Looking for a new Denon receiver. Questions about upconverting signals for NES and SNES. - AVS Forum | Home Theater Discussions And Reviews
Old 07-13-2013, 11:08 AM - Thread Starter
Level99's Avatar
I am interested in picking up a new receiver as my old one (Pioneer VSX-D411) does not have any HDMI or any of the newer surround formats. I am pretty set on getting a Denon as I am interested in giving Audyssey a try and I can get a pretty good deal at Accessories4less. I am considering the AVR-2312CI as it has MultEQ XT as well as video upconversion. The only reason I am interested in the upconversion though is to be able to hook up my older game systems such as NES and SNES through composite and S-video and have them upscaled to 1080p through hdmi for a hopefully better picture than my Panasonic 42S60 gives when hooking up straight through composite(it has no S-Video input). however While looking at the online manual for the receiver it says that a nonstandard signal may not work and These old systems put out something like 240p instead of 480i. Does anyone know if the upconversion would work the way I want it to? If not, I would rather just save some money and buy something like the AVR-1712.
Level99 is offline
Old 07-13-2013, 09:03 PM
Ross Ridge's Avatar
Liked: 81
Old consoles outputed NTSC standard video or they wouldn't have worked with any TV sold in the US or Japan. However, you may have compatibilty problems with older devices like the manual indicates. If this is important to you then I wouldn't recommend purchasing this or any AV receiver unless you can easily return it if it doesn't work.
Ross Ridge is offline
Old 07-13-2013, 09:18 PM - Thread Starter
Level99's Avatar
Interesting. I realize it is NTSC but have often read that they put out a lower resolution but tvs treat it as 480i. This wasn't a problem for old crts but hdtvs have some issues with it. The manual states "When a non-standard video signal from a game machine or some other source is input, the video conversion function might not operate". It doesn't say older devices just non-standard.
Level99 is offline
Old 07-13-2013, 09:26 PM - Thread Starter
Level99's Avatar
Here is a Wikipedia page about it :
http://en.wikipedia.org/wiki/Low-definition_television
A quote from the page:
"Older video game consoles and home computers generated a nonstandard NTSC or PAL signal which placed both fields on top of each other. This is equivalent to 240p and 288p respectively, and was used due to requiring less resources and producing a progressive and stable signal"
Level99 is offline
Old 07-14-2013, 12:43 AM
Ross Ridge's Avatar
Liked: 81
Wikipedia is wrong. You can't "put fields on top of each other", and the referenced articles don't claim this.
CRT TVs didn't support multiple resolutions like way CRT computer monitors did, they only accepted video in one format. For TVs in North America and Japan that was in the format defined by NTSC standard. Lower resolution video simple weren't compatible. A so called 240p video signal is just an NTSC signal where either the interlaced frames are identical or one is blank.
It's possible that these older consoles, and it's only older consoles that cause problems, bent the rules in such away that make them incompatible with some modern equipment, but they weren't using entirely different video format or resolution.
Old 07-14-2013, 11:10 AM - Thread Starter
Level99's Avatar
Ok well whatever the way the so called 240p signal works, I'm not here to argue about it. I just want to know if anyone has had success hooking up one of these older consoles through one of these upscaling receivers either with composite or s-video and having it output through hdmi either at 480i/p or upconverted to 1080p. If no one has, I still want a new receiver anyway for Blu-ray ect. and would just get one without video processing to save some money. In this case I would just hookup the old consoles straight to the tv and deal with the subpar picture quality.
Level99 is offline
Old 07-14-2013, 08:07 PM - Thread Starter
Level99's Avatar
Anyone?
Level99 is offline
Old 07-14-2013, 08:14 PM
Kilian.ca's Avatar
Liked: 37
This thread reports issues with 240p through a Denon:
http://www.digitpress.com/forum/showthread.php?154278-Jittery-picture-w-NES-amp-SNES-through-A-V-receiver
Although the model isn't mentioned it is enough to suggest that it is potentially an issue, but when it happens it's possible to use a line doubler to put out 480p as a workaround:
http://www.avsforum.com/t/1432555/convert-nes-from-240p-to-480i
Having said that the Denon 2312 uses Analog Device vp chip not one of the big names by any means so I doubt it's going to make that MUCH of an improvement. If you're going to drop this idea and get a lower model and cheaper AVR without vp then it also drops Audyssey MultEQ XT too (except the 1712). But then you never find out if it works or not.
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
Old 07-14-2013, 08:34 PM
Knucklehead90's Avatar
Quoted: 384 Post(s)
Liked: 332
Most tv's still accept legacy video connections. Why not just plug the game console into the tv?
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is online now
Old 07-14-2013, 08:41 PM - Thread Starter
Level99's Avatar
Thanks for the links and good points! I might just go for the 1712 and figure out some other way to get these systems to look better on my tv. Maybe some mods or an external scaler or something. Although you are right about not finding out if an AVR with vp works or not if I don't get one. Hmm what to do...
Level99 is offline
Old 07-14-2013, 08:46 PM - Thread Starter
Level99's Avatar
I have had them plugged straight into the tv and it works fine. It just that the picture looks crappy. I was hoping video scaling or upconversion would improve the picture.
Level99 is offline
Panasonic 42 Inch Plasma Hdtv Tc P42s60 , Denon Avr 1712 Receiver , Pyle Home Prjg42 480i 17 67 Inch 4 3 16 9 Led Video Game Projector
