Denon E-300 & My 5.1 Setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-15-2013, 11:43 PM - Thread Starter
rpd709's Avatar
Just got my Denon E-300 setup and trying to mess with this Audessy thing following the instructions to the best I know how here is what it came up with, this doesn't seem right?
I have 4 speakers in my ceiling in a square configuration with a Polk center speaker below my TV and then a Polk subwoofer.
Here are photoshots of what the configuration came up with and would like your thoughts and help if at all possible.
photo(14).jpg 477k .jpg file
photo(15).jpg 483k .jpg file
photo(16).jpg 484k .jpg file
photo(17).jpg 470k .jpg file
If more or different photoshots are needed I am more then happy to provide those. I appreciate this forum very much and all the help it provides!
ID:	70822   Click image for larger version
ID:	70823   Click image for larger version
ID:	70824   Click image for larger version
rpd709 is offline
post #2 of 7 Old 07-15-2013, 11:55 PM
afrogt's Avatar
Quoted: 1055 Post(s)
Liked: 756
We have no idea if the distances are correct since we're not in your room.
But since the channel level for the subwoofer is -12.0db, that means the subwoofer volume is way too loud. turn down the subwoofer volume knob to the 9:00 or 10:00 position and rerun Audyssey. You really want the sub level to be close to 0db. Somewhere between -3.0db and +3.0db is good. Then all the other channel levels will change too.
Afro GT
afrogt is offline
post #3 of 7 Old 07-16-2013, 12:00 AM - Thread Starter
rpd709's Avatar
OK, I will do that. I used a tripod and did the measurements. I put the subwoofer at 50% volume like it instructed so not sure what happened there.
rpd709 is offline
post #4 of 7 Old 07-16-2013, 12:37 AM - Thread Starter
rpd709's Avatar
Turned the subwoofer to 10 oclock position and reran the tests and it still told me -12.0 Good grief.
rpd709 is offline
post #5 of 7 Old 07-16-2013, 12:38 AM
Nutdotnet's Avatar
Quoted: 108 Post(s)
Liked: 41
All subs are different. It's merely a suggestion. Lower your dial on the sub and re-run
Nutdotnet is online now
post #6 of 7 Old 07-16-2013, 12:43 AM - Thread Starter
rpd709's Avatar
I will redo it again in the morning. Also will go lower on the sub.
rpd709 is offline
post #7 of 7 Old 07-16-2013, 01:00 AM
afrogt's Avatar
Liked: 756
Lower it to 8:00 then. Basically keep lowering it until you get a sub channel level in the -3db to +3d region.
Afro GT
afrogt is offline
Denon Avr E300
