Choosing to optout of Audyssey MultEQ xt32. Smart decision??? What I hear ... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 07-06-2013, 05:06 PM - Thread Starter
Pianist718's Avatar
Quoted: 134 Post(s)
Hi guys,
So, I completely restored my Denon 4311 to factory settings and decided to NOT do the automatic set up with Audyssey just to see what kind of sound I get and sound I get is pretty good. It seems like before, after running Audyssey, it would tone down the highs due to my room bouncy acoustics, thus possibly harming the sound.
Question is .... am I really missing anything if I opt out of auto set up??? Other than Dynamic Volume control.
The only things I changed manually were...
Sub frequency 120
Crossover 90
Speakers set to small
Speaker distance measured manually
Channel volume ... due to no SPL meter had to do it by ear.
Have any of you opted out of automatic calibration systems that came with your receivers???
Sharp LC-80LE650U 80-inch, Denon AVR 4311ci, Ascend Sierra-1 NrT, Ascend HTM-200 (surrounds), Rythmik F12, WD TV Live Media Player, Samsung BD ES6000, Denon DVD-2910 & Sony BDP-S370 SACD/DVDa, Monster HTS 5100 MKI, Monster Z2 Biwire, Logitech Harmony One, Sennheiser HD600, Schiit Modi/Vali
Pianist718 is offline
post #2 of 16 Old 07-06-2013, 05:27 PM
jdsmoothie's Avatar
Quoted: 12107 Post(s)
Liked: 5510
If Audyssey hasn't been run, you also cannot use either Dynamic EQ or Dynamic Volume.
jdsmoothie is offline
post #3 of 16 Old 07-06-2013, 05:55 PM - Thread Starter
Pianist718's Avatar
Quoted: 134 Post(s)
I know, I mentioned that in my post.
Do you know of a way to get these things working and turning off Audyssey? Is it that function that I saw on remote for MultiEQ that after pressing multiple times you get to Audyssey OFF. Would that be as if I never ran it in the first place?
post #4 of 16 Old 07-06-2013, 06:09 PM
jdsmoothie's Avatar
Liked: 5510
You mentioned Dynamic Volume only ... I added Dynamic EQ, and no, on Denon AVRs you cannot use either Dyn EQ nor Dyn Vol without Audyssey being enabled.
post #5 of 16 Old 07-08-2013, 01:14 PM
DMark1's Avatar
I think it is NOT a good idea to forego Audyssey in your prepro setup. Obviously, there are many advantages to having room correction, which have been analyzed to death on this site already, so I won't go into them again.
The high frequency roll-off above 10khz is the most negative comment I usually hear about Audyssey. I'm not sure why some manufacturers don't give you the option to defeat that HF roll-off (some manufacturers do. I think Marantz gives you the option to have an "Audyssey Flat" curve without the HF rolloff.)
So I say, run Audyssey on your prepro. You can always turn it off, or run your system in Direct mode, or whatever Denon calls the equivalent mode. And, I do strongly believe that movies sound much better with Audyssey than without.
My two cents.
Fine Music, Movies, Wine, and Friends - A Life Well Lived!
DMark1 is offline
post #6 of 16 Old 07-08-2013, 01:24 PM
jh901's Avatar
Quoted: 429 Post(s)
Liked: 152
There is also the downsampling concern, but I'm not sure how many blu-rays have a lossless soundtrack sampling at over 48hz.
In any event, why not set up for Audyssey and then listen with it both enabled and disabled? Passive room treatment will be even more critical without room correction processing.
HT: Panasonic BDT 460 | JVC RS600 | 106" x 45" Stewart ST 100 | Marantz AV7005 | NAD M27 | Elac Uni-Fi UF5, UC5, Debut B6 | Focal CMS Sub
Stereo: Cary Audio 306 SACD Pro | Cary Audio SLP-05 tube line level | Cary Audio SA-200.2 | Focal Diablo Utopia III
Den: Panasonic BDT 220 | 60" Panasonic VT60
jh901 is offline
post #7 of 16 Old 07-09-2013, 05:51 AM
braveheart123's Avatar
Quoted: 311 Post(s)
Liked: 273
My two cents.
That depends on the AVR. Cambridge Audio Azur's raw output in movies is far better than the same EQd by Audyssey MultiEQ XT in Denon 3313
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #8 of 16 Old 07-09-2013, 10:50 PM
DMark1's Avatar
I think that would be very room and system dependant. Audyssey takes much of the room's contribution out of the equation, which will give you a more consistent result across a broad spectrum of rooms. However, I agree that a perfect room and a perfect system would sound better without additional Audyssey processing. Unfortunately, most of us don't have perfect rooms and systems... wink.gif
DMark1 is offline
post #9 of 16 Old 07-09-2013, 11:07 PM
DMark1's Avatar
The downsampling issue is not an ideal solution, by any means. Now that the downsampling hornet's nest has been exposed and stirred up, I expect we'll start seeing manufacturers ponying up for more powerful DSP chips in their products so they don't have to downsample, and can market that as a new "feature".
