Need to confirm a Denon receiver audyssey mic? Thanks. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-29-2013, 12:23 AM - Thread Starter
kuer's Avatar
Have a Denon avr-4308ci receiver without calibration microphone. The original mic model should be dm-a505z, but I just saw somebody said the model dm-a405 is the upgrade replacement of a505z, it can be used for 4308ci.
Becasue of little info about it on the internet, not sure if dm-a405 is suitable or not. anybody here knows of it? I am thinking to buy one mic for the receiver.
Thank you very much.
kuer is offline
post #2 of 7 Old 06-29-2013, 05:48 AM
myoda's Avatar
Liked: 57
http://www.newremotecontrol.com/denon/catalog_item.php?catnum=3210039004
http://usa.denon.com/US/Support/Pages/PartsDistributors.aspx
http://www.encompassparts.com/item/7515616/Denon/3210039004/Dm-a505zem_Avr4308ci
myoda is offline
post #3 of 7 Old 06-29-2013, 05:37 PM - Thread Starter
kuer's Avatar
Thank you for your information. I checked on ebay, really expensive for the original dm-a505z. while dm-a405 has much reasonable prices.
I today contact local denon company, waiting for their reply, If buying one 505z model, i would get it from denon.
kuer is offline
post #4 of 7 Old 06-29-2013, 07:04 PM
myoda's Avatar
Liked: 57
Encompass is a parts distributor for Denon.
myoda is offline
post #5 of 7 Old 07-03-2013, 01:34 PM - Thread Starter
kuer's Avatar
Thank you all.
I got a dm-a505z new from my local denon distributor for a low price, very happy.
kuer is offline
post #6 of 7 Old 05-17-2014, 05:09 AM
HofstraJet's Avatar
Quoted: 17 Post(s)
Hi,
I have the same question as the OP as I am having trouble locating an original a505z. Will any of the other Denon Audyssey microphones work with the 4308-CI, such as the A409 for example? Thanks!
HofstraJet is offline
post #7 of 7 Old 05-17-2014, 05:43 AM
jdsmoothie's Avatar
Quoted: 12089 Post(s)
Liked: 5503
No, the A409 is for the 2008 and newer models. You'll need to use the A505Z.
jdsmoothie is online now
