn't seem really that old ... maybe 80's. Whoever built it knew their stuff judging from all the components they used. It seem fairly complex for a homemade job. They could have been copying a schematic of a factory made product hence the large layout. Without knowing what tubes it was designed to use you may never know for sure how it works / sounds.
If it had 2 sets of inputs and outputs I would have though it was a preamp / mixer for 2 turntables.
post #6 of 8 Old 06-15-2013, 05:04 PM
vcrpro3's Avatar
Quoted: 107 Post(s)
Liked: 25
My guess is that it would use either 12ax7, 12au7, etc.. http://en.wikipedia.org/wiki/12AX7
vcrpro3 is offline
post #7 of 8 Old 06-17-2013, 06:55 AM - Thread Starter
Thank you all for your input. We cannot figure out what kind of tubes it uses at this time. You all have been very helpful! Thank you!
post #8 of 8 Old 06-18-2013, 01:28 AM
vcrpro3's Avatar
Quoted: 107 Post(s)
Liked: 25
Good grief!, now i'm obsessing on what the tube complement this thing was supposed to have........eek.gif
vcrpro3 is offline
