No sound from front speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-28-2013, 12:29 PM - Thread Starter
jerazm's Avatar
Hi everyone!
I am Jeraz from India. I am new to the forum.
I have a Marantz SR6005 AV receiver. Everything was running perfectly till yesterday (I finished playing a game on my ps3 at around 1.30 am). At morning, when I turned on the system, there was no sound from the front speakers (I was playing 2 channel music so there was no sound at all). I tried various sources including my PS3, Xbox 360, Pioneer BD Player (BDP 150), and even my ipod connected via USB cable.
I navigated to the test tone menu and realized that the centre speaker, surrounds and subwoofer are working fine. The front speakers (Klipsch RF62ii) are not responding.
I am not well-versed with speaker cables and connections. I checked the HDMI cables, and they seem to be connected properly (I am getting video). Also, the speakers seem to be connected correctly, since I do not see any loose ends whatsoever. I am getting sound from my TV speakers, so it is not a source problem.
What could be the issue here? I just wanted to make sure there was nothing I could do before calling the techie (I still have warranty). Any help would be much appreciated.
Thank you!
jerazm is offline
post #2 of 5 Old 06-28-2013, 01:15 PM
Selden Ball's Avatar
Quoted: 3050 Post(s)
Liked: 1494
The 6005 supports having two separate pairs of front channel speakers attached, called A and B. See page 23 in the owner's manual
Check to see if you accidentally selected the alternate (B) set of front speakers (which you don't have). Press the "SPKR A/B button" on the remote to switch back and forth between them.
jerazm likes this.
Selden
Selden Ball is offline
post #3 of 5 Old 06-28-2013, 01:26 PM - Thread Starter
jerazm's Avatar
Thank you so much, Selden Ball. That solved it. I'm so relieved. I'll admit (at the risk of sounding like a total moron) that I was worried I had lost some important internal component. Now, I feel both relieved, and stupid! biggrin.gif
jerazm is offline
post #4 of 5 Old 06-28-2013, 01:46 PM
Liked: 1494
You are very welcome!
Other people have reported the same problem: you are not alone.
Selden
post #5 of 5 Old 01-01-2015, 06:06 AM
nba23tsc's Avatar
Quoted: 45 Post(s)
I know this is an old post but is it helpful or what! I ran into this problem today, googled and found this and sure enough it is this button that did the trick. Believe it or not this is not the first time I ran into this problem and both times I googled for this simple fix.
This is useful info for people who own this model. It is very easy to accidentally press this A/B button so if u find ur front speakers not working it is very likely this problem.
nba23tsc is offline
