Differences between Pioneer Elite SC-61 and SC-1222-K? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 06-19-2013, 06:47 AM - Thread Starter
mbuck's Avatar
Quoted: 23 Post(s)
I can get the SC-61 for $600 but it's BB Magnolia's demo unit that's been on the shelf for almost a year. Still full warrantee.
What benefits do I get from the SC-61 vs. the same (actually a touch lower) priced SC-1222?
mbuck is offline
post #2 of 15 Old 06-19-2013, 10:11 AM
daburgh's Avatar
Go to Pioneer's web site, pull up both receivers in a comparison window and ...tada!
Best Regards,
Tony
daburgh is offline
post #3 of 15 Old 06-19-2013, 10:24 AM - Thread Starter
mbuck's Avatar
Quoted: 23 Post(s)
That would be a great idea except those models aren't on there and even if they were they don't have a comparison and both are in different categories (Elite V. Non-Elite).
mbuck is offline
post #4 of 15 Old 06-19-2013, 06:04 PM
vcrpro3's Avatar
Quoted: 107 Post(s)
Liked: 25
Open a couple of windows on your browser and compare the from there...
vcrpro3 is offline
post #5 of 15 Old 06-19-2013, 06:10 PM
vcrpro3's Avatar
Quoted: 107 Post(s)
Liked: 25
SC-61 has more 12v trigger connections......
vcrpro3 is offline
post #6 of 15 Old 06-19-2013, 06:14 PM
vcrpro3's Avatar
Quoted: 107 Post(s)
Liked: 25
Elite has orange display with blue indicator lights and around power button, SC-1222-K, white display...
vcrpro3 is offline
post #7 of 15 Old 06-19-2013, 10:07 PM - Thread Starter
mbuck's Avatar
Quoted: 23 Post(s)
Sorry, what does that mean?
Sounds like there's no real reason to get the sc-61, the 1222 is $50 cheaper than the open box which will have less warrantee and has been used. Right?
mbuck is offline
post #8 of 15 Old 06-19-2013, 10:53 PM
crn3371's Avatar
Quoted: 239 Post(s)
Liked: 192
Do you know for sure about the warranty? I'd think you'd still get the full 2 years.
crn3371 is offline
post #9 of 15 Old 06-19-2013, 11:15 PM
vcrpro3's Avatar
Quoted: 107 Post(s)
Liked: 25
Couldn't hurt to ask about the warranty, if the store says yes to 2 years on the Elite piece...then get it in writing....
vcrpro3 is offline
post #10 of 15 Old 06-19-2013, 11:18 PM
yaomizzle's Avatar
Liked: 26
Any open box will always carry same mfg warranty
Sent from my iPad using Tapatalk HD
yaomizzle is offline
post #11 of 15 Old 06-20-2013, 02:34 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Elite has 2 year warranty, regular Pioneer receivers like the SC-1222 come with one year warranty. an open box model should still carry the full mfrs warranty.
so the advantage of your buying the open box Elite unit is the extra year warranty.
And if the receiver has been sitting there for a year you should be able to negotiate a lower price. You've got nothing to lose by asking.
Afro GT
afrogt is offline
post #12 of 15 Old 06-21-2013, 11:45 AM
daburgh's Avatar
Oh they do my friend they publish a downloadable Product Sheet Brochure in PDF format, grouped in the downloadable manual area. You might have to go to the support pages to get there under some of the older models, as they're not grouped under the current Pioneer receiver offerings. Anyway the information is there and you can do a comparison just like I said. You just have to be willing to think a little.
Best Regards,
Tony
daburgh is offline
post #13 of 15 Old 06-21-2013, 12:07 PM
afrogt's Avatar
Liked: 755
10 second Google search found both receivers...
SC-1222 link on Pioneer website
http://www.pioneerelectronics.com/PUSA/Home/AV-Receivers/Pioneer+Receivers/SC-1222-K
Product Sheet
http://www.pioneerelectronics.com/ephox/StaticFiles/PUSA/Files/Home/SC-1222-K%20New%20Single%20Sheet.pdf
Elite SC-61
http://www.pioneerelectronics.com/PUSA/Home/AV-Receivers/Elite+Receivers/SC-61
Product Sheet
http://www.pioneerelectronics.com/ephox/StaticFiles/PUSA/Files/Home/SC-61%20New%20Single%20Sheet.pdf
Pretty easy to open up a couple of browser windows and compare the two receivers. Or do it the old school way and print out the product sheets.
Afro GT
afrogt is offline
post #14 of 15 Old 06-21-2013, 12:12 PM - Thread Starter
mbuck's Avatar
Quoted: 23 Post(s)
Dude. It takes less time to skip a post that you don't want to help with than to moan and groan about the question asked. I'm new to all this'm new to this, don't know what the specs mean and figured there are some that have the knowledge and want to help. Apparently that's not you, so skip my post. Sorry to take your time. But I did do my research then came here to fill in the gaps.
mbuck is offline
post #15 of 15 Old 06-21-2013, 04:47 PM
daburgh's Avatar
Let me say this, you are one lazy ungrateful Gen X Y Z or whatever generation you are. You guys suffer from an entitlement complex, you believe people should just jump at the chance to serve you. It's not that I don't want to help you, you just communicate like it's too much trouble to look something up. Dood I was saying dude before you were born.
vcrpro3 likes this.
Best Regards,
Tony
daburgh is offline
Panasonic Ptae8000u Hd Projector
