Sony STR-DN1030 VS Pioneer VSX-1122-K - AVS Forum | Home Theater Discussions And Reviews
Old 07-11-2013, 11:42 AM - Thread Starter
Zoom123's Avatar
Which AV receiver is better, the Sony STR-DN1030 or the Pioneer VSX-1122-K?
The Receiver will have to drive the KEF KHT-2005.2 (5.1) speakers.
Both receivers have the features I need and I can find both at about the same price.
Zoom123 is offline
Old 07-13-2013, 02:15 AM - Thread Starter
Zoom123's Avatar
Any opinions on this?
Zoom123 is offline
Old 07-13-2013, 07:27 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 522
IMO those are two receivers that are not worth buying, as there are much better ones available for the same price or less from Denon, Harman-Kardon, and Marantz.
If I was recommending something in that class to a friend, my first choice would probably be the Denon AVR-1913.
My second choice would be the Harman-Kardon AVR-1710.
Either of those will drive those speakers well with better sound quality IMO.
Don't get hung up on power ratings, because the differences are essentially meaningless and misleading.
For any REAL power output information, you need to look at the Home Theater magazine test results, which often are less than HALF of what the manufacturer tries to imply.
commsysman is offline
Old 07-13-2013, 08:43 AM - Thread Starter
Zoom123's Avatar
Thanks, but the low-end Denons do not seem to provide Analog to HDMI, a feature that I would prefer to have.
Zoom123 is offline
Old 07-13-2013, 09:25 AM
phantom52's Avatar
Quoted: 27 Post(s)
Liked: 84
Test report from Sound and Vision on the Sony below. Seems to be a solid AVR for the price. Good luck.
http://www.soundandvisionmag.com/article/test-report-sony-str-dn1030-av-receiver
You may also want to consider one of Sony's ES models. Those models have 5 year warranties. Their 1800ES is not that much more than the DN1030.
http://store.sony.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=8198552921666485365#features
phantom52 is offline
Old 07-13-2013, 10:20 AM - Thread Starter
Zoom123's Avatar
Thanks. So I guess the Sony is better than the Pioneer?
What exactly would I gain if I go with something like Denon x1000? Seems like the Sony/Pioneer, although older models, offer more features, and from the reviews it seems that the Sony at least can produce good sound.
Zoom123 is offline
Old 07-13-2013, 10:25 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 756
How much analog to HDMI conversion do you need? How many devices?
Afro GT
afrogt is online now
Old 07-13-2013, 11:25 AM - Thread Starter
Zoom123's Avatar
There will be no analog device permanently connected. This is just for occasional use (e.g. connecting my old VCR or video camera). AV Receivers have many features these days and probably I will never use several of them, so I figured that I might as well have a feature that I will need, even if very infrequently.
Then again, if I will gain something significant by choosing another receiver which doesn't have this feature (at the same price range) then I will of course consider it.
Zoom123 is offline
Old 07-14-2013, 05:43 PM - Thread Starter
Zoom123's Avatar
I found the Onkyo TX-NR717 at the same price as the Sony and the Pioneer.
I had looked at the Onkyo TX-NR616 before, which had ideal specs for my needs, but I rejected it due to the reliability issues. Seems that the TX-NR717 doesn't have the same problems.
Should I go for the TX-NR717 instead of the Sony or the Pioneer?
Zoom123 is offline
Pioneer Vsx 1122 K
