Can't get Coxial Digital Audio cable to work on my Sony Receiver.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 06-27-2013, 04:21 PM - Thread Starter
WaveBoy's Avatar
Quoted: 134 Post(s)
Liked: 43
So, I have an HDMI Cable going from my Bluray player straight to my HDTV(Don't wont to bypass it through my Receiver and send it through another HDMI cable to my TV because there's noticable audio lag when doing so, which is why i opted for Coxial. It's either that or basic audio. Coaxial it is! XP)
and a Coaxial cable coming from my Bluraplayer straight to my receiver....But it's not working. I have everything hooked up properly, the coaxial input on my Receiver is labeled 'DVD in' and it's set to DVD on my Receiver. What could be the problem?
Do you have to manually go into your receivers menu via remote to somehow activate coaxial?
Here's my STR-DG720 Sony Receiver
http://store.sony.com/p/STR-DG720/en/p/STRDG720
WaveBoy is offline
post #2 of 18 Old 06-27-2013, 05:06 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
You can check your manual but it possibly does need the input to be specified as to source unless it auto detects (it may be set to hdmi by default). Were you hoping to not have to read the manual yourself? smile.gif http://esupport.sony.com/US/p/model-home.pl?mdl=STRDG720&template_id=1&region_id=1&tab=manuals#/manualsTab
PS You might also check your player to make sure you don't have to specify output, too
lovinthehd is offline
post #3 of 18 Old 06-27-2013, 05:42 PM - Thread Starter
WaveBoy's Avatar
Quoted: 134 Post(s)
Liked: 43
I'm reading through it right now, but it's a little...well, overly complex. looking for the word COAX. XP
WaveBoy is offline
post #4 of 18 Old 06-27-2013, 05:56 PM
lovinthehd's Avatar
Liked: 4775
Try input audio assignment or something along those lines
post #5 of 18 Old 06-27-2013, 09:23 PM
lovinthehd's Avatar
Liked: 4775
Now that I'm home check page 76
post #6 of 18 Old 06-27-2013, 10:30 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
WaveBoy - Why do you say the coax input on your AVR is labeled DVD? Analog audio inputs never change and they have physical labels on the back of the AVR. Digital audio inputs do not have permanent labels. Rather, they are associated with a name based on the selections made on the digital input assignment screen.
BIslander is offline
post #7 of 18 Old 06-27-2013, 11:02 PM
lovinthehd's Avatar
Liked: 4775
Take a look at the way his avr is labeled on the back, page 23 in the manual (dvd in, coaxial, digital assignable)
post #8 of 18 Old 06-28-2013, 12:18 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
If it is assignable, as digital inputs almost always are, then any physical label is meaningless. If the coax input has been reassigned, it will not be associated with the DVD label. On that model AVR, there are five other inputs where the coax could have been reassigned. p75 of the manual. That's why I asked the question.
post #9 of 18 Old 06-28-2013, 09:07 AM
lovinthehd's Avatar
Liked: 4775
At work again so can't see the manual but IIRC there is a way to check display as to current assignment, think that was on p.76.
Could be he hasn't told his player how to route audio yet too...
post #10 of 18 Old 06-28-2013, 09:18 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Could be. But, on most players, the audio outputs are always active.
post #11 of 18 Old 06-28-2013, 11:37 AM
lovinthehd's Avatar
Liked: 4775
Maybe OP has figured it out....
post #12 of 18 Old 06-29-2013, 07:48 AM - Thread Starter
WaveBoy's Avatar
Quoted: 134 Post(s)
Liked: 43
Correcto! XP Thanks to page 76...well, sort of. I basically went into the menu system, selected 'Audio', which had Optical selected by default, so i clicked down and selected COAX where it then basically links it to whatever Amplifier channel(DVD, Sat, Video 1) of your choice. Easy as pie and works like a charm. thanks for the help you guys! My New Sony 3D Bluray player definitly looks quite a bit sharper/clearer than my PS3 Bluray, plus my new Sony BD player is extremely quite, you can't even hear it vs the extremely loud PS3 Fan which was pretty darndistracting.
I may not get 96hz/dts HD master with a Coax cable but that's fine seeing as how i typically use my pair of Sennheiser HD595 headphones anyways, AND there's zero lag since i'm not bypassing any cables through my receiver from a particular device and sending it out to my TV. wink.gif
WaveBoy is offline
post #13 of 18 Old 06-29-2013, 07:58 AM
D Bone's Avatar
Quoted: 294 Post(s)
Liked: 376
Was the audio late or early using HDMI to the receiver? I'm guessing it was early, and you could have used the audio sync feature in the Sony to correct the issue. Then you get Dolby HD/DTS Master decoding.
Samsung UN60D6420 ~ DirecTV HR-44 ~ Sony S5100 BD ~ Roku 3 ~ Denon AVR-X3200W ~ SVS Prime Bookshelf L/R ~ SVS Prime Satellite Surrounds ~ MultEQ XT L/R Bypass ~ Power Sound Audio XV15
D Bone is offline
post #14 of 18 Old 06-29-2013, 09:40 AM - Thread Starter
WaveBoy's Avatar
Quoted: 134 Post(s)
Liked: 43
Really? well, i've got quite a few HDMI cables lieing around so i could always try this out. And i'm pretty sure the audio was a little late when using HDMI.
WaveBoy is offline
post #15 of 18 Old 06-29-2013, 10:05 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Audio is usually early rather than late because the picture can be delayed by video processing.
post #16 of 18 Old 06-29-2013, 12:17 PM - Thread Starter
WaveBoy's Avatar
Quoted: 134 Post(s)
Liked: 43
Page 45 from the manual >
A.V SYNC.
* A.V.SYNC. N (No) (Delay time: 0ms)
The audio output is not delayed
*A.V.SYNC. Y (Yes) (Delay time: 60ms)
The audio output is delayed so that the time
gap between the audio output and visual display is minimized
So in this case, wouldn't having it set to 'Y' reduce or solve the Audio sync delay problem?
I'm going to throw in a dvd, and see if i can make out a difference between the two for myself.
WaveBoy is offline
post #17 of 18 Old 06-29-2013, 01:00 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Yes, if the audio is ahead, it needs to be delayed to get back in sync.
post #18 of 18 Old 06-29-2013, 01:04 PM
lovinthehd's Avatar
Liked: 4775
I didn't search your manual to solve your lag/gaming thing. Some receivers you can adjust for with a simple lip sync setting if you're using hdmi. Some may also allow an adjustment of the lag time but from what you posted it seems you only have one setting of 60ms (mine is variable from 0-800 ms in 5ms intervals plus has the single sync setting too). Give yours a try (and look through the manual for anything else).
