Onkyo TX-NR709 Firmware 4107 update problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-24-2013, 10:04 AM - Thread Starter
sgibson's Avatar
Quoted: 89 Post(s)
Liked: 51
Hello All,
When trying to update from Firmware Number:1131-1277-0211-3107 to 4107 via my wired cat-5 network, Message says I already have the latest Firmware(still shows 3107). Any other Onkyo TX-NR709 owners experience this? Should I try the USB Firmware update?
Notice of Firmware Update for TX-NR709
Latest Firmware Number (16 digits): 1131-1377-0211-4107
As of 13 June 2013
Corrects the problem that the OSD menu does not appear when certain source components connected via HDMI are in standby mode
Source: http://www.intl.onkyo.com/support/firmware/tx-nr709.html
sgibson
sgibson is offline
post #2 of 2 Old 06-24-2013, 06:02 PM - Thread Starter
sgibson's Avatar
Quoted: 89 Post(s)
Liked: 51
No Firmware Update via Ethernet problem solved.
Just downloaded and unzipped to USB thumb drive.
Firmware successfully updated to 1131-1377-0211-4107
Took about 15 mins. total.
Just be sure to read the Firmware Update instructions carefully.
After Completion, do not use the remote to shutdown. Use the Power/Standby button on the receiver itself.
Then remove the Thumb Drive.
Link to Firmware:
(Click on the HOW to Install tab and read the pdf before updating.
sgibson is offline
Onkyo Tx Nr709
