Marantz av8801 and the two subwoofer outputs (11.2) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-26-2013, 07:39 PM - Thread Starter
ABQ2013's Avatar
As a newbie, I have a lot of questions. I just bought a Marantz av8801 and it is described as "11.2". Does this mean that there are TWO subwoofer connections possible (i.e. the ".2). If so, then are the two subwoofer outputs the same (both subwoofers have identical output) or are there TWO different outputs. If the latter is true, would this make the placement of the subwoofers more difficult given that the output for two subs is not identical. Can anyone clarify this for me? Thanks.
ABQ2013 is offline
post #2 of 5 Old 06-26-2013, 07:46 PM
ajax-jp's Avatar
Yes. 2 subs.
Think of it like stereo speakers or stereo subs. The levels are independent.
Placement is still non-trivial.
Originally Posted by audioholics.com
It also supports Audyssey Sub EQ HT, a feature we are really excited to see. Sub EQ HT integrates two subwoofers into a system by adjusting level, delay, and EQ independently for each sub. Of Course, careful subwoofer placement is still critical to best performance.
ajax-jp is offline
post #3 of 5 Old 06-26-2013, 10:03 PM
jdsmoothie's Avatar
Quoted: 15085 Post(s)
Liked: 7277
Although the output will be the same, because the unit features Sub EQ HT, the level and delay for each sub will be set independently unlike the 7701 which although also having two sub pre-outs, in actuality is no different than a model using a single sub pre-out with a "Y" splitter as it does not use Sub EQ HT.
For more information, see the 8801 Owner's thread below ....
http://www.avsforum.com/t/1431914/marantz-av8801-preamp-processor-official-owners-thread/0_100
jdsmoothie is offline
post #4 of 5 Old 06-26-2013, 10:09 PM - Thread Starter
ABQ2013's Avatar
Thanks. You answered my questions. I am thinking of buying two Rythmik F15HP subs for my system. My system will consist of a pair of lMagenpan 3.7 and 1.7; Marantz AV8001 and the new Marantz amplifier; I also have an Oppo 105.
ABQ2013 is offline
post #5 of 5 Old 06-26-2013, 10:12 PM - Thread Starter
ABQ2013's Avatar
thanks for your info.
ABQ2013 is offline
Marantz Av8801
