Onkyo TX-SR500 with LG 47CS570 TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-30-2013, 02:59 PM - Thread Starter
ieee488's Avatar
I inherited my father's Onkyo TS-SR500. It has two digital optical inputs. I have a LG 47CS570 TV with one digital audio out. I also have a Panasonic Blu-ray player.
I am having a brain freeze with knowing how to connect up these three so that sound goes to the Onkyo TX-SR500.
TV -- (optical cable) --> Onkyo
Blu-ray -- (RF audio cables) --> Onkyo
If so, do I just buy any Toslink cable of desired length?
ieee488 is offline
post #2 of 8 Old 06-30-2013, 03:17 PM
Knucklehead90's Avatar
Quoted: 504 Post(s)
Liked: 437
To play audio from the blu-ray player (there is no HDMI) connect the player to the optical or coax inputs on the AVR. To play TV audio through the AVR you can connect your sat/cable box via optical or coax to the AVR. Alternatively you could also connect the L/R stereo output from the sat/cable box to the AVR via one of the video inputs or the DVD input.
Yamaha CX-A5000 - VTA ST-120 (6550 output tubes) - Salk Song Towers - Oppo 103
Vinyl Room: Emotiva PT-100 - Acurus A100 amp - Acoustic Research AR-2ax - Marantz TT42 - Oppo 103
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #3 of 8 Old 06-30-2013, 03:22 PM - Thread Starter
ieee488's Avatar
One other question. Do have to specifically turn off the audio portion of the HDMI when I am playing a Blu-ray?
I have the Blu-ray player connected to the TV via HDMI.
ieee488 is offline
post #4 of 8 Old 06-30-2013, 03:30 PM
myoda's Avatar
Liked: 57
TV Out optical cable to Onkyo optical in 1 - this usually works with over the air TV audio. What is your source?
Blu-ray - HDMI out to HDMI input on LG - optical out of Blu-ray to Onkyo optical in 2
myoda is offline
post #5 of 8 Old 06-30-2013, 03:31 PM
Quoted: 504 Post(s)
Liked: 437
Most DVD and blu-ray players output HDMI and optical/coax and L/R stereo simultaneously. If if doesn't you'll need to go into the audio setup and specify which one you are using. Or you can try running an optical cable from the TV to the AVR. Depending on whether the TV outputs the signal in stereo or a 5 channel signal you'll get stereo or surround sound. Not all TVs output the optical signal in surround mode. Experiment to see which sounds best to you. Or easiest.
post #6 of 8 Old 06-30-2013, 03:37 PM - Thread Starter
ieee488's Avatar
I want to make sure I don't have sound coming out of the TV's speakers *and* the AVR.
I will just have to experiment.
My source is cable TV. I have basic cable so I am going straight from the wall to the TV, no cable box.
With the replies, it looks like I need to purchase two 6' Toslink cables.
I also have a DVD recorder which has a digital coax output which I will connect to the AVR's digital coax input.
I just need to find the digital coax cable that my father was using.
ieee488 is offline
post #7 of 8 Old 06-30-2013, 03:45 PM
Quoted: 504 Post(s)
Liked: 437
You can use any RCA cable for connecting coax ports.
Your TV should have an option in setup to turn off the internal speakers.
post #8 of 8 Old 06-30-2013, 03:47 PM - Thread Starter
ieee488's Avatar
Looks like I am good to go.
Thanks everyone.
ieee488 is offline
Onkyo Tx Sr500 A V Receiver , Lg 47lh90
