How do I connect an external hard disk to my amplifier? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-15-2013, 06:58 AM - Thread Starter
bobbyalex's Avatar
I have a Marantz PM6004 amp + 5004 CD player connected to a pair of ELACs. I have a huge collection of hi def music on my external usb drive. Mostly MP3. What do I need so that I can listen to them on my current setup? I know there you could use a line in from my computer but I dont want that. Will a DAC help here?
EDIT:
Based on the replies so far I have concluded that a DAC wont help. Media players with RCA out look promising but most require the TV to be switched on so that you can navigate. Same for XBOX, PS3, DB/DVD players. Anyone know of any that I can use as a standalone unit? Preferably with a remote so that I can just switch it on and start playing.
I had a look at one of the Sonos models but they only seem to stream music from your computer/phone or require a line in from an external device. It does not have storage nor does it accept a USB drive. Know of any alternatives?
bobbyalex is offline
post #2 of 8 Old 07-15-2013, 08:14 AM
r0n1n's Avatar
do you have a media player? usually media players have usb input. connect your hdd to a media player, then connect your media player to your amp. And no, you can't use a dac.
bobbyalex likes this.
Paradigm Studio 10 v5 | Paradigm CC 490 v5 | Mirage Prestige Nanosat | PSA XS30 | Anthem MRX 310
r0n1n is offline
post #3 of 8 Old 07-15-2013, 07:09 PM - Thread Starter
bobbyalex's Avatar
I dont have one. Also, the amp does not have a standard stereo 3.5 mm line in, only RCA. What I am looking for is a device that I can connect to the amp to which I can connect the usb drive and use a remote to skip/pause songs. I dont want to have to use a TV or any other external device like a computer to play music or control the device. I am also ok if the device does not have a USB input but has internal storage to store the music directly.
Any suggestions?
PS: Well now that I think about it, I do have a PS3 and a DVD player. But I need to turn on the TV to navigate both.. plus there is a start up delay.
post #4 of 8 Old 07-15-2013, 07:22 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Many BD Players will play MP3s off of external drives.
arnyk is offline
post #5 of 8 Old 07-15-2013, 07:38 PM - Thread Starter
bobbyalex's Avatar
True but you have to switch on your TV first. I am looking for a more stand alone option. Media players look promising... know any which does not require a TV?
post #6 of 8 Old 07-16-2013, 03:25 AM
Nethawk's Avatar
Liked: 118
Look for a Logitech Squeezebox Touch or classic on Ebay. While discontinued it's the best solution there is. You can navigate via the front panel of the Touch or smartphone/tablet app for either.
Nethawk is offline
post #7 of 8 Old 07-17-2013, 05:42 AM
r0n1n's Avatar
I think most media players will need a TV to navigate through the menus. So you will still need a TV. The Squeezebox is a viable option, or try to search for music servers. Not sure if it has usb input though.
r0n1n is offline
post #8 of 8 Old 07-17-2013, 05:21 PM
bommai's Avatar
Quoted: 194 Post(s)
Liked: 49
If you have an iPhone/iPad/iPod Touch, your best bet is to get a $100 AppleTV. Then use airplay to stream. You don't need to turn on the TV. Works great.
bommai is offline
