Need new AVR replacement asap - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 06-20-2013, 01:29 PM - Thread Starter
purplerain's Avatar
Quoted: 42 Post(s)
Liked: 27
Need to replace my Marantz SR7001 (goes into protect mode now and then, had it checked, but no avail). All I will use the new AVR for will be TV and BLU-RAY only. What do you guys suggest? Thanks
My current setup is as follows:
(2) Rear WH 2 series Wharfedales
(1) Energy CC10 center
(2) Sound Dynamics RTS-P100 powered speakers (towers)
Marantz SR7001 AV receiver
Velodyne SPL-1500R sub
KRP500M Pioneer plasma
PS3
Dish satellite receiver
*ENTERTAINMENT PURPOSES ONLY - PIONEER KRP-500M*
(2) Monitor Audio RX6 towers - (1) Monitor Audio RX center - (2) Monitor Audio RX FX surrounds - (1) NAD T758 AVR - (1) Velodyne Optimum 8 Sub
purplerain is offline
post #2 of 12 Old 06-20-2013, 04:40 PM
vzphoneman's Avatar
Quoted: 83 Post(s)
Liked: 78
The lazy man finds the easiest way ... Ben Franklin
Rouge Audio Cronus Magnum II integrated amp, Goldenear Technology's Triton 2+ speakers, Schiit Bifrost Multibit Dac, Technics SL-1200MK2 turntable with Audio Technica 440ml cartridge, Teac X-1000R reel to reel, custom computer as main music source
vzphoneman is online now
post #3 of 12 Old 06-20-2013, 05:06 PM
jdsmoothie's Avatar
Quoted: 12176 Post(s)
Liked: 5548
Have you checked all your speaker wiring to ensure there are no loose strands touching another post? Any wire run through the walls which could have be cut but a nail? Is the unit well ventilated or stuck inside a cabinet? If you do replace the unit, upgrade to at least a MultEQ XT unit. Budget?
jdsmoothie is offline
post #4 of 12 Old 06-20-2013, 05:14 PM
afrogt's Avatar
Quoted: 1057 Post(s)
Liked: 758
If your front speakers are powered then you'll need a receiver with preouts. Pretty much every Marantz receiver at least has front preouts.
Do you care about networking?
http://www.accessories4less.com/make-a-store/item/MARSR5007/MARANTZ-SR5007-100w-x7-NetworkingTheater-Receiver-w/AirPlay-3D-4K/1.html
Afro GT
afrogt is offline
post #5 of 12 Old 06-21-2013, 06:38 AM - Thread Starter
purplerain's Avatar
Quoted: 42 Post(s)
Liked: 27
I replaced all wires with 12 awg and banana plugs, but that's not the problem. Plenty of ventilation etc. I just noticed that I have had the crossover set at 100, it has been like that for 1 yr plus. I changed the crossover to 80 yesterday. I wonder if that was/is the problem??
post #6 of 12 Old 06-21-2013, 07:53 AM
afrogt's Avatar
Liked: 758
A crossover of 100hz shouldn't cause your receiver to go into protect mode. That's actually less taxing on the receiver than a 80hz setting. But that receiver should perform well at either setting.
So what happened when you changed the setting?
Afro GT
afrogt is offline
post #7 of 12 Old 06-21-2013, 08:46 AM - Thread Starter
purplerain's Avatar
Quoted: 42 Post(s)
Liked: 27
I just changed it last night.....so time will tell. I dont feel like spending another $500-$800 for another receiver. Its probably happened 10 times in the past few months. When it happens, its just for a second or two. I guess I can live with that.......maybe
post #8 of 12 Old 06-21-2013, 05:23 PM
jdsmoothie's Avatar
Liked: 5548
Lowering the crossover increases the probability of the unit going into Protection mode.
post #9 of 12 Old 06-21-2013, 05:33 PM
LastButNotLeast's Avatar
Quoted: 1488 Post(s)
Liked: 1089
Then keep an eye out here:
http://www.avsforum.com/f/122/great-found-deals
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
post #10 of 12 Old 06-23-2013, 08:10 AM - Thread Starter
purplerain's Avatar
Quoted: 42 Post(s)
Liked: 27
I need to order a new receiver this week, but I do not care about networking.
Need some ideas fast.......thanks all
Marantz SR5007 (new $599)....Marantz SR6006 (Marantz factory refurb $599).....Denon 2313CI (new $530).......???
post #11 of 12 Old 06-23-2013, 07:49 PM
jdsmoothie's Avatar
Liked: 5548
All feature the same version of Audyssey MultEQ XT, so select the model that best meets your feature/input/output needs.
post #12 of 12 Old 06-25-2013, 07:08 AM - Thread Starter
purplerain's Avatar
Quoted: 42 Post(s)
Liked: 27
Going with the Denon 2313CI ($599 NEW shipped)...........Thanks
