Hi guys,
I am getting a CX A 5000 delivered today and will compare it to the Marantz AV7702, as I will buy either of the two units as an upgrade to my existing pre pro.
However I have a couple of questions on the setup which someone might hopefully be able to answer:
1. I am using active speakers, an Oppo 103D Blu Ray Player and a TV. The Oppo has two HDMI outs and can be set up in a way that one HDMI carries the sound information only and the other HDMI carries the actual movie data stream.
My plan was to connect the audio HDMI with the Yamaha and then the other HDMI directly with the TV.
Is there a possibility to activate the OSD for the Yamaha without having an HDMI connection from the processor to the TV?
2. I think I read "somewhere" that the initial setup can be done via browser as well if the Yamaha is connected to the network.
Could someone enlighten me how this is done? I seem to remember that you have to enter the processor´s IP in the browser? How do I know which IP the Yamaha got assigned in my network?
3. I am currently using a Velodyne DD12 Woofer which got a room EQ build in. This is working pretty fine for me and the bass is perfect as it is.
My speakers are all set to 80hz and below that the woofer takes over, which means that the build in EQ does its work as well.
Now when using YPAO is there a way to keep the above described setup, so the Yamaha´s room EQ does only take care of the frequencies above 80 HZ?
4. I read that you can run YPAO from multiple positions.
Is there any benefit of doing this or would it be sufficient to just position the tripod thingy at my main listening position? Just wondering if the whole EQ gets more precise the more measure points it has.
Thanks a lot for your feedback! I am really new to all this fancy stuff as my current processor is a good 10 years old and as basic as it gets!
