Marantz NR1602. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-30-2013, 09:10 PM - Thread Starter
H.D.T.V's Avatar
I had a Yamaha 5.1 receiver for a couple years, and decided to upgrade. I thought the Yamaha was rather "bright", and from reading, it seems other people thought so too.
So I looked at Marantz, the 5.1 seemed cheap, but I wanted 7.1 since a lot of new material is in 7.1
Something I did not quite understand, there is nearly a $150 difference in MSRP between the two, which seem rather high for just two more channels of amplification and a ethernet port.
Anyway, I could not afford the 7.1, until I found a place selling them factory refurbished for $369.99, I checked out the site 1st, and they had good reviews. So I purchased it.
Anticipation builds, as it will be here Wednesday. Once it's here I will update the thread with pictures and some 1st looks.
H.D.T.V is offline
post #2 of 4 Old 06-30-2013, 11:39 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
your 5.1 Yamaha might be an entry level model whereas this 7.1 receiver has more features.
you get more than 2 extra channels of amplification.
- Marantz new comes with 3 year warranty
- Marantz 1602 has analog to HDMI video conversion, your Yamaha does not.
- Marantz 1602 can be used as a Zone 2 receiver which means you can have 5.1 in one room and play a difference source in another at the same time
- Ethernet ports means you can stream Pandora, internet radio or use DLNA to pull music and pictures from your PC
- Airplay means you can stream wirelessly from your iPhone, iPad, etc.
- You can use your iPad, iPhone or Android as a wireless remote.
$150 really isn't alot to go from 5.1 to 7.1 considering the extra features. It could be much, much higher.
Afro GT
afrogt is online now
post #3 of 4 Old 07-02-2013, 03:34 AM
jdsmoothie's Avatar
Quoted: 12104 Post(s)
Liked: 5508
jdsmoothie is offline
post #4 of 4 Old 07-02-2013, 05:43 PM - Thread Starter
H.D.T.V's Avatar
Well I got it today.
I hooked it up, and let me tell you, there is a NIGHT AND DAY difference in audio quality, tested with the same speaker.
I can't describe it exactly, but it's like the old Yamaha was filtering stuff out , everything sounded clearer, richer, and fuller. It sounded natural, to say the least.
Since it was a refurb, I expected some cosmetic issues with the unit, but it was in excellent condition.
H.D.T.V is offline
Marantz Nr1602 Av Receiver
