Denon AVR 3312 issue. Replacement? - AVS Forum | Home Theater Discussions And Reviews
Old 06-18-2013, 06:14 PM - Thread Starter
avthokie's Avatar
My denon is currently, on all inputs, producing a mild crackling sound along with lack of "vocal" sounds. People will be talking and the only voice sounds I hear are the bass from the subs. I am guessing it is the DAC, which will be an expensive fix. I am headed out tomorrow to try and get my money back/ or get it repaired. I would consider the new 4000 with the 4k tech, or another similar model of another brand (Yamaha, P.E. SC 67,...). Has anyone experienced this issue/outcomes, and any recommendations for replacements in the case of it being dead...Thanks!
Denon AVR 3312ci--Samsung pn51e7000--Klipsch RC-62 II--2 Klipsch RF-82 II--Polk fxi-a4 surrounds--Panasonic DMP-BDT300--Xbox 360--PS3--Scientific Atlanta Explorer 8300HDC with TWC--2 Dayton sub 1200's
avthokie is offline
Old 06-22-2013, 07:51 AM
jdsmoothie's Avatar
Quoted: 12155 Post(s)
Liked: 5536
Try resetting the microprocessor (p. 149 OM) after saving the config file to a PC via the Web Control feature (pp. 80-81) and if that doesn't resolve the issue, the unit has a 3 year warranty so check on Denon's website to see if there are any authorized repair centers in your local area.
jdsmoothie is online now
Old 06-23-2013, 09:45 AM - Thread Starter
avthokie's Avatar
Appreciate the help. I will give it a try and look for a repair center if necessary.
avthokie is offline
