Need something inexpensive - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-10-2013, 03:53 PM - Thread Starter
KidHorn's Avatar
Quoted: 1492 Post(s)
Liked: 982
I have an old JVC receiver that turns off 5 seconds after turning it on. It's over 10 years old and I'm not going to spend any time trying to fix it. I need a replacement for a 5.1 system that's in my master bedroom. My wife is the only one who uses it. I don't want to spend much, but at the same time, I want a good deal. I have 6 surround sound systems in my house, so I wouldn't be opposed to buying a 7.1 receiver and handing down an old receiver to the master bedroom. I prefer audyssey, but a Yamaha or pioneer would be acceptable. hdmi 1.4 would be preferred and I only need 2 hdmi inputs. Fios and blu-ray.
Does anyone know of any good deals right now? I probably wouldn't spend over $500 unless it's a great deal.
KidHorn is offline
post #2 of 8 Old 07-10-2013, 03:59 PM
duc135's Avatar
Quoted: 173 Post(s)
Liked: 228
duc135 is offline
post #3 of 8 Old 07-10-2013, 11:56 PM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
^^^ +1 on the 1713...also check out the other great deals accessories4less routinely offers on their site.
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #4 of 8 Old 07-11-2013, 05:45 AM - Thread Starter
KidHorn's Avatar
Liked: 982
I ended up getting this...
http://www.amazon.com/gp/product/B00BHC7ZTE/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
I know it's not as good as the Denon but since my wife is the one who will use it, I need to get what's best for her. I want something new with a warranty where a return is simple an easy. I don't want it to break, so something that isn't known for getting hot is a plus. It has Sony room correction, which is probably much worse than audyssey xt, but coming from something without any room correction, it should be a marked improvement.
Thanks for the replies.
KidHorn is offline
post #5 of 8 Old 07-11-2013, 08:40 AM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
Since it's just for a bedroom I don't think you'd notice much difference between the low-end auto-EQs. For that low of a price you can't really go wrong.
JWagstaff is offline
post #6 of 8 Old 07-11-2013, 09:06 AM
duc135's Avatar
Quoted: 173 Post(s)
Liked: 228
I know you've already purchased from Amazon, but just so you know, accessories4less.com is an authorized Denon reseller and you get a 1 year manufacturer's warranty on their refurbished units. Some credit cards will double that warranty. I know my Amex does.
duc135 is offline
post #7 of 8 Old 07-11-2013, 11:30 AM - Thread Starter
KidHorn's Avatar
Liked: 982
I knew that, but thanks for reminding me. Even with a warranty, having something break and need repair or replacement is a PITA. I've had mixed luck buying refurbs and will typically only buy if the savings is 50% or more off new.
KidHorn is offline
post #8 of 8 Old 07-14-2013, 05:13 AM - Thread Starter
KidHorn's Avatar
Liked: 982
I hooked up my new Sony STR-DH740 and it works great. Sounds much better than my old JVC receiver. Probably because it has an automated speaker setup. The setup only seems to adjust distance and volume. No eq. It stays cool and is small and light. It fits in the old slot with room to spare.
I wouldn't recommend it for a serious AV enthusiast, but for someone who wants 7.1, isn't too picky, and wants to spend the minimum, it's a good choice.
KidHorn is offline
