how important is L+R sub outputs ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-08-2013, 04:37 PM - Thread Starter
william77's Avatar
hi
I have the pioneer SP-PK52FS speaker package with the SW-8MK2 sub w/ L+R sub inputs.
i'm shopping for a new amp/receiver ,but most in my price range don't have l+r outputs.
so i guess i'm curious if having an amp with left and right signals to sub will sound better than an amp with one and then use a y- splitter.
theses are what ive been looking at
Sony STR-DH540 ...has L+R sub outputs $228 or
Yamaha RX-V473 ...has single sub output $319
or any other suggestions are welcome must be under $320
i know my budget dosent allow much room
as always thanks to all
william77 is offline
post #2 of 4 Old 07-09-2013, 04:09 AM
kneo's Avatar
You will be able to use the Line in inputs on the sub. Just connect the 'Subwoofer' output from your receiver via a digital coax wire to any one of the inputs in Line In. Or get a Y-adapter and use both Line in inputs.
kneo is offline
post #3 of 4 Old 07-09-2013, 11:28 AM
derrickdj1's Avatar
Quoted: 984 Post(s)
Liked: 721
Usually running a sub cable from the avr to the L input will work. So, no big problem! smile.gif
derrickdj1 is offline
post #4 of 4 Old 07-09-2013, 12:13 PM
hdnewbie21's Avatar
Liked: 38
The receivers you are looking into don't have an L+R sub output. They have 2 LFE outputs, meaning you can hook up 2 subs. A Y splitter will do or following your sub manual direction for hooking up the LFE cable (I think it is the left input in your sub.) I think the subs have L+R to be use on different kinds of preamps and not in AV Receivers, but I'm not really sure.
Yamaha RX-V673 | HSU HC-1 MK2 | HSU HB-1 MK2 - LR | Pioneer SP-BS22-SLR | BIC RtR-V44-2 (Presence)
hdnewbie21 is offline
