Looking for a receiver with analog 5.1 inputs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 07-08-2013, 11:24 AM - Thread Starter
bburroughs's Avatar
It looks like analog 5.1 inputs on receivers have become something of a rarity these days. I'm looking to upgrade my old Onkyo unit, and since I still listen to a lot of SACD's and DVD-Audio surround discs via my pioneer universal player, this is a feature that's important to me. Can anyone recommend a decent sub-$1000 receiver that has 5.1 inputs? I'd also like it to have a phono pre-amp and 2 hdmi outputs, but I can work around both of those requirements. I'd be OK with a model that's a year or 2 old and still available on closeout.
bburroughs is offline
post #2 of 13 Old 07-08-2013, 12:04 PM
JBWIII's Avatar
Liked: 42
The Yamaha RX-A1030 has everything you want: 5.1 inputs, phono stage and two HDMI outputs. Problem is that it's $1100. I looked around for its predecessor model, the 1020, but I don't see it discounted anywhere.
JBWIII is offline
post #3 of 13 Old 07-08-2013, 12:09 PM
JBWIII's Avatar
Liked: 42
Another thought: Does your player have an optical or coax digital audio output? If so, can't you use those instead?
JBWIII is offline
post #4 of 13 Old 07-08-2013, 12:15 PM
BGLeduc's Avatar
Quoted: 1476 Post(s)
Liked: 1320
He can't use that with SACD.
#JB17
BGLeduc is offline
post #5 of 13 Old 07-08-2013, 01:57 PM
enricoclaudio's Avatar
Quoted: 1101 Post(s)
Liked: 1127
Check on the Marantz SR6007 ($899). It has phono input, 7.1CH analog input and dual HDMI output.
http://www.amazon.com/Marantz-SR6007-Home-Theater-Receiver/dp/B0081N91BC/ref=sr_1_1?s=electronics&ie=UTF8&qid=1373313148&sr=1-1&keywords=marantz+6007
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL & Sierra 2s | Rythmik F12SE (x2) | Marantz SR7008 | Parasound Halo P5 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
post #6 of 13 Old 07-08-2013, 02:55 PM
JBWIII's Avatar
Liked: 42
Oops--thanks. I know you can pass DSD over HDMI; forgot about the optical restriction.
JBWIII is offline
post #7 of 13 Old 07-08-2013, 07:28 PM
jdsmoothie's Avatar
Quoted: 12091 Post(s)
Liked: 5503
The Marantz 5007 has the EXT IN but no PHONO or 2nd HDMI output; however, note that most posters using an AVR with Audyssey with an Oppo 105 (or other player with multi analog outputs) generally prefer passing the DSD over HDMI as going the multi analog route will disengage the use of Audyssey which will generally trump any quality difference with the player's DAC.
jdsmoothie is online now
post #8 of 13 Old 07-08-2013, 07:58 PM
JBWIII's Avatar
Liked: 42
I think the OP has a player without HDMI--possibly a Pioneer Universal Disc Player.
JBWIII is offline
post #9 of 13 Old 07-09-2013, 12:33 AM
derrickdj1's Avatar
Quoted: 877 Post(s)
Liked: 590
Look for a used Pioneer SC 35/37 or 55/57.
derrickdj1 is offline
post #10 of 13 Old 07-10-2013, 11:48 AM - Thread Starter
bburroughs's Avatar
Thanks for all the tips. I'll look into some of the suggested options.
post #12 of 13 Old 07-12-2013, 10:58 AM - Thread Starter
bburroughs's Avatar
I wasn't aware that the Oppo supported DVD-A over HDMI. That's an interesting option to consider. Thanks for pointing it out.
post #13 of 13 Old 07-12-2013, 03:10 PM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 419
Originally Posted by afrogt View Post
By a used Oppo 980H and you'll be able to do SACD and DVD-A over HDMI as well as 7.1 analog out.
Does the 980H utlize a bass manager for the 7.1 analog outputs?
Just my $0.02... 👍😉
M Code is offline
