Complete Noob to Speakers with Two Speakers - Questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-08-2013, 08:13 PM - Thread Starter
Colton127's Avatar
Hi there,
I have two Jenson Concert Series 1230 laying around and was wondering if they're even worth using. They're very old, but I'm pretty sure they work.
I have no idea how to use these things. I know I'll be needing an amplifier of at least 140W to power them (70W each.)
Any suggestions? Are these even worth using?
Colton127 is offline
post #2 of 2 Old 07-09-2013, 01:45 PM
Selden Ball's Avatar
Quoted: 3171 Post(s)
Liked: 1553
70W is the maximum power that can be used continuously without damaging them, not the power needed for them to work. Just about any modern receiver should work fine. You can get one for less than $250.
The usual connection is (player) --> (receiver) --> (speakers)
The "player" can be a disc player (CD, DVD or Blu-ray), a networked media player or a computer.
Most modern receivers include the ability to stream networked audio sources.
You'll need to buy some speaker cabling, of course. Don't pay more than about $0.30 per foot.
I hope these comments help a little.
Selden
Selden Ball is offline
