Surround sound problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-30-2013, 08:56 AM - Thread Starter
daven65's Avatar
Hi. I have a great set of speakers and when it is set to a DVD they all work wonderfully. Surround is great all speakers firing. But when its set to the TV mode only the left/west side of the rooms speakers play. They all obviously work but I have tried everything I can think of when it set to TV but I can't get them all to be in true surround. Help!
daven65 is offline
post #2 of 4 Old 06-30-2013, 09:08 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
Most DVDs have 5.1 soundtracks. Many TV shows are only stereo. Try applying a surround mode such as PLII to stereo sources, which should provide fairly good surround sound.
Are you watching HD broadcast sources, which are usually done in DD 5.1? If so, and you aren't getting DD 5.1, then you have have a setup problem with your source component.
BIslander is offline
post #3 of 4 Old 06-30-2013, 09:18 AM
LastButNotLeast's Avatar
Quoted: 1792 Post(s)
Liked: 1403
Could be a bad cable/connection between the TV (model?) and AVR (model?).
Welcome to AVS!
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #4 of 4 Old 06-30-2013, 09:18 AM
oztech's Avatar
Liked: 101
Make sure the TV is not set to SAP in the audio setup seen this before if no second language is supplied sound will only come out of one speaker also make sure you are using the optical out and not analog from the TV.
Check your audio out settings in your TV's menu .
oztech is offline
