Testing speaker terminals with multi meter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-08-2013, 12:44 PM - Thread Starter
Shakenblake12's Avatar
I have an old receiver and I think some of the terminals are broken. Is there a way to test if the terminals are broken with a multimeter? Like to see if a connection is being made?
Shakenblake12 is offline
post #2 of 4 Old 07-08-2013, 01:39 PM
mogorf's Avatar
Quoted: 1119 Post(s)
Liked: 715
I think the best test would be to hook up a speaker,...and listen. Start with a low volume setting! smile.gif
mogorf is online now
post #3 of 4 Old 07-08-2013, 03:18 PM
budwich's Avatar
Quoted: 62 Post(s)
Liked: 31
yep... get the meter, pop the "lid" on the receiver and check for continuity between the inside contact of a give connector and the contact on the outside. No continuity, no good... :-) OF course, you do this with the power OFF and UNPLUGGED. Basic electronics testing.
budwich is offline
post #4 of 4 Old 07-08-2013, 05:15 PM - Thread Starter
If those leads are broke is there any way to fix them? Would it most likely be the soldering that broke?
