Sound levels in games and Blu-rays - AVS Forum | Home Theater Discussions And Reviews
Old 06-27-2013, 03:34 AM - Thread Starter
DELTAsnake's Avatar
Quoted: 45 Post(s)
I have a Denon AV Receiver with a Kipsch 5.1 speaker setup. I ran the auto-setup on the Denon when I setup the current speaker positions.
On Blu-rays the dialog, music and sound effects sound great, in level with each other.
But when I play a game like Bioshock Infinite where dialog is coming at times from L, R and the Surrounds the dialog changes volume when it is moved from one speaker to another. ie: if Elizabeth starts talking to me from the SL speaker the dialog is louder and then if I turn to look at her the dialog gets quieter when it's in the center channel.
I know I can adjust the speakers volume in the Denon so they are equal, but I'm afraid of loosing what seems like a perfectly fine setup for Blu-rays. How should I proceed and will making games sound more consistent ruin my Blu-ray sound levels?
Samsung UA55HU9000, Samsung HW-J7500, Xbox One, PS4, Wii U. Plus a bunch of old consoles.
XBL: DELTAprime, PSN: DELTAsnake, Wii U: DELTAprime
DELTAsnake is offline
Old 06-27-2013, 05:39 AM
nmunson's Avatar
I had the exact same problem, right down to the same game and same character smile.gif
I'm guessing you have Dynamic EQ on. Try turning it off and you'll see the problem disappear. Dynamic EQ struggles with games because it boosts the rears too much, I find. Another option is to tweak the reference level with Dynamic EQ on. I've been playing The Last of Us with Dynamic EQ on and Reference Level set to 15, and that tones down the rears quite a bit. I think they are just a bit too loud now, but the tradeoff for the other benefits of having DEQ on makes it worth it for me.
DELTAsnake likes this.
nmunson is offline
Old 06-27-2013, 06:04 AM - Thread Starter
DELTAsnake's Avatar
Quoted: 45 Post(s)
Thanks, I never realized that Dynamic EQ was on. Things sound much more equal now. I might play around with the volume settings a bit, see if I can get things a bit more equal than the auto-setup.
Old 06-27-2013, 07:47 AM
JHAz's Avatar
Quoted: 306 Post(s)
Liked: 273
they already are calibrated equal. If you use the internal test tones to re calibrate you run the risk that there are peaks in frequency response that will significantly impact th readings for one or two speakers, and then will be gone when you actually play real content. This happens because the Audyssey corrections are entirely bypassed during manual setup.
See AUdyssey FAQ in AUdyssey thread.
JHAz is offline
