LFE different from DVD to Blu-Ray and vice versa? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-07-2013, 12:32 AM - Thread Starter
TK Doom's Avatar
Quoted: 18 Post(s)
I have a Denon 5800.
I am using an Oppo-93 and a Toshiba XA2.
Both are connected via Coax or TOSLINK for DVDs and analog outs for lossless.
I calibrated the receiver and DVDs have a lot more LFE than their blu-ray counterpart.
Is this normal?
Anyone else run into this issue on an older non-HDMI receiver?
My 5800 is waayyy to useful to retire, at least until Denon makes its replacement. (I wasn't in the market at the time to get a 5308).
Any info would be appreciated.
TK Doom
Unreal Tournament Forever
Project Gotham Racing too!
TK Doom is offline
post #2 of 8 Old 07-07-2013, 01:44 AM
Kilian.ca's Avatar
Liked: 37
Yes, because of the difference in LFE handling between digital and analogue inputs, it's all explained here:
http://www.avsforum.com/t/748147/lfe-subwoofers-and-interconnects-explained
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
post #3 of 8 Old 07-07-2013, 07:41 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
LFE is recorded 10dB low and must be boosted in the processor. (With digital, the software does the boost, with analog, the user had to do it.) Bass management is done in the player and when using bass management, the sub output is dropped another 5dB.
The challenge with MCH analog is finding a way to boost the sub without screwing up your digital calibration. Many Denons have a setting for an analog SW boost of 5, 10, or 15dB just for this purpose. That's what I use on a Denon 3805.
If you did not already know this - all speaker setups such as layout (5.1 or 7.1), distance, and bass management must be done in the player since those adjustments are all done in the digital domain prior to the DAC. Your receiver just acts like an amp.
BIslander is offline
post #4 of 8 Old 07-07-2013, 10:34 AM - Thread Starter
TK Doom's Avatar
Quoted: 18 Post(s)
You're referring to the analog out portion, correct? The Coax and Toslink fed through the receiver would be using the receivers calibration?
TK Doom
TK Doom is offline
post #5 of 8 Old 07-07-2013, 12:23 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
Yes. This is not a DVD vs. Blu-ray issue. It's a difference between digital and multichannel analog. With analog, all of the processing had to happen in the player prior to the digital- analog conversion.
post #6 of 8 Old 07-07-2013, 07:10 PM - Thread Starter
TK Doom's Avatar
Quoted: 18 Post(s)
Ok, thanks, I'll crank up that portion...I know my HDDVD player has it, I'm guessing my OPPO does as well.
TK Doom
TK Doom is offline
post #7 of 8 Old 07-16-2013, 09:44 PM - Thread Starter
TK Doom's Avatar
Quoted: 18 Post(s)
Adjusted th LFE on my Oppo 93, everything sounds better now.
Unfortunately my XA2 only has sub yes/no, so my Hd DVD will b sub par.
Thanks for info!
TK Doom
TK Doom is offline
post #8 of 8 Old 07-16-2013, 10:04 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
Well, the LFE output should not be raised in the player. That should happen in the processor or at the sub itself. The reasons are explained in the link that Kilian.ca posted a few entries above this one. The challenge is finding a way to boost the sub for the MCH analog inputs without affecting digital sources. While a challenge, it can be done with most processors.
