Best receiver for martinlogan electromotion speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-01-2013, 10:18 PM - Thread Starter
Logan92's Avatar
Quoted: 16 Post(s)
Just curious to get some opinions on what the best receiver (5.1 through 7.2 is fine) would be for these:
http://www.amazon.com/gp/product/B004M8S12A/ref=s9_simh_gw_p23_d0_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=0KPHMWSZ62PMJG3MSZ2F&pf_rd_t=101&pf_rd_p=1389517282&pf_rd_i=507846
Trying to spend a little less on the receiver if possible.
Setup:
- Bowers & Wilkins 685, HTMC62B Speakers, ASW61 Sub -
- Denon 1713 Receiver -
- Panamax MR5100 -
- Samsung PN51F8500 -
Logan92 is offline
post #2 of 8 Old 07-01-2013, 11:37 PM
|Tch0rT|'s Avatar
Quoted: 186 Post(s)
Liked: 130
You should state your budget.
MartinLogan ESL's can be hard on amps but the newer ones like the EM ESL's aren't as brutal as the older models. That being said I personally prefer Denon and Marantz. Yamaha Aventage receivers are supposed to be 2ohm stereo stable and that would probably work well with ML ESL's crazy impedance swings. There's also a refurb Sherwood Newcastle R-972 at Accessories4Less I'd checkout but I can't vouch for it or it's amp section. I used the amps in my old school Marantz SR7200 for a while before adding a separate Marantz MM9000 amp. They worked well on receiver power however they are power hungry so the more power you can get the better.
My Home Theater/Video Gaming/HTPC/2 Channel rig (Mitsubishi, MartinLogan, Marantz, DIYMA, and others)
|Tch0rT| is offline
post #3 of 8 Old 07-01-2013, 11:39 PM
yaomizzle's Avatar
Liked: 27
I would look into the pioneers with their d3 amps
Sent from my iPad using Tapatalk HD
yaomizzle is offline
post #4 of 8 Old 07-02-2013, 08:51 AM - Thread Starter
Logan92's Avatar
Quoted: 16 Post(s)
I have to get the receiver from Best Buy (work there), and price wise i'm not looking to spend over $800 really for retail price.
How would the Denon AVRX-2000 or Denon AVRX-3000 work?
Setup:
- Panamax MR5100 -
Logan92 is offline
post #5 of 8 Old 07-02-2013, 09:01 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
The best receiver would be one with Audyssey XT32 - there are a number of Denons to choose from.
I just set up a system with a Denon 1913 and am pleased with the results, so let's say that it or some other Denon with plain old Audyssey Multieq would be your "a little less" choice.
I am not as comfortable with your choice of speaker as others who are posting on this thread. I have yet to see a Martin Logan ESL impedance curve that is not IMO insane and incompetent.
arnyk is offline
post #6 of 8 Old 07-02-2013, 05:43 PM
|Tch0rT|'s Avatar
Quoted: 186 Post(s)
Liked: 130
According to some people over at MartinLogan Owners forum and ML themselves Audyssey is very finicky with ESL's and tend to make them sound like poo. They do have an Audyssey guide for ESL's on that forum though. I can't vouch for that but it's one of my concerns when I upgrade my ancient Marantz SR7200.
To the OP, ah you work at BB? If I were you and were limited to their selection I'd get the highest end Denon they carry that I could afford.
|Tch0rT| is offline
post #7 of 8 Old 07-12-2013, 08:40 PM
JoeB4ever's Avatar
So as a Best Buy employee and a Geek Squad HT installer I thought I'd makes some recommendations that may intrigue you. I'm assuming you're fully aware of the Denon and Yamaha accommodations. From my personal experience installing dozens of receivers from both brands I'd lean toward the Denon. Between the AVR-X2000 and AVR-X3000 I would go with the AVR-X3000 for the little price difference.
JoeB4ever is offline
post #8 of 8 Old 07-13-2013, 07:22 AM
oztech's Avatar
Liked: 101
Same here I have yet to find an instalation where their D3 amps have been strained although I was expecting it a time or two my hat is off to the engineering team that designed them.
oztech is offline
