noob looking for amp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-18-2013, 11:22 PM - Thread Starter
newc33's Avatar
Quoted: 738 Post(s)
Liked: 915
IV never used an amp before but wanted to one with my new speakers( listed below) where do I start?
1600 cubic foot sealed room! Samsung 8500 curved 4k
denon x4100
JTR noesis 228s LCR
Ascend acoustics cmt 340se side ss.
ascend acoustics cbm170se rear ss
Quad PSA T18s!!!!!!
newc33 is online now
post #2 of 7 Old 06-19-2013, 12:19 AM
runnin''s Avatar
Liked: 45
Well, it might help to know the size of the room and the volume level you are hoping for. Also, is this for mostly movies/TV or music too?
runnin' is offline
post #3 of 7 Old 06-19-2013, 02:26 AM
Nethawk's Avatar
Liked: 118
Can't see the signature link from my tablet, but I believe your new system is Ascend. You really don't need a separate amplifier, any decent AVR will power those speakers adequately. Now if you have money to burn, that's a different story.
Nethawk is offline
post #4 of 7 Old 06-19-2013, 02:48 AM
Bond 007's Avatar
Quoted: 2375 Post(s)
Liked: 1911
The last 2 posts are both correct.
The 373 has no preout to hook up an amp so you would have to buy a different avr.
You dont need an amp. The 373 will do just fine.
Licence to Kill
Bond 007 is offline
post #5 of 7 Old 06-19-2013, 05:34 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Actually implement your equipment list as stated with the possible upgrade of an AVR with Audyssey (Onkyo, Denon).
Its not precisely what I'd choose, but it does look pretty good. Its not going to be a waste of money.
If you wanted to throw more money at the project after the AVR upgrade, next on your list should be your subwoofer. What you've got looks good but its hard to overspend on subwoofers.
Then there are the acoustic room treatments, which would probabaly be a good idea.
Most audiophiles are well served by AVRs in the 80-110 wpc range. One reason is that if you work out the typical peak SPLs, power levels, distances, etc., 50 wpc is all you need unless you want to accelerate your own ear damage, or buy equipment for the sake of buying equipment, even if you are already a little deaf. ;-)
arnyk is offline
post #6 of 7 Old 06-19-2013, 06:18 AM
Bond 007's Avatar
Liked: 1911
Spending that amp money on a subwoofer is a great idea.
Licence to Kill
Bond 007 is offline
post #7 of 7 Old 06-19-2013, 06:38 AM - Thread Starter
newc33's Avatar
Quoted: 738 Post(s)
Liked: 915
Okay thanks for the advice guys. Yeah ill prolly do that. I'm thinking the sub will be a rythmik fv15hp. They said it will blend nice with my lv12r
denon x4100
JTR noesis 228s LCR
Quad PSA T18s!!!!!!
