Pioneer VSX-1021 Won't Save Settings... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 07-14-2013, 10:17 AM - Thread Starter
Tezmac's Avatar
I have the titled receiver and it has stopped saving my settings. I unplugged it and moved it into a different room the other day. I plugged it back in and it had lost all of my settings and the receiver display had gone into demo mode. So I powered it off, held in the enter button while I powered it on and reset the system.
I can setup my speaker system configuration, rename my inputs, adjust other settings, exit the setup screen, then go back to the setup screen, and all my settings are still there.
However, once I power the receiver off and then power it on, the volume is reset to zero, my input names are gone, it's back running in demo mode, and my speaker configuration is gone.
Is my receiver toast or is there a setting I'm missing? I have a donor "parts" receiver that I can swap a board out of, but I'm unsure which board I'd need to swap (I'd previously swapped the board with the HDMI ports out).
Thanks!!!
Tezmac is offline