The jury is probably still out on whether such downsampling is actually audible during normal listening, but I would rather keep everything at it's native resolution, of course. Incidently, most Blurays I've seen have had lossless soundtracks at 24 bit / 48khz resolution. I believe it is the bitrate that is far more important than the sampling rate, so I am glad Audyssey is using the 24 bit rate, even if they are downsampling to 48khz from higher sampling rates.
Good advice on setting up Audyssey and using your own ears to judge in your own system. Also, good advice on the importance of passive room treatment in a good system. I think movies benefit greatly from Audyssey, mainly due to the amount of bass used in soundtracks vs. music material only. After all, Audyssey does it's best work in controlling room modes from 300Hz on down. But, in a good system and room, I think music can sound better without the Audyssey processing. Although, even that is not an absolute, and can depend on the music being played.
I guess the bottom line is set up Audyssey, and use your own ears! biggrin.gif
DMark1 is offline
post #10 of 16 Old 07-10-2013, 02:03 AM
Kilian.ca's Avatar
Liked: 37
The Denon and Onkyo AVRs also have the option. That covers most AVR brands using Audyssey.
It might have been a problem in the past, and IIRC only applied to 192kHz dts-HD MA but it wasn't downsampling as such, rather not able to apply Audyssey. It is unlikely to be a problem now but since you cannot capture processed digital audio out and measure it you can't be 100% sure unless the AVR has info display to tell you (mine does and it remains 192kHz). In any case there're only a handful of BDs with 192kHz dts-HD MA.
The '24' is not the bit-rate. How can you tell Audyssey is processing in 24-bit words?
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
post #11 of 16 Old 07-10-2013, 11:58 AM
DMark1's Avatar
I own an Onkyo PRSC-5508, and it does NOT give you an Audyssey Flat option to eliminate the 10khz rolloff point. (Integra 80.2 is the same pre/pro inside). So, I'm not sure where you are getting your information...? I don't know about the Denons.
No, I think you are wrong on this one, too. You need to read the Secrets of Home Theater article by Dr. David A. Rich that started this whole Audyssey downsampling debacle....
http://www.hometheaterhifi.com/audio-calibration/audio-calibration-reviews/anthem-room-correction-arc-system-part-1/page-9-room-gain.html
Specifically, read the section entitled "Notes on High Resolution Signal Processing". The article even shows graphs taken from the Marantz AV8801 showing that the prepro is clearly downsampling to 48khz when Audyssey is engaged. This is because most prepros don't have enough DSP computing power to do full rez Audyssey processing - However, Audyssey DOES support full 192k sampling rates IF there is enough DSP power to do it in the prepro. It is up the the manufacturer to provide enough DSP power.
Uh, I'm pretty sure the "24" is the bit rate... as in 24-bit/192Khz: 24-bit is the bitrate and 192khz is the sampling rate... What else would you call it? ...
DMark1 is offline
post #12 of 16 Old 07-10-2013, 12:15 PM
Kris Deering's Avatar
Quoted: 1584 Post(s)
Liked: 2491
24 is the bit depth. Bitrate refers to how many bits are coming over in a signal at a given time whether it is video or audio.
My Home Theater
Kris Deering is online now
post #13 of 16 Old 07-10-2013, 12:15 PM
Liked: 2491
And I also agree that bit depth is more important than sampling rate.
My Home Theater
post #14 of 16 Old 07-10-2013, 02:04 PM
DMark1's Avatar
OK, I meant to say "Bit Depth" :-)
Thanks for clearing that up, Kris!
DMark1 is offline
post #15 of 16 Old 07-10-2013, 05:49 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
If one performs reliable listening tests (level matched, time synched, double blind) one finds that exceeding 16 bits and 44,100 Hz sampling has no audible effects if the reproduction system is reasonably free of distortion. Therefore Audyssey's downsampling causes no audible loss of sound quality.
Dr. Rich seems to make no claims about the audibility of this change. Based on his past writiings, I would expect him to eventually conclude that there are none.
arnyk is offline
post #16 of 16 Old 07-11-2013, 12:53 AM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
denon/marantz and onkyo/integra use different terminology when it comes to audyssey eq curves. denon/marntz use "flat" where onkyo/integra use "music" for the eq curve that eliminates the high frequency roll off - my onkyo 809 as this so I presume your 5508 should too.
So yes indeed, pretty much all AVR's w/ ausyssey allows the user to use a flat eq curve...the only one I am not sure about are the NAD units w/ ausyssey.
I don't need snobs to tell me how to think, thank you!
67jason is offline
